Question about RCA D52W19 52" Rear Projection Television
RCA TV - D52W19 Unplugged and moved it away from the wall to paint, moved it back, plugged it in and now it will not turn on. It is very hard to tell if the green light is going on but it is definately not making any sound. This TV may be about 3 or 4 years old, but it is not used much. Maybe abount 2 or 3 times a month. Any suggestions on what we can try. Paul
  • 59 Answers
Chek the plug on the cord, the rca have a tendancy to break if moved sharply, relace the plug end
Posted on Apr 01, 2011
52" RCA Scenum froze and would not turn off. I unplugged it and then plugged it back in. All the lights are on in the front of the tv but it will not turn on.
The small signal board is the most likliest cause of that issue which is a very famous symptom for the ITC222 and ITC222A chassis RCA models. You can usually get the small signal board from www.tvrepairworld.com several versions were used so they can assist with identifying which version ssb your model requires.
Apr 03, 2013 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52 in, as speaker was put beside it & the convergence is out.
Move speaker away, unplug tv for a few hours, restart and do convergence adjust using menus.
Nov 27, 2011 | Televison & Video
When i turn on my tv., the indicator light will come on and off again three times before going off. No picture showing.
I have this same problem you can unplug it from the wall for an hour and it comes back on for several hours. However if you don't keep it unplugged for most of the day then you will have this problem everyday until you buy replacement parts.
Jan 12, 2011 | RCA D52W19 52" Rear Projection Television
My rca d52w19 makes a noise when turned on.no picturet henshutsof
what kind of noise? is it like an electrical buzzing?
a rapid clicking?
Apr 29, 2010 | RCA D52W19 52" Rear Projection Television
D52w19 rca hdtv.will not tourn on. when u push the
Hi Friend,
Please folliow the below steps one by one
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
If still you are having the same problem then please check the resolution configured in the Screen,try to reduce the Colour and the brightness of the TV
Even after that you are facing the same issue please check with the Display Card in the TV,
If you have any Clarification please feel free to contact us
Regards,
Ayyasam
Apr 03, 2010 | RCA D52W19 52" Rear Projection Television
RCA d52w19 green LED flashing and speaker int/ext switch problem
The most probable cause are the Three capacitors CP150, CP114 and CP120 all located on the deflection board.
Dec 13, 2009 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52 in When my set is Immed, turned
WHAT ISTHAT WHEN MY TV MAKE NOISES THEN STOP FOR AMINUTE ONCE THE PICTURE IS THER THEN 10 MINUTES IS CUTOFF LIKE ITS TRYING TO COME BACK ON WITH THE SAME NOISES
Jul 15, 2009 | RCA D52W19 52" Rear Projection Television
RCA Tv wont come on at all. No light s flash or
hi, i think cathode ray tube has burnt out .......first check the fuse also thank u.......
Jun 03, 2009 | RCA D52W19 52" Rear Projection Television
Will not turn on
Does the set make any sounds. DOes the front green led light or flash when you try to turn it on.. if not then it could be as simple as a fuse, if it does flash then it can be many problems
Jan 06, 2008 | RCA D52W19 52" Rear Projection Television
Rca d52w19byx1
You could get away with replacing it if you get a 'freeview box' and connect it to the scart socket on the back of the tv and then connect your ariel into the freeview box instead.
Nov 12, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
55 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
