Question about Goldstar M1003R Air Conditioner
Cord to plug in
So my dog ate the cord to my window unit. i got a plug to attach to the frayed cord, but i need to know which wire to attach to which part of the plug. the green ground wire is clear, but the plug offers the options "black" and "white" and the cord does not have different colors for the + and -. only one side of the cord is ribbed, and the other side has writing ("seshin" and lots of numbers). which side is "black" and which is "white"? thanks!
mm
    Genius:
  • 1,198 Answers
On a 120 volt plug, the smaller plug is black, power. The larger side is white, neutral. The center round plug is green, ground. Make sure your ac is not 220, the plugs are in line above the neutral. On 220 both are power.
Posted on Aug 18, 2008
My power cord for the docking station is beginning to unravel with wires showing. Can it be replaced or repaired?
First, I know nothing at all about ipods. However, I am a decent electronics guy. Obviously, one end of the power cord plugs into a wall outlet; the other connects to the station. How? Does the cord simply disappear inside the station, or is there some kind of connecting plug? Which end is frayed? If it's at the wall plug end, you could simply cut the wire (unplug it first !!!) above the fray and wire in a new standard wall plug. You can do the same on the station end if the wire runs directly into the unit AND if you can get in there to reconnect the wire. If, on the other hand, the wire is attached to the station via some sort of power plug (like a printer for example), you'd better leave that puppy alone and invest in a new docking station or new power cord. You'd also better stop using the unit unless you can fix it. Bare wires spell tripped breakers and danger of injury.
May 28, 2016 | JBL ONSTAGE Docking Station for iPod
My acer aspire one notebook won't boot up.
Is the new cord/charger/transformer the EXACT same power specs? When your "dog ate your charger", it may have shorted out something in the Laptop? Was it plugged it when your dog ate it?
Jan 16, 2013 | Acer Aspire One PC Notebook
My dog ate my ignitor plug
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Tips Tricks
Yamaha XJ 650 4K0 80 84
http://www.carlsalter.com/pdfs/Yamaha_XJ600SK_Owners_Manual.pdf
OEM parts for Yamaha
Yamaha XJ750 Owners Workshop Manual
Oct 08, 2012 | 1981 Yamaha XJ 650
Have a rule 1800 Pump and my dog ate the cord
so cut repair and tape and fix if its near water side use silicon make sure dosent hit water
Jul 22, 2012 | Rule 1800 H53SP-24 Swimming Pool Cover...
My dog ate the cord to the fan I need to know how to replace the old with a new one
Hi mlh9188
You can replace your cord that was eaten by your dog very easy.
Disassemble your fan.
Be sure to mark how the fan is assembled with an awl or sharp instrument to scratch an alignment scratch on the outside of the motor case before you disassemble it....maybe even take a picture
Once you have the fan disassembled to the point that you can get to where the wire that was chewed is connected to the fan, you will disconnect the wires from the plugs,sockets,etc...take another picture before disassembly.
Take the old cord with you down to your local hardware store,loews,homedepot,ace hardware,etc.
Tell the person in the electrical dept what happened, and he will fix you up with a new set up.
Come home install the new cord and plug...keep away from dog...
Please take time to rate me
Sep 10, 2011 | Patton U2-1487 Floor / Box Fan
I have an older model RCA television ( but it's ot all the hook ups for today) and my dog accidentally ate through the cord, should I take it to a shop or just buy a used tv somewhere else & not even...
I guess it depends how far up the cord your dog ate through it! You could cut the cord off at the bite, fit a new plug and use an extension cord to reach the socket. Other than that, I don't think its an expensive job to get a complete new cord fitted - depending on the repairer, it should still be cheaper than a replacement tv
Feb 04, 2011 | RCA Televison & Video
I need a power cord for an emerson tv
Hope the dog is well. Best to go to hardware store and buy a plug to replace yourself. Is it two wires, or three? Is it round or flat cable? Also if this is a continuos problem you might want to get a length of metal clad cable to put over the cord before you put the new plug on.
Mike
Mar 26, 2009 | Emerson EWF2704 TV
Broken electrical cord
The belt can e replaced but I recommend you should take it to your local vacuum cleaner service center. They may even be able to fit a new plug on the end for you if the damage is at the plug end.
Mar 20, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Help! Dog Bit Through Electrical cord on Lakewood 2727. How to replace cord???
another option for you would be to use crimp on terminal connectors(**** connectors) you may purchase these from most hardware stores. Even using these I would still tape around the outside to ensure a good insulating surface.
Apr 28, 2008 | Lakewood 2727 Heater
Goldstar M1003R Air Conditioner Logo
148 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
