Question about Mustek Steering Wheel
I have problems with foundin drivers for "Mustek steering wheel 80-SW100". it' old version.. thanke you :)
I am searching for Mustek 1200 UB driver for windows 8.1
find an old XP version and right click on exe then compatible , tick box then select xp service pack 2. them apply. run exe as admin it load in fine and as it should.
May 15, 2016 | Mustek Office Equipment & Supplies
Compatible drivers for mac OSX 10.8.3
Yes the Mustek A3 2400S can run on OS X 10.8.
Go to http://www.mustek.com.tw/support/driver-manual-downloads.html . Check the serial number of your Mustek A3 2400S scanner. Then use the drop-down menus in the left column of the page to choose the scanner model and indicate the first three alphanumeric characters of the serial number. Then select Driver and ayour OS. The Mustek site has a driver for the D3K models that covers OS X 10.7-10.12. For the scanners with D18 serial numbers, there is a driver for OS X 10.6-10.8 and a second driver for OS X 10.8-10.11.
I hope this helps.
Jun 01, 2017 | Mustek A3 USB Flatbed Scanner
I can't found my BearPAw scanner drivers for Windows Vista. Could you help me?
Hi there, You don't get a Driver for Vista for your scanner but you can use the windows XP one. It will work as well. You can download them at the site below. http://www.mustek.com/mustek/supportdrivers.php
Hope it helps
Regards,
Jul 30, 2011 | Mustek Be@rPaw 1200 Flatbed Scanner
Loss of drivers my pc cot detecting scanner how to free dawn load drivers -Scan 1200 CUBMustek
Hi. Thanks for your question.
please go to this website------>http://www.mustek.com/mustek/Support.php
Select category --->scanner Series ----> USB Then choose your model. Click on the latest version of your driver and your download should start automatically. Once downloaded execute file. Please remember that while installing your scanner needs to be unplugged unless told to plug in by program.
I hope this helped. Thank you for using FixYa
Dec 17, 2010 | Mustek Plug-n-Scan 1200 UB Plus Flatbed...
I need drivers for my scanner with serials number:80-091-04130
Ha this looks like a Packard Bell Diamond 1200 Plus. Allegedly these were made by Mustek so Mustek 1200 USB drivers should work. I'm still working on this myself but I thought I'd pass on my two pennyworth. Good luck!
Sep 12, 2010 | Office Equipment & Supplies
How to take of steering wheel in audi 80
First you have to disarm SRS system.How- ensure ignition switched OFF.Remove ign.key.Disconect battery earth lead and make sure accidental reconection is not possible.Disconect power suply multi-plug/red/,located behing driver.s storige compartment under fascia.No waiting time required. Now you have to remove driver.s airbag.There is two screws with 5mm allan/hexagon/head behing an airbag.Open it.Disconect and remove airbag.Use 24 socket for steering wheel nut. When remove a steering wheel be very carefull with spiral cable behing.GOOD LUCK !!! There is tightening torque for steering wheel nut-40Nm and two screws-6Nm.
Apr 24, 2010 | 1991 Audi 80
I am running WIndows 7 and my scaner Mustek 1200 UB+ is unreconisable by system. It does not accept XP drivers. Please give me adress to download apropriate drivers for my device or possible solution....
New operating system same old problem
Contact Mustek to see if they have an upgrade set or you will need to wait till someone gets around to either writing a new one or hacking a new one
Oct 23, 2009 | Mustek Plug-n-Scan 600 Flatbed Scanner
Packard bell branded Mustek Be@arpaw 1200CU+ scanner
FIRST and most important - uninstall any other attempts at scanner software using the control panel and add/remove software.
THen download and run this file: ftp://ftp.mustek.com.tw/pub/driver/BearPaw/1200CUPLUS/Windows/PS1G_WEB.exe
This works for my Packard Bell branded Mustek Bearpaw 1200CU+ scanner under XP Pro SP3.
On the same site Mustek also have Vista drivers available!!!!!
Sep 07, 2008 | Mustek Be@rPaw 1200CU+ Flatbed Scanner
Drivers for Diamond 1200
The Packard Bell Diamond 1200 Plus is in fact manufactured by Mustek and is the Mustek Bearpaw 1200 CU Plus.
Packard Bell no longer support or list this device on the website but drivers can be found at Mustek's European site
http://www.mustek.de/11/index.php/en/ser...
They provide drivers for Windows so make sure you download the corret one for your version
Feb 22, 2008 | Packard Bell Packard-Bell Full Page...
Video Game Consoles & Games Logo
Top Mustek Video Game Consoles & Games Experts
James Wishart
Are you a Mustek Video Game Console and Game Expert? Answer questions, earn points and help others
