Question about Rinnai RHFE-556WTA Direct Vent Heater NG Air Conditioner
# 11 appears when it trys to start...... not heating
    Brigadier General:
  • 4,736 Answers
Code # 11 indicates an Ignition Failure. According to the Owners Manual you should do the following: Check that gas is turned ON. Check that the vent termination is not blocked. Refer to the Restart Function explanation.
RESTART FUNCTION:
If the appliance fails to ignite, the appliance will attempt ignition after 1 hour. The "Ignition Failure" fault code, 11, will appear during that hour and disappears after a successful ignition. If ignition fails again, then the fault code will remain and another attempt to ignite will occur in 1 hour. The fault code is not stored in the fault code history.
If the flame is extinguished during forced combustion then the appliance will attempt ignition after 1 hour. The "Ignition Failure" fault code, # 11 will appear during that hour and disappears after a successful ignition. Forced combustion takes place for about 15 seconds after ignition. After this time, the temperature control logic controls the combustion.
If the flame is extinguished (burner combustion failure) while the temperature control logic is operating the appliance, then the appliance will immediately attempt ignition. No fault code will appear.
In this problem repeats itself, contact you local Rinnai Authorized dealer/serviceman.
Hope this helps you to troubleshoot and solve the problem.
Posted on Mar 31, 2011
Engine trys to start but wont. I have a new battery and the alternator is tested good. Will start sometimes with a jump even though it doesnt appear to be the battery.
If the car isn't turning over slowly as you try to start it, it's not the battery. If it started acting up just after a fuel fill-up, or if you're in a cold climate and your fuel level is low - I'd check for water in the fuel. Treat with Isopropyl alcohol (iso-heat or heet brands) in teh fuel tank. let it sit for 30 mins and try starting for a bit. probably won't start on this attempt. Let set for another 30 mins and try again.
If it's not he above, I would look at teh fuel pump as the culprit. You can test by attaching a fuel pressure guage to the fuel rail - pressure should be between 20-30#. Or have a shop test it.
Jan 23, 2011 | 2001 Mercury Sable
Trys to start up for about 8 seconds then stops then reads c2 then 11
overheat stat, or fan check little hose at fan for pinhole best of luck
Nov 01, 2009 | Rheem RTG-53XP Outdoor Liquid Propane...
Trys to fire up then after about 8seconds then
overheat stat or fan check little tube at fan area for pinhole best of luck
Wont run while under load
ok buddy i know the problem before the pipe connects to the tank it goes to a valve unscrew this and check the rubber inside turning it around if necessery get back to me51a35be.jpg
Sep 19, 2009 | Coleman Powermate 11 Gallon Air Compressor
Heat pump takes many trys to start compressor
do the thermostat have a time delay on it? most digital ones do you may have to get one if thats the case. Also are there start components on the unit? I've had top add them due to the newer units hasve nonbleed txv's and have a hard time starting up because of them. ans if oyu can see if there's a crank case heater on the unit becaause refrigerant migrates to the coldest spot and the compressor can have all the refrigerant inside of the can mixed with the oil. goof luck
Jan 10, 2009 | Comfort Products Heating & Cooling
Dell 610initial start up problem
Hi!
You are unable to enter bios....to select drive c...try to remove the hard drive and install it in the other machine that you have....or just boot your notebook without the Hard disk and see if it makes any difference.....
Can you explain more on...
"The computer trys to start and then just shuts down in approx, 8 seconds."
Nov 13, 2008 | Dell Latitude C610 Notebook
32" sylvania TV thin line
There are bad solder connections on the vertical IC. This is a small flat IC attached to a heat sink. It should have about 9-11 pins and may be marked LA7837 or something similar. Resolder the pins on this IC and that should resolve the problem.
Dan
May 07, 2008 | Sylvania SRT2232S 32" TV
Running fine but no heat
YOU HAVE A SOLENOID (COIL) ON THE VALVE THAT IS HEATING UP AND BREAKING CONTACT INTERNALLY. WHEN YOU BUY THE COILS, THEY COME AS A SET SO YOU WILL REPLACE BOTH OF THEM.
Apr 10, 2008 | Estate TGDS740JQ Gas Dryer
Rinnai RHFE-556WTA Direct Vent Heater NG Air Conditioner Logo
358 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
