Question about Ovens
We have a Emerson Microwave Oven model # MW8115SS and it has power, but does not heat up. Key pad and light inside work. Where do I find the fuses to check and possibly replace?
  • Ovens Master
  • 3,740 Answers
You have to remove the 4 side screws and the 4 rear screws of the chassis cover then slide the cover to the rear about 3/4" life the rear of the cover about 30 degrees and remove the cover. Follow the power lead to the first connection and you will see a fuse holder. This is normally a 20 Amp slo-blo fuse. The fuse fails either from a bad power diode that is near the HV capacitor or a bad HV capacitor most of the time. MAKE SURE YOU DISCHARGE THE CAPACITOR BEFORE reaching inside the cabinet. Take a screwdriver and ground across the terminals at least 3 times.
You read the diode with a meter using R X 10,000 it will read zero ohms with the leads in one direction and infinity when the leads are reversed. You must disconnet at least one terminal from the diode to read it properly.
You test the HV capacitor using the same meter setting and reversing the leads. Eavh time you reverse the leads your watching for a momentary jump in capacitance and then the meter moves to infinity. If it reads continuity or no jump then the HV capacitor is bad.
This microwave has been around for quite some time.... so long that there are few manuals out there for it. If you find a failed part.. walk into your nearest appliance parts source with the failed part in hand. Use of GENERIC parts is fine.
Thanks for choosing FixYa,
Kelly
Posted on Mar 31, 2011
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    The fan works but the oven doesnt heat up
    If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
    So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
    then it must be checked or replaced.
    See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
    Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
    Now keeping clear of the microwave, switch on, use a cup of water inside to test.
    If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
    If there is heating without any issues, you can use the microwave safely
    Jul 13, 2011 | Whirlpool Ovens
    Microwave will not heat. Turntable does not move. Lights come on and fan is working. Ideas?
    Apr 14, 2011 | Ovens
    Light is working, plate is a;so rotating but not heating
    Apr 11, 2011 | Ovens
    I was defrosting meat in the microwave and my microwave just quit. The fuse box was checked. MY microwave is blank. What is the problem?
    If there is no action please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
    Oct 09, 2010 | Ovens
    Oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where...
    oven will not heat up. microwave works fine. all oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where is it located
    Jul 19, 2010 | GE JKP86 Electric Double Oven
    Self cleaning oven won't start self clean mode
    NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
    Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
    GE Advantium Microwave oven SCB2000CBB 03 LZ90Z940K
    Sounds like the door monitor switch, which would take out the internal ceramic fuse. I'd replace those two plus the primary and secondary door safety interlock switches.
    Sep 19, 2008 | Ovens
    KitchenAid KEMC308KSS02 Microwave Error
    The micorwave oven light does not work and when I push start, the word DOOR shows on the screen and beeps 3 times. The oven will not start.
    Jun 14, 2008 | KitchenAid KEMC308 Electric Double Oven
    Ovens Logo
    137 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
