Question about Rowenta Irons
Hi my rowenta 1800wi will light on but no heat on iron surface light keep blinking orange..
SOURCE: Rowenta Steam Iron Leak
Yes, my rowenta model DX6700 is also leaking from the heal. I bought this iron after having a GE for ten years because I thought it would iron my clothes better. I've had it less than two years. How frustrating!!!!!!
Posted on Aug 01, 2008
wizzard8955
  • 18 Answers
SOURCE: My Rowenta iron will not heat up. The yellow light
Inside the iron is a piece of thermal metal the is supposed to make contact with a small ceramic pin with a metal cap on it. I think this was intended to be a safety device but they fail and the iron will not heat up. The part does not seem to be available so easiest way to fix is to put a small bead of glue on the housing that forces this to make contact.
Posted on Mar 06, 2009
SOURCE: new rowenta effective iron that doesn't heat and steam correctly
Don't use distilled water-I had same problem. It was built to use regular water. Solved problem
Posted on Mar 08, 2009
omaromid
  • 332 Answers
SOURCE: I have a Rowenta DX1700. The iron will only stay
The problem is with the iron's thermostat which controls the temperature of the iron
Posted on Feb 07, 2010
heatman101
  • 43501 Answers
SOURCE: I have a rowenta advancer DZ9080 iron that the
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
Heat goes off and red light blinks
Contact Rowenta if the yellow and red LED lights start to blink; this indicates an internal electrical failure.
There are over 200 complaints on the consumer affairs website, that include same this problem.
Its better to be safe than sorry.
Apr 24, 2014 | Rowenta Irons
My rowenta iron which is about 4-5 years old starts blinking the red on-off button after only 2-3 minutes of use. Also the orange button will not stay lit. What is the problem? The red on-off button does...
your iron has a thermostat fault its this thermostat thats cutting in and out that puts the red light on it could be fixed but that wont be a cheap fix best bet is to buy a new iron as that would work out cheaper
Sep 11, 2010 | Rowenta DX6700 Iron
Rowenta Advancer iron has been working for 2 years and now won't heat up. I have checked the cord and it is fine. The heat indicator light comes on but I don't measure any voltage going to the hot plate....
<div class="solution-text"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution"><span><span>Hi,<br /><br />Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.<br /><br />Electric Iron not Heating Up or not Working Right <br /><a href="http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not" target="_blank">http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not</a><br /><br />heatman101 </span></span><br /></span></div><!-- /solution text --><!-- helpful bar -->
Aug 25, 2010 | Rowenta Irons
Iron won't heat up, the 3 lights of yello green and red blinking
heatman101
May 03, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Feb 07, 2010 | Rowenta Effective DX1700 Iron with Auto...
Red light keeps blinking and iron shuts off
Sounds as if the cable may be damaged or a loose connection. May be cheaper to buy a new one from wallmart or similar store.
Jul 31, 2009 | Rowenta Effective DX1900 Iron with Auto...
My Rowenta iron will not heat up. The yellow light just continues to blink- so I know that there is some electrical current. I have a friend with the same issue with the same iron. Is there a trick to this...
Mar 01, 2009 | Rowenta Professional DM890 Iron with Auto...
My rowenta effective will not heat up.
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Dec 15, 2008 | Rowenta DG5030 Iron
Irons Logo
23 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
