Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Problem with our KitchenAid Superba side by side: Food placed in the top 2 crisper drawers freezes (happens regardless of temp settings for fridge or freezer). Thanks!
  • 2 more comments
  • hspope Mar 31, 2011
    Thanks for your input ZJ!
    If it's the control board would the sound of the fan be more random - stop and go? - it seems fairly constant...Also, the top shelves don't seem any warmer than they should be (or radically warmer than the lower areas).
    On this model, the drawers are fed colder air directly through a small hole from the freezer....is this different from the LG?
    Also the kick plate (grill cover) has been off for a year or 2....would this effect things?
    Thank you!
    I haven't checked these things yet, but will.
    quick questions:
    How do I access the fan motor?
    Are the condensor coils accessed from the front and does the power have to be off to clean them?
    Thanks for your help!
    Thanks very much Macmarkus, I'll let you know how it goes!
  • KitchenAid Master
  • 2,605 Answers
Hello, Welcome to FixYa. I can see your dialog from previous post but not the other expert who was exchanging dialog. What I gather from this is the items inside the drawers freeze regardless of the temperature setting. Is this correct ? There are a couple of thing's I'd focus on with these symptoms, the condensor and condensor fan motor. First insure the condensor fan motor is turning freely and running when the compressor is operating. Second, insure the condensor coils under the fridge are completely clear of lint and dust. If these coils are clogged or blocked in any manner the unit will not cycle correctly, thus causing items to freeze...especially fruits and veggies even when in a drawer. It is possible the damper motor is not working properly as well and thereby staying wide open at all times allowing continual cold air into the fridge section. I would focus on the first two possibilities before moving forward though. Let me know if this is something you've investigated and can confirm both are OK. As for the grill at the bottom, that has no effect on the operation of the unit, however the panel/cover at the back does...it must be in place. Good luck. Regards, Macmarkus :)
Posted on Mar 31, 2011
  • Mark MacDonald
    Mark MacDonald Mar 31, 2011
    Thanks for the reply. Yes you should unplug the unit before doing any service...safety first.
    You can access the fan from the back only, this will require you to pull the unit out from the cabinets unfortunately and then remove the panel at the bottom which covers the compressor and fan to direct air-flow It (cover) must be put back in place for proper operation.
    As for the condensor coils. They are located under the fridge (looking like a automotive radiator) and the best way to clean them is blowing compressed air through them, though that can be messy.
    I suggest vacuuming them out as best as you can from front and back...the use of a coil brush works well too.
    i.e. part #5303318693
    Careful not to dislodge any wires by the fan or compressor etc. Let me know how it goes when you get around to it. Good luck.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    OK. sounds good. I will be watching for your post.
    Regards,
    Macmarkus :)
  • 17,970 Answers
I heard about this problem in LG models, I know that isn't the brand but could helpfull like clues; apparently the problem is the main control board (in LG models). According to the technician that came out to fix, there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer.
I had done a fair bit of research before calling your technician service, and came to the conclusion that this was a common problem. If you have underwarranty, called.
The service tech also told they that all refridgerators made after 2001 are required (by law), to have an electronic mother board which in all likely hood will fail at some point prior to when you are ready to buy a new fridge.
Hope helps.
  • ZJ Limited
    ZJ Limited Mar 31, 2011
    The kick plate could affected this, not retain cold.
My Kitchenaid refrigerator deli drawer freezes everything, how can I fix this?
Check the air flow vents for ice buildup, this happened with my whirlpool fridge. Hope it helps.
Feb 03, 2015 | KitchenAid Refrigerators
Kitchenaid 25 cu. ft. side by side is freezing food in the refrigerator side(meat drawer and crisper)
Have you checked the temperature setting for the fridge? It may be set too low. There also may be an adjustment on the drawer for the crisper that can be adjusted (typically a slide adjustment.
Dec 05, 2014 | KitchenAid Refrigerators
How do i replace the small post that the crisper drawer rides on ?
you need a different site for this question this is a auto help site.
Sep 05, 2014 | KitchenAid Superba KSRG25FK Side by Side...
Kitchenaid superba refrigerator side at lowest temp setting is not cold enough. Freezer temp is fine.
Check the setting of your vents between sides and open them, sometimes you have to pull out the produce drawer to find the lower one
Jun 23, 2011 | KitchenAid Superba Architect KSCS25INSS...
We have a side by side Kitchenaid Superba Refrigerator. Freezer runs all the time...and does not shut down. Tried turning it off for 5 minutes as well as increasing the freezer temp for 0 to 5 degrees, ...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Mar 30, 2011 | KitchenAid Refrigerators
I am thinking on buying a used refrigerator. It's a KitchenAid Superba black side by side. Water and ice on door. This is the serial #4176358945 I can't locate it anywhere on the kitchenaid site. How...
Good day,
Thoughts on buying a used refrigerator.
1. Can you see the machine running at normal temperatures. That is, the freezer should be at 0 to 4 degrees and the food compartment at 34 to 39 degrees.(You'll need a thermometer) If not, have it corrected or walk away.
2. Does it it cycle on and off. It should be running 30 to 70 percent of the time. If any more than the high number, either have the problem corrected, or walk away.
3. Does it make ice, dispense it, and does the water delivery system work. Although sometimes easily corrected, repairs can become very pricey.
4. Can you transport it without the machine being layed on it's side? This is critical to the compressor.
5. Parts? If you have the model number as well, with both, call any large appliance parts house. Ask if they can order the bottom crisper drawer for the fresh food side. If yes, then your O.K.
Jun 11, 2010 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Apr 04, 2009 | KitchenAid Superba Architect KSCS25IN Side...
The refrigerator section is freezing. the temp adjust is at 1
This could be the actuator is not closing the door that controls how much cold air from the freezer is ciculated into the fresh food section. It could be something broken or there could be ice biuldup on the door itself, not allowing the door to open or close.
Nov 12, 2008 | Refrigerators
Kitchenaid superba refer side by side
its normal for the temperature to stay around 28 degrees farenheight int the bottom drawer. (fresh cut meat keeps better at his temp). you can adj the temp slide near the bottom of the refrig next to the botom drawer to help adj temp. veggies will almost always freeze in the bottom drawer. also adj the temp controls to a little bit warmer to help as well.
Keep in mind the mid point settings on your refrig is just a starting point for you to adj to where it works best for you and your usage..
Dec 17, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
56 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
