Question about Frigidaire Refrigerators
Water not flowingthrough water tube to icemaker
  • 132 Answers
This could be either;
No water supply, tap could be turned off or calcium has built up closing off the tap. Open the tap all the way, close it then open it all the way and then drain some water off.
The water filter could be blocked, change the water filter.
The fridge could be too cold freezing the water in the pipe. Raise the thermostat temperature slightly
Posted on Apr 01, 2011
Whirlpool side by side with water and icemaker. My water works perfectly fine but my ice maker no longer produces ice. It runs but it's not getting any water to make ice. What can be done to fix this?
There are a couple reasons your icemaker will not fill with water.
First thing you want to check for is a frozen fill tube to the icemaker. The easiest way to check for a frozen line is to remove the icemaker. Once the icemaker is removed look for ice in the fill tube. If there is ice in the tube the (water valve) will need to be replaced. You can melt the ice by forcing hot water up the fill tube.
Another reason could be the icemaker is not sending voltage to the water valve. The fix for this issue is to replace the icemaker. Hope this helps you with your whirlpool fridge!
The reason to change the water valve with a frozen water line is because the solenoid is not closing all the way. This allows water to enter the fill tube of the icemaker and freeze based on the temperature.
May 04, 2017 | Whirlpool Refrigerators
My lg refrigerator lsxs26326 is dispensing water but not filling ice tray up. What could be wrong?
the water solenoid valve for the water dispenser is separate from the icemaker water supply solenoid valve . get to the icemaker water supply solenoid and test it if it works alright . unplug the fridge from wall outlet do not close water supply valve. disconnect water tube connection on the water discharge side of the icemaker water supply solenoid valve . pull - out power supply connection of the solenoid coil . connect solenoid valve directly to wall outlet. a faint click should be audible and water should come out from where the tube was removed -- from the water supply discharge side. if no water is coming out with the solenoid plug in , then the solenoid is faulty. but if water comes while solenoid is powered -on , check the position of the icemaker lever. if it is on off position icemaker timer won't activate icemaker water supply valve..move icemaker lever to on and check for water pouring into the icemaker tray' if no water comes out . change the icemaker timer. thanks.
Mar 04, 2016 | LG Refrigerators
Frigidaire icemaker still overflowing after replacing inlet valve
Make sure the water is not splashing out the fill tube rather than the icemaker. Sometimes ice forms in this tube and causes the water to shoot over the tube and run down. You could also try turning the water faucet valve down a bit. Your water pressure could be too high and it is filling too fast. Last thing if you have very hard water the cubs could be sticking in the mold tray and not releasing. When the icemaker fills again there is still ice in ther causing the icemaker to overflow.
May 17, 2014 | Refrigerators
Icemaker is not working
Pour about 2/3 cup of water into the icemaker . If those cubes freeze and dumps but water does not go into the icemaker , replace the water valve behind the refrig ( piece the water line connects to ) . If it does not dump the cubes , replace the icemaker . Also , check the fill tube ( tube which fills the icemaker ) to make sure it is not frozen up . If so , the water valve is seeping and still needs to be replaced . Check the coils under the refrig for dust , lint , pet hair , etc. The coils have to be clean for the icemaker to be 5 degrees , and work properly .
Mar 20, 2011 | Kenmore Refrigerators
Pipe that feeds ice maker is broken. How do I repair and where do
Check the water valve, it might be leaking water slowly into the icemaker tube. Turn off icemaker. Disconnect .25" tubing from the icemaker fill tube in the back of the refrigerator. shake some water off the .25" tubing, mark the current water level on the tubing, then leave it for 5 min or so, and check it again. If the level has risen - replace the water valve. If the level is the same - replace the fill tube, it may have some sediment buildup, which causes the water drops to remain in the tube after the icemaker fillup.
Good luck.
Jun 01, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
The water fill tube for the icemaker is blocked.
Replace the Dual water control valve found on the back of the refrigerator near the floor with a new one and thaw out the entrance where the water goes into the ice maker. Provide a model number found on the inside of the fresh food compartment wall and I'll try to help you find the correct part number for the water control valve. The water control valve is apparently leaking like a leaky faucet and it's freezing causing the problem
Apr 03, 2017 | Whirlpool Refrigerators
Replace selenoid and water is still not going to ice maker
Did you pour about 2/3 cup of water into the icemaker and did it dump ? If you did pour water into the icemaker , and it did not dump the cubes , then the icemaker is bad . If it did dump , so you replaced the water valve , then the fill tube directly at the icemaker is frozen with ice . It will need to be removed ( fill tube at icemaker ) and the ice cleared out by hot water . On some models , behind the refrig , 2 screws hold the fill tube in place . Remove the tube , and clear the ice . When reinstalling , have someone guide it from inside the freezer , to where it mounts on the icemaker fill cup .
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No ice
Pour about 1/2 cup of water into icemaker . If it freezes and dumps , the water valve is bad ( where the wall water line connects to the fridge ) . If it freezes and does not dump and the ice stays in the icemaker , replace the icemaker . Also check the fill tube ( the tube going from the freezer wall to the icemaker itself ) to see if it has frozen closed . If it has , the water valve is not closing completely , and letting a drop thru and freezing in the tube . Also an indication of a bad water valve .
Aug 20, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Not getting water from the plastic valve to the icemaker (Have water from the bottom of frig to the valve) --- any ideas? by the way the thing on the icemaker is flipped down so that is not the solution.
#1 Defective switch or thermal fuse in Icemaker not sending voltage to the valve.
#2 Defective water inlet valve
#3 Frozen fill tube to Icemaker (the tube that goes through the back wall and feeds the icemaker)
Apr 01, 2009 | Refrigerators
No water coming down tube in kenmore ice maker
Hi!!! make sure your icemaker filling tube is not blocked with ice.its where the water comes into the icemaker .it can freez on you.put a hair dryer on to the filling tube and icemaker for 30 minutes. Also you can jump start the icemaker by putting a jumper wire show in this picture .If no ice then go to the back your frig and change your water valve ..
Jan 04, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
49 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
