Question about Mtd Products Yard Machines 158CC Tiller
I have a bolens tiller(5.5)hp runs good when very low on gas but runs very rough and sometimes dies when gas is in tank past one-tenth of tank
4 Suggested Answers
  • 398 Answers
SOURCE: I have a bolens rear tine tiller that will not
is the fuel filter clogged? you may need to check the engine compression for bad valves or rings.if the compresion is off it wont get gas . check the fuel filter first though and keep me posted.
Posted on Apr 24, 2009
  • 15 Answers
SOURCE: Tiller won't stay running
Hmmmm.....it sounds like restricted fuel flow to me, but explain "rebuilt the carb" so I can get an idea on what you did.
Though it sounds right off like you whooped it good and got the basics.
Right off, go back through the "system", check the fuel flow, check that spark on the plug. Eyeball for any loose wires (E.G., Kill Switch, etc.) that are grounding (you never know!)
Stick to KISS on this one, since it ran before the carb got bad and got rebuilt, it will be one of those things you replaced, rebuilt, or changed. Sometimes, it is the SMALLEST thing......
Posted on May 28, 2009
  • 407 Answers
SOURCE: I have an older 5 hp. Mtd tiller Do I have to use
Look on top of the machine.If there is an oil fill then no you do not use mixed fuel if yes it needs engine oil,30 wt.If there is no engine oil fill then you use mixed oil and gas,at a 50:1 ratio.
Posted on May 30, 2011
Low power, runs rough, hard to start.
replace the fuel lines,ethanol kills them,then they leak air
Jul 04, 2015 | Husqvarna 224l Gas Powered Line Trimmer, 4...
95 chevy blazer
It's good that you changed the fuel filter. Was it running OK until you were very low on fuel? It could be dirty injectors. Put a can of fuel system/ injector in the tank, and see if you can run it through the system.
May 26, 2014 | Vehicle Parts & Accessories
Briggs and Stratton engine runs rough but good with low gas
YOU ARE CORRECT. sounds like a simple carb. adjustment, probably too rich of a fuel mixture.
Apr 06, 2013 | Measuring Tools & Sensors
Tiller will not continue to run. It has good spark. It will start if primed through the carburator but once the prime burns off it dies.
If fuel sits in the gas tank 3 months, the fuel deteriorates and it gums up the filter in the tank. You need to put stabil in the tank. This has happened to me over and over. It is best to dump out the gasoline if you don't use the tiller within one month. Some people who use chain saws commercially dump all the gas out every day and start over the next day. The symptoms are the tiller won't run at high speed at first, then as it gums up more
it won't run even at low speed, then becomes hard to start.
The gum is hard to see. Pull out the gas line to get to the filter and change the filter. Filters are only 3 or 4 dollars at hardware stores.
Jun 01, 2012 | Honda 25cc 4-cycle Mini Tiller
Engine dies out
Could be any of several problems. Since you indicate you just bought it, I'd suggest you return it. Troy-Bilt is pretty good at making customers happy and should repair or replace it right away.
Apr 09, 2010 | Troy-Bilt Pony Garden Tiller
1986 F150: Rear gas tank results in engine sputtering/dies
you are going to have to replace the in tank low pressure fuel pump, we call this the "lift" pump.
Oct 06, 2009 | 1986 Ford F150 SuperCab
Was running then died
I would check your oil level first, they have safety stops when oil level is low. Change the oil while you're at it if it hasn't been done for a while, if it still doesn't work, empty the gas in the tank including the one in the carburettor float housing, spray some carburretor cleaner while you're at it, and put fresh gas in the tank.
May 31, 2009 | Ryobi Cultivator
I have a Bolens 6.0 OHV tiller M# 21A-332C163 and S# 1C283K40098. It will start on first pull but only run 2 or 3 mintues then quites. You then have to choke it to restart it then again it will only run...
Has it sat with gas in it ? if so carburetor needs cleaned,The other thing could be water in gas look in tank for something that looks like a bubble floating in bottom of tank if you see one its water you remove tank clean out then if carburetor has bowl you must remove carburetor bowl clean out water.
May 04, 2009 | Garden
I have a bolens rear tine tiller that will not run. The carborator has been completely cleaned, new gas, new spark plug, new oil, and new gaskets. It seems like it is not getting gas from the tank. Will...
Apr 23, 2009 | Mtd Products Yard Machines 158CC Tiller
Maxim tiller won't run
Try better quality gas. I had the same problem. Ethanol too high in lower grade gas. Buy better grade or ethanol free. Mine works fine with better gas.
Apr 06, 2009 | Maxim Garden
Mtd Products  Yard Machines  158CC Tiller Logo
137 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
