Question about Texas Instruments TI-83 Plus Calculator
My TI-83 Plus started acting wierd I removed the batteries and checked them all are good, now it will not turn on at all. So now what do I do?
    Problem Solver:
  • 12 Answers
Try fresh name brand batteries and make sure they are in the correct orientation as indicated by the graphics under the battery cover.
Posted on Mar 31, 2011
HELP! ACT Emergency!
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect first.
1. Try a new set of AAA batteries.
2. Adjust the contrast by pressing and releasing the 2nd key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
3. Remove one of the AAA batteries. Press and hold the CLEAR key. While holding CLEAR, reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the CLEAR key and then press it one more time to remove the message.
4. Remove one of the AAA batteries. Press and hold the DEL key. While holding DEL reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Jun 08, 2013 | Texas Instruments TI-85 Calculator
TI-83 Plus "waiting ...please install message then "error message
Please Install Calculator Software Now error
This message means that the operating system has been corrupted. These steps will allow you to update the OS.
Unit to Unit
• Connect two TI-83 Plus units by means of the data cable (short black cable that was prepackaged with the TI-83 Plus)
• Make sure that at least one of the TI-83 Pluses contains the current Operating System
• Select [2nd] Link
• Select "Send OS" option from the Link menu
• Make sure that the other unit still reads "Waiting Please Install"
• The OS should be downloading.
From the Computer
• Make sure you have the latest version of the TI Connect™ Software
• Download the latest version of OS for the TI-83 Plus to the desktop of the PC.
• Connect the appropriate TI-GRAPH LINK™ cable between the PC and TI-83 Plus.
• Since the TI-83 Plus is currently off, the TI-83 Plus will automatically turn on when the TI-GRAPH LINK Cable is inserted.
• On your computer, choose Start, Programs, TI Tools, TI Connect, TI OS Downloader.
Dec 10, 2007 | Texas Instruments TI-83 Plus Calculator
I get black "lines" going across the screen when i hit the graph button. It will graph also,but you can barely see the graph. Help pleae.
Jun 04, 2013 | Texas Instruments TI-83 Plus Calculator
I haven't used the calculator in a long time(TI 83 plus) and I put in a new set of batteries. The old ones that were in left some battery acid, but not much. The calculator doesn't want to turn on. It's a...
hi adamsukienni,
Clean the battery damage up real good. Gently scrape to terminals of corrosion. Back in my day we use to put a little bit of coke cola to clean car battery posts to get a good connection. If you could put a little bit of coke on a Q-tip without getting any inside the calculator that would be good. Just let it soak in for about 30 minutes. And gently scrape the bad areas again clean of the corrosion. You have to clean it up to metal so, that when the battery is in it will be metal to metal connection.
If you can download new OS with another Ti83 Plus or, don't want to install the new OS goto Procedure 1.
Be ready to install the new ti 83 OS v.1.19. So, setup your computer with Ti Connect software and, have the new OS v.1.19 download ready and, in "My Documents \ My TI Data \ Downloads." If you need additional instructions on how to connect the computer to the calculator you can read my instructions at another posting I did. You can go to that posting by clicking, "Connection Instructions," under this paragraph. Just remember the OS was for a Ti 84 Plus and, your's is a Ti 83 Plus so, don't download the OS from the other posting. I'll give you a link below this paragraph to download the correct Ti 83 Plus OS v1.19 for your calculator here at your posting. Just follow the other posting to where I say, "You can also go back and, download the Ti 84 Plus guidebook too, if needed." After that statement the computer and, calculator get connected with the cable and, your not ready for that process, yet! When you come back to this posting and you have downloaded the new OS to the proper folder goto Procedure 1.
Additional computer to calculator connection instructions click, "Connection Instructions."
Ti 83 Plus OS v.1.19 download click, "Ti 83 Plus OS v.1.19". Save this download to "My Documents \ My TI Data \ Downloads".
Procedure 1.
Take all the batteries out for 10 minutes, including the very small one that you have to use a small philips screw driver to get it out. Watch out for the spring under the small battery, it might pop out. Replace all the batteries after 10 minutes with new ones, including buying a new small battery. The small one might cost about $5. I know it is expensive but, this might work.
A battery reset procedure should bring your Ti 83 Plus back to life.
Make sure the batteries are in correctly? The batteries alternate negative/positive, positive/ negative and so on. The first time I put the batteries in, I didn't have them in correctly. I know if it happen to me that anybody could make the same mistake. And of course, the calculator will never come on if the batteries aren't in correctly.
If your Ti 83 Plus turns on when you put the batteries back in you do not have to re-install the OS. I just think it is better since, your OS might be corrupt.
The process below should reset your calculator.
1). Pressing the [2nd] key followed by pressing and releasing the [Up Arrow] key. This adjust the contrast in case the contrast was to low. Keep repeating if necessary for about 10 seconds and, then go to the next step. If calculator comes on and responds to key functions your done. Once again, if your calculator turns on after this procedure you do not have to re-install the new OS. You can quit these procedures now with a perfectly good calculator.
Please be prepared to re-install the calculator's OS, if you run through this process.
2). Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
"Waiting...Please install calculator software now". Connect to other Ti 83 Plus and, install OS from that calculator. Or, follow the instructions, I gave at the other posting "Connection Instructions" to reinstall the calculator operating system and, connect the computer and, calculator. You can start where, I say, "Link your computer and, Ti 84 Plus (Your's is a Ti 83 Plus) with the proper cable (USB or Black Link). Upon completion your Ti 83 Plus will be ready to use and, the new OS installed.
Jan 18, 2011 | Texas Instruments TI-83 Plus Calculator
My ti 83 will turn on when i press the clear thing but when i try to put something in nothing happens
Hi imagenius1,
You need to free up some memory. Try clearing your RAM memory. Your calculator should operate properly afterward.
Press [2nd] [MEM] [7] [1] [2]
If the steps above did not reset the memory to your Ti 83 family calculator try the procedures below.
Please be prepared to re-install the calculator's OS if you run through this process.
If you have a straight Ti 83 without the Plus or, Silver Edition label goto (Procedure 2) below. If your Ti calculator is a Ti 83 Plus or better goto (Procedure 1).
(Procedure 1).
  2. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and, then press [CLEAR] one more time to remove the message.
  1. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  2. Steps to re-installing the operating system:
    ~Connect the TI Connectivity cable between the PC and the calculator.
    ~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
    ~Follow the on-screen directions to reinstall the calculator's OS. If you could not install the new OS on your calculator goto step 4.
  3. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
  4. If the above process did not reset your calculator. Try re-doing (Procedure 1) and, extend the time in step 4, by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
(Procedure 2).
For a straight Ti 83 without the Plus or, Silver Edition label try the procedure below.
  2. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the AAA battery and then turn the calculator on.
Jan 06, 2011 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus ram cleared message when turned on
It calculator tells you Ram Cleared each time you turn it on, the most likely reason is that the backup battery is depleted. Its role is to keep the memory modules electrically refreshed when calculator is turned off. If the backup battery is dead, the memory is erased when you turn calculator OFF. Main batteries no longer supply power and the contents of the memory are cleared.
  1. Check that main batteries are good and inserted in calculator.
  2. Turn calculator OFF.
  3. Replace the backup battery.
  4. Turn calculator ON.
  5. Press the [CLEAR] key to erase the "Ram Cleared" message.
Jan 19, 2010 | Texas Instruments TI-83 Plus Calculator
Texas instruments TI-83 Plus won't turn on. I have replaced the AAA batteries.
Check that the batteries are correctly inserted.
The screen may be too light to see anything.
To darken it
Press [2nd] key and release it.
Press and HOLD [UpArrow] till it darkens enough.
If that does not solve the problem here is what the TI Knowledge base has to say. Please read till the end. I hope it helps.
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83-family or Ti84 Plus family to reinstall the calculator operating system (see below.)
  5. Remove all of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Reinstalling the OS fot the TI84Plus
How do I correct the Error Waiting...Please Install Calculator SoftwareNow message on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating the operating system on a calculator with low batteries. Users will need to use the TI Connectivity cable and the TI Connect to send the operating system to the calculator. Make sure to have the latest version of TI Connect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
If the message "Error! Press any key to turn unit off. Then turn unit back on." appears on the graphing calculator, quickly, remove one battery from the calculator and reinstall it while the transfer is taking place.
If that does not solve the problem, you should contact Texas Instruments at ti-cares@ti.com or www.ti.com/calc.
Nov 09, 2009 | Texas Instruments TI-83 Plus Calculator
My TI-83 Plus Calculator will not turn on
This is from TI FAQS:
Solution 11900: Troubleshooting a TI Graphing Calculator That Will Not Turn On.
  2. Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
Aug 06, 2009 | Texas Instruments TI-83 Plus Calculator
RAM Cleared
This is kinda a weird situation. Because it's usually the other way around. Your ram will clear if your calculator is frozen. So take out all 5 batteries from the back. Even the back up battery. Then reset it again. 2nd then + then 7 then 1 Then 2. Good luck.
Oct 22, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
42 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
