Question about Britax Advantage
Can I get an extension for the latch between the legs
  • 48 Answers
You can contact the manufacture, many do have them. Or search online, just make sure that the part you buy is for the brand seat you have or else it may not be safe, that why it is best to go through the manufacture.
Posted on Aug 06, 2008
We folded the Proform 500 LE Elliptical and moved it. Now we are unable to unfold the elliptical with the latch button. Suggestions?
HOW TO FOLD AND UNFOLD THE ELLIPTICAL
When the elliptical is not in use, the frame can be folded out of the way. First, lift the latch under each pedal arm, and lift the pedal arms off the adjustment sleeves on the crank arms.
Next, raise the pedal arms until they touch the magnets on the upper body legs; the magnets will hold the pedal arms in place.
Then, hold the handle and lift the frame until it locks in a vertical position. To use the elliptical, first hold the handle, press the latch button, and lower the frame.
Next, pull the pedal arms off the magnets on the upper body legs.
Then, lift the latches under the pedal arms, and set the pedal arms on the adjustment sleeves on the crank arms.
Release the latches, and make sure that the pedal arms are securely connected to the adjustment sleeves.
Will be attaching a link to your manual also
http://www.sportsmith.net/images/product_support/ProForm/PFEVEL959101%20-%20PROFORM%20500%20ZLE%20ELLIPTICAL/PFEVEL95910.1-307585.pdf
May 25, 2015 | Proform Exercise & Fitness
Door won't stay latched on dishwasher
Make sure nothing is binding the racks which could be pressing against the door when closed. Also make sure the dishwasher isn't installed too tightly in its place, which puts pressure on the latch. You may need to lower the leveling legs a bit.
Oct 24, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
How to i fold it into the space saver option
Make sure the incline is at its lowest point 1. Hold the treadmill with your hands on each side of the frame at back of treadmill To decrease the possibility of injury, bend your legs and keep your back straight. As you raise the treadmill, make sure to lift with your legs rather than your back. Raise the treadmill about halfway to the vertical position. 2. Move your right hand to hold the treadmill firmly in the upright position. Using your left hand, pull the latch knob to the left and hold it. Raise the treadmill until the latch pin is aligned with the hole in the catch. Insert the latch pin into the catch. Make sure that the latch pin is fully inserted into the catch.
May 31, 2010 | Proform Pro Series 1500 Treadmill
One of the leg latches cracked making tripod unusable
Try www.BogenTripodParts.com for that part. There is listed the widest selection of Bogen parts and support more models than any other web site I’ve seen. There are losts of pictures to help find just the right part.
May 19, 2010 | Manfrotto Digi 728B Tripod
Vanguard VT-114 (1993) tripod broken leg latches
Call Vanguard. They're sending me the lower latch and a foot free.
Nov 16, 2009 | Vanguard International VT-128 Tripod
Tud6710sb whirlpool dishwasher need to hold and push the door to make it work
You should be able to adjust the latch so that the door latches and you dont need to hold and push to make it work
Jun 12, 2009 | Estate TUD6710 Built-in Dishwasher
Does the buckle between their legs come out?
Mine, I have to remove the base first and then you can remove the strap and move it to another slot, or to clean
May 19, 2009 | Eddie Bauer 3-In-1 with Latch
How do you fold the Exersaucer Smart Steps?
Onthe bottom of the legs, there is a thumb latch, press that all the way down into the hold it is in. do this on all three legs.
Then once that is done turn the whole thing to the left, it should fold in two, on the sides, there are three latchs that go into the hole next to the small legs, those latches secure it in place..... The thumb laches can be hard just so you know
To unfold, simply press on the holding latches, and pull up
Jan 03, 2009 | Evenflo ExerSaucer SmartSteps ABC Stroller
Need directions on how to fold legs
Hi, I can fix this.
First, on the bottom of the legs, there is a thumb latch, press that all the way down into the hold it is in. do this on all three legs.
To unfold, simply press on the holding latches, and pull up.
Good Luck.
Gordon & Shirley
Nov 17, 2008 | Evenflo ExerSaucer SmartSteps ABC Stroller
VGB3 leg lock broke
On the velbon vgb 3, the leg locks consist of a lever, one or two pieces of metal and a plastic piece. The metal and plastic pieces rest in a depression against the lever. When the lever is pulled out, pressure against the smaller leg section is released. When the lever is pushed in, pressure against the smaller leg section is exerted, locking the legs in place. On the back side of each joint, there is a phillips head screw which acts as a stop to keep the leg section from coming all the way out. When the screw is backed out, the leg section can be removed, exposing the latching mechanism. If the only problem is that the latch mechanism came apart, it can simply be reassembled. If, however, something broke and allowed the latch assemby to come apart, that will have to be dealt with as well. My guess is that the phillips screw may have become loose, and the latch came apart.
Aug 14, 2006 | Velbon Chaser EFL-4 (A) Tripod
Britax Advantage Logo
52 people viewed this question
Top Britax Baby Gear Experts
CheckitRight
CheckitRight
Jennifer Rock
Jennifer Rock
Iron
Iron
Are you a Britax Baby Gear Expert? Answer questions, earn points and help others
