Question about Kenmore Elite Trio 7855 (25 cu. ft.) Bottom Freezer French Door Refrigerator
Freezer still working. Refrigerator not cooling. Hot to top on inside of left hand door as you face refrigerator
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 01, 2011
KENMORE TRIO 2004 59675523400 REEFER/FREEZER NOT COOLING
it should not be the compressor as the bottom is only not cooling.
Jun 23, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
A bar in the middle, when two doors are opened, is really hot. and cold storage is not working vey well. please help.
IIRC your refrigerator has an electronic control in the front face of the freezer door. Both sides have 3 buttons in a vertical column. On the left side (standing facing the closed door) the center button is labeled "freeze". Each time you push it the number of horizontal green bars changes. The bars increase in count to the top/maximum, then start over at the bottom with a single bar. This is your freezer setting indicator (the fridge works the same way). The more bars the colder the setting is. Note that if you set the freezer bars too high (IE set the freezer too cold) then the "waterway" heater will come on and stay on to prevent the waterway inside the door itself from freezing up. This heater is wired such that when it comes on so does the "home-bar" (which touches both of the doors when closed) heater, which will also stay on.
Aug 15, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
Top refrigerator not ccoling and bottom freezer
check the condenser temperature when the compressor is running by hand it must be warm or hot if it is not then that means no refrigerant left in the system.This can be a possible cause.
Sep 27, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer works, refrigerator does not cool
Often the cooling section is located in the freezer and their is a hidden fan that blows the cold air into the lower section. If the fan quits working the refrigiator section wil not be cool.
Jun 19, 2009 | Refrigerators
Kitchenaid KSRA25IL Freezer working Fine - Refrigerator not
many times when a unit has a defrost problem the coils freeze up and do not allow the fresh food side to cool properly...check for a build up of ice on the inside back wall of the freezer compartment. if there is a build up of ice, you have a defrost problem. Also, check to make sure the evaporator fan in the freezer is blowing the air into the fresh food side.
Dec 26, 2008 | KitchenAid KSRS25IL Side by Side...
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Kenmore Elite Trio 7855 (25 cu. ft.) Bottom Freezer French Door Refrigerator Logo
336 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
