Question about Kwikset Locks & Locksmithing
I have a kwickstet smartcode touchpad keyless entry. When I push the lock button it opens and when I do the code it locks?
It may be confused with the Hand side. You probably did not follow the procedures, who does , right?. Anyways you can get it to learn the Hand side of the lock by following the following procedure: 1. Remove the battery module, extend the lock mechanism as if to lock the door using the key, then hold the lock button on the outside keyboard, place the battery set back in and keep holding the lock button for 30 sec. The software will then drive the lock back and forth to figure out which way it is mounted and it should work correctly after that. That is how the procedure instructs us to do it, but even myself read to do a little bit of reading to make sure I figured out how it did seem to be setup to work on the opposite hand side. It took a leap of faith to trust the procedure and voila, it figured out the right way to lock and unlock.
Posted on Dec 08, 2012
  • 963 Answers
I have included a link to the installation instructions for the Kwikset 909 lock. I think that if you go through the installation instruction routine carefully, you will solve your problem. Pay particular attention to Step 8, the synchronization routine.
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
Posted on Apr 18, 2011
How do I enter new code?
[PDF]Quick Reference Installation & Programming Manual
www.weiserlock.com/.../electronics/smart...
Translate this page Weiser Lock25605-02 Weiser SmartCode Manual. Program. Button .... Press and hold the "LOCK" button on the exterior keypad, while fully inserting the battery pack into .... anyone withaccess to the power board can change these codes, you must restrict access ...technical means, or evaded by entry elsewhere on the property. No lock.
Nov 26, 2015 | Weiser Lock Locks & Locksmithing
Need a video how to program my keyless entry deadbolt lock
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
Oct 20, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
My keypad won't light up when door is locked whe you push lock won't light up green
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Good luck--and please provide feedback if this helps!
Aug 04, 2011 | Kwikset 909 909-L03 Lifetime Polished...
How do i get the smartlock to relock on its own without having to push the lock button
For reference, here is a link to the installation guide:
Under Step 11, you will see that if you change the switch position of the second switch (of 4) internal to the lock to the ON position, it will enable auto-lock of the door 30 seconds after unlock.
Hope this helps!
Jul 19, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
How do i change the entry code on my Kwikset 909 keyless lock? Just bought the house and want to made a code number of MY choosing. Thanks.
slide the cover off the interior of the door. you will see a program button. you can program two individual codes. to program the first code, press the program button once, then enter your code on the exterior keypad and press the lock button. for the second code you would press the program button twice, then enter the code and press the lock button.
Jan 23, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
We have a kwikset keyless entry lock and need to reset it.
Try searching the type of kwikset lock from this page:
http://www.kwikset.com/Customer-Support/Product-FAQs/Search-Faq.aspx?prod=FAQ+Categories_Keyless+Entry
Jan 22, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
To unlock the bolt no code is needed... just by pushing the lock button it unlocks what do i have to do to make it function proporly
You need to reset the lock, so it will be set to the correct handing (left or right hand door).
Open the door and extend the lock bolt. Remove the battery. Press the reset button three times and wait 20 seconds. Push and hold the lock button, while inserting the batteries. Hold the lock button until the bolt starts to move. Allow the lock to complete it's learning cycle.
Program a new code and test.
Jan 09, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
The backlights on our Kwikset 909 are not lit. Is this controlled by one of the switches or could something not be installed correctly?
Dec 17, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
How do i change the code in my kwikset 909 keyless entry
un screw the back cover located on the inside of the door , unscrew the two srewa inside that holds the front key pad , when it is removed you will find is has couled tags inside that are placed on regired key numbers for entry good luck
Nov 29, 2009 | Kwikset 909 909-15 Satin Nickel Smart...
I just installed a Smartcode Deadbolt and I follow the directions but I cant program a code and it trys to lock itself every 30 seconds. what do i do
On the back of the unit slide the cover off and push the 2nd switch (on the contorl panel of four switches) down.
To program the code, push the black button once and enter a 4 to 8 digit code, then press the middle lock button. To set a secondary code, press the black button twice, enter 4 to 8 digit code and press the lock button.
This should all be self explanitory in the instruction manual.
I have one of these on my front door and its fantastic. I carry a key but have not used it in months. Bravo Kwikset, Bravo!
Aug 14, 2009 | Kwikset 909 909-15 Satin Nickel Smart...
Locks & Locksmithing Logo
374 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
Steve Masymas
Level 1 Expert
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
