Question about Toshiba Computers & Internet
I was using my laptop in office. i went outside for about 20 mintes, as such, when i got back the laptop had gone into sleep mode. i moved the mouse cursor and pressed the keys to awake it, but of no use. then i swtiched it off, removed the battry but of no use. now when i swtich it on, it gives a verrrrrrry dim display, hardly visible. it is a new laptop
  • 61 Answers
Hi there no not a new laptop just a new inverter...quite simple to fit and not very costly.;....just get the make and model of your laptop then search on ebay..should cost you anywhere between £20-40 for a new 1 and about 30min to 1hr fix depending if you have any experience..
Hope this helps
Posted on Mar 31, 2011
Monitor has gone to power saving mode
Hello, The reason your monitor switched to power saving mode is because the operating system on your computer told it to. A computer left on and unattended is programed to sleep/hibernate after usually a short period of time. Without going to in depth, There are stages of sleep and after time the hibernation deepens. However, moving the mouse or pressing a key should take it out of sleep. Microsoft has a support page for this issue: http://support.microsoft.com/kb/266283 Good Day
Feb 12, 2014 | LG Flatron W2242TQ-BF 22" LCD Monitor -...
HP DC7800 doesn't wake up
Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity The computer will power-down and turn off unnecessary systems, including the monitor, while keeping the memory active so it can start back up quickly and still have all programs up that were being used prior to entering sleep mode. While this is a helpful feature that can extend the battery life of a laptop, it can result in errors where the computer won't power back up. You can usually solve the problem quickly.
Look for a sleep-specific key on the keyboard. It will usually be near the top row and have a symbol of a moon on it. Press this key as some laptops only respond to that command to come out of sleep mode. Press the "Enter" key to see if that will cause the computer to respond. Move the mouse back and forth several times and click the mouse button. Hold down the power button for 5 seconds if the previous methods have not worked. This is another common method for exiting sleep mode for many laptops. It may also trigger a full computer restart which would also solve the sleep mode problem. Unplug the laptop and remove its battery.
Reinsert the battery and then plug the laptop back in.
This should cause a full restart when the power button is pressed. Download the latest video drivers from the website for your video card manufacturer. Old drivers can sometimes cause problems with the laptop's power functions. See if your computer manufacturer has an updated BIOS on its website. The BIOS (basic input/output system) is the firmware that controls the initial boot processes for your laptop. Computer companies will release updated BIOS firmware if they get multiple complaints of boot or power problems. The BIOS interfering with Windows Power Manager is a frequent cause of sleep mode problems. Adjust your BIOS settings by rebooting the computer and pressing the appropriate function key when prompted on start up. It will normally be F1, F2 or F3, and you will often see a message during start up saying to press that key to enter the BIOS. Experiment with the BIOS settings by scrolling through the menu and locating Power Management. Increase the amount of time the BIOS allows before hibernating to make sure it is higher than the the Windows power setting. This can help eliminate conflicts between the BIOS and Windows concerning power shutdowns.
Jan 28, 2013 | Computers & Internet
How to wake msi u130 from sleeping?tnx
If it is in sleep pressing any key or moving the mouse will generally wake it up. If you left the computer unplugged in sleep mode then it most likely ran out of power. If your using hibernate I would recommend not using it as it has so many issues.... :) If you have to hit the power button to wake it up then it's either shutdown or in hibernate. FYI there will generally be an amber light on to indicate sleep mode. If no lights it's most likely not in sleep mode.
Comment if you need additional assistance.
Aug 24, 2011 | Acer Aspire One Netbook 8.9" Notebook
I was surfing the web, left the room for a few minutes and came back to a blank screen. My remote mouse wouldn't work, I couldn't get it to react by wiggling the laptop mouse or hitting keypads. Two lights...
Your laptop went into sleep mode/hibernate. In many cases windows could not recover from these situations. One solution is to update the BIOS of your laptop on the acer website. Easy way to fix it is setting your power options under control panel. You can configure the settings here if your pc is idle to prevent sleep mode or hibernate.
Sep 08, 2010 | ASUS Computers & Internet
My dell inspiron E1405 screen turns off by itself it turns on fine but after a couple min. The screen turns off but the laptop is still on
Its going to sleep mode after 5 mins or going to standby if you are not working on it. you can on it by moving mouse or pressing any key on keyboard if it gone to sleep mode .You can press power button to make it on if its gone to standby. To disable this Right click on any empty space on desktop and go to screen saver tab and click on Power button . There in Power Scheme tab , make all options to NEVER and press Apply and OK.Now it will work fine. Options are turnoff monitor, turn off hard disk , System standby , system hibernates etc
Feb 17, 2010 | Dell Inspiron E1405 Notebook
Laptop went into sleep mode and will not turn back on
Try a Hard Reset, follow the steps below:
1) Unplug the AC Adapter from the notebook PC and remove from any port replicator or docking station.
2) Remove the battery from the notebook battery compartment
3) Press and hold the power button for about 20 seconds
NOTE: Holding down the power button while the computer is turned off drains any residual charge in the capacitors
4) Insert battery and plug the AC Adapter back into the notebook PC.
5) Press the power button to turn the notebook PC back on.
Dec 28, 2009 | HP G60-120US Laptop
How do I wake up my laptop from sleep mode?
To get out of sleep mode you should hit any key, move the mouse, open the lcd. To go into sleep Fn+F4
Jan 28, 2009 | Acer Aspire 3680 Laptop
Acer 5101 sleep mode
Go to the "Control Panel" and select the "Power" settings button...you can adjust the sleep settings from there
Jan 24, 2009 | Acer Aspire 5101WLMi Notebook
Pc stuck in sleep mode...
You will need to replace the hard drive which has any version of windows operating system, or you will have to re-install windows xp on that computer. Assuming if the computer has a green light and monitor has an orange light. I've encountered this problem where I work at.
Nov 06, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Computers & Internet Logo
37 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
