Question about HP Office Equipment & Supplies
I've got this HP Color LaserJet CP3525dn on the bench with this 13.1C Fuser Wrap error. The fuser has been replaced, the firmware is up to date, it has been cold reset, the cartridges are brand new originals but it still gives this error. When you print a config page the first page will jam in the fuser. It is not wrapped around the rollers but it is creased as though it is about to wrap. It looks like the fuser stops and the paper momentarily is still feeding so gived this slight crease. When you remove this first page, open and close the cover for the printer to resume, it will clear the paper path by feeding the next sheet straight through the printer unimpeded. I have been told that this is a known error in this machine when using compatible cartridges, and this printer did have compatible cartridges when this issue started, but it has originals now and a new fuser but it still gives this fuser wrap error.
  • David Maidment Apr 01, 2011
    If you cannot be helpful it's better you **** out, buddy.
Soulvisitor
  • 1113 Answers
SOURCE: printer is putting a crease in the middle of the paper
You need to have the fuser replaced, it comes out easy on these back cover just pulls off, and there is two tabs or long silver screws to undo fuser, remove it anf you will see that upper roller is worn, buy a maintence kit for this model which includes fuser and fit it yourself easy done instructions are included with kit.
Posted on Dec 01, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Printed paper is creased
First thing to check is try it with a fresh unopened ream of quality paper, paper with too much moisture content, drys out and goes wavy when it runs threw the fuser roller at rear (180 deg), otherwise it will be the fuser rollers themselves causing your problem, which means that you need to replace fuser assy
Posted on Dec 05, 2007
SOURCE: paper has creases or is crinkled
We have had it worked on 2 or 3 times in the last six months and it is still doing the same thing.
Posted on Aug 26, 2008
  • 990 Answers
SOURCE: HP Laserjet 1300 paper creasing on printing
change toner cartridge will be OK!
Posted on Dec 16, 2008
  • 43 Answers
SOURCE: Paper Jam - ADF
Open ADF cover
Lift up Pickup roller Assy
remove spring from pickup roller assy
Remove pickup roller assy gently pull it towards you
Carefully remove green plastic diverter
note this is held in place by 4 plastic pins 2 on each side
look in the opening for foreign objects.
( I have found labels, money, paperclips, plastic pieces,jammed paper in this area)
Posted on Jan 23, 2009
Hp color laserjet 5500 error 59 ck printer error
list of error codes
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP COLOR LASER PRINTERS 4600, 5500 ERROR 59.3, 59.4 1. A fuser motor error. 2. Replace the fuser drive assembly. 3. Replace the D.C. controller board.
Jan 04, 2017 | HP Office Equipment & Supplies
How to reset fuser error in hp color laserjet 4650
Fuser faulty,we cannot reset the error message in til replacing the fuser..
Oct 21, 2011 | HP LaserJet 4650 Color Printer
I keep getting a "replace fuser kit" message on my
If you replaced with new fuser even getting same error, then check,
>Check the fuser connector (J5001). If
it is broken or damaged, replace it.
>. Check the connector (J1025) on the
DC controller PCB.
>. Replace the DC controller PCB.
Oct 07, 2011 | HP LaserJet 4700 Printer
Cp3525dn prints only blank pages new black
Page is blank.
The high-voltage powersupply lower is defective (no developing bias output).
Replace the high-voltage powersupply lower.
Jul 12, 2011 | HP CP3525N Color LaserJet Printer
My hp color Laserjet cp3525dn displayed error 55.50. Resend upgrade.
I couldn't find an error code of 55.50 in the service manual.
All 55.xx errors are DC Controller problems.
I did find the message "resend upgrade".
That refers to a Firmware upgrade that didn't complete successfully.
If that's what happened in your case...restart the upgrade and keep away from the printer
until the upgrade finishes.
Jun 28, 2011 | HP CP3525DN Color LaserJet Printer
Dont know. What is a 50.7 Fuser Error?
Caused by a defective sensor in the fuser.
Fuser is going to have to be replaced.
I am getting 50.1 fuser error on my printer cp3505n any advise
50.1 is 'low fuser temperature'
I'm assuming that you haven't been messing around with the fuser.
The book says to upgrade the DC Controller firmware.
If that doesn't work, replace the DC Controller
Go to www.hp.com/#support to find your printer and its downloads
Jan 30, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
User error
FUSER ERROR:
. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board.
Mar 27, 2009 | HP Color LaserJet 5550hdn Printer
Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
Dec 05, 2007 | HP Color LaserJet 2600n Printer
80 people viewed this question
Seeker5211
Seeker5211
