Question about HP Photosmart C8180 InkJet Printer
Ink system failure with error code "0xc18a0501" on my HP Photosmart C8180. . How do I handle? I have turned power off and then back on twice. No result. Please convince me C8180 is not a piece of junk. Many thanks. Ed
SOURCE: Manual C8180
Basics Guide:
http://h10032.www1.hp.com/ctg/Manual/c01179724.pdf
User Guide:
http://h10032.www1.hp.com/ctg/Manual/c01178488.pdf
Setup Guide:
http://h10032.www1.hp.com/ctg/Manual/c01179426.pdf
Posted on Dec 11, 2008
SOURCE: Ink System Failure
did a master reset. Unplug the printer, then pressing the help and ok buttons simultaneously plug it back in. it will recalibrate and ask to replace almost all of the ink cartridges, however Unplugging the printer, while then pressing the help and ok buttons simultaneously plug it back in did fix it and I am able to print again. Thank you soo soo soo much.
Posted on May 21, 2009
  • 1684 Answers
SOURCE: Ink System Failure: Errow:Oxc18a001 with a HP C7280
Check our web site at: www.ccl-la.com/hp.htm We have a step by step guide to correct this problem. This error is caused by air in the ink feed tubes and the guide will help you do a purge on the lines.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Aug 19, 2009
Testimonial: "Thanks a million!!!!. Saved the day. Instructions were on point... Reply was timely. THANKS."
SOURCE: Ink System Failure with error code: 0xc05d1281
I had the same problem and took Guru NinaE advice....1. Unplug power cord from back of printer while it is on. 2. Wait for 60 seconds after it is in sleep mode. 3. Press and hold "Print Photos" and "Red Eye Removal" at the same time and while holding the two buttons down, plug in the power cord into the back of the printer. 4. The printer display should go blank or Reset might show up on the display. When this happens, touch the ON button and the printer will reset itself.
Posted on Sep 15, 2009
rulds2008
  • 3866 Answers
SOURCE: can't print on Photosmart 3110 all in one
This is a result in a print head failure or the use of non HP ink ether or there right you need to service the unit part will be needed if the maintance does fail. If your using non HP ink stop its use and purchase HP ink you be glad you did!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Nov 17, 2009
How do I fix ink system failure error message on a hp photosmart c8180 even though I have replaced all cartridges. Need to rest the system any ideas?
i love google.... usually:
http://h30434.www3.hp.com/t5/Other-Printing-Questions/Photosmart-C8180-Ink-System-Failure-Error-0xc-18a0005/td-p/331285
If you need further help, I’m available over the phone at https://www.6ya.com/expert/robert_beef7390c57fac0d
Jun 24, 2014 | United Stationers HP Photosmart C8180...
Tip
Ink System Failure 0xc18a0501 For HP C8180
NVM Reset : 1. Unplug the power cord from the back of the HP All-in-One.
2. Wait for the unit to go to the sleep mode. Wait for 60 seconds.
3. Press and hold Print Photos & Photo Fix
buttons simultaneously on the control panel; keep them pressed and reconnect the power cord to the All-in-One.
4. Continue pressing the buttons until the display goes blank or Reset shows on the control panel display.
Worked for me.
on Jun 14, 2010 | Office Equipment & Supplies
Error:0xc18a0501 on HP Photosmart 3210
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 31, 2010 | HP Photosmart 3210 All-In-One InkJet...
Can't print on Photosmart 3110 all in one
Nov 17, 2009 | HP Photosmart 3310 Printer
1. Try to remove and reinstall the Ink Catridges. Be sure it is lock in place on the ink cartridge holder.
2. Turn off the Printer and unplug and replug the power adapter.
3. Uninstall and reinstall the printer driver.
Sep 24, 2009 | HP Office Equipment & Supplies
HP Phototsmart C8180 Ink system failure
The printer should have its own ON/OFF switch (or button).
Always use that control to turn-off the printer.
The printer reacts to the 'OFF' signal by properly shutting itself down, and then cutting the power to itself.
Sep 14, 2009 | HP Photosmart C8180 InkJet Printer
HP Photosmart C8180 - Ink System Failure - Oxc18a0101
i had exactly this error message. Rang HP. They said it was a hardware failure, they couldn't fix over phone, would cost 2x cost of new printer to fix, but they offered me 20% discount on new printer if ordered over the phone.
But with some fiddling, problem now resolved. Here's what I did:
- press Red Eye Removal and Print Photos button together
- goes to Mfg Commands -> Enter Special Keys Combo. Press OK
- uaiux Support page (some code) -> click right arrow key until you get to System Configuration Menu - click oK
- should say hardware failure status - click OK
- says hardware failure status: Clear. Press OK to clear
- I clicked OK on this and system reset itself and problem was solved
Jun 24, 2009 | HP Photosmart C8180 InkJet Printer
May 20, 2009 | HP Photosmart C8180 InkJet Printer
PRINTER NOT ABLE TO PRINT
These error codes indicate that the product has an internal condition. Solution one: Reset the product Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Oct 23, 2008 | HP Photosmart C8180 All-in-One InkJet...
HP Photosmart C8180 InkJet Printer Logo
77 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
