Question about Mitsubishi Televison & Video
Mitsubishi VCR Model HS-M1000(B) has no fluorescent display with cassette stuck inside unable to eject.
  • Mitsubishi Master
  • 6,993 Answers
when you say no fluorescent display, does this means the screen display of the player is blank? If the screen is blank, are you sure the player is turned on? Because if the player is not turned on, then there is no way the player is going the eject the cassette.
There are two things involved, it is either the player is having a power problem or the tape has coiled inside the player. This can cause the cassette not to eject.
So you can turn off the player, remove it from the wall, get a screw driver, open the player and check if the cassette it coiled inside. After that, turn on the player and see if the cassette is going to move or make any noise.
If it doesn't make any noise, then know that your player is having a power problem.
Keep me posted and let me know the out come.
Good luck.
Posted on Mar 31, 2011
Mitsubishi hs-u62 vcr cassette will not eject
Needz fresh belts. You can order common o-ringz uv the same length that will work fine, but usually not az long.
Apr 19, 2015 | Mitsubishi Televison & Video
Mitsubishi VCR Model HS-821V Ejects Video Cassette & gives an error code E4
Sometimes things like that are caused by the mode switch which will either need to be cleaned or replaced. It's worth looking inside for damage inside the unit. Pay close attention to plastic parts.
Nov 26, 2012 | Televison & Video
I have a Mitsubishi HSU48. The tape is stuck in the VCR. I cannot get it out. Do you have any suggestions
I had this problem with this specific machine. These answers have all been general to any VCR. The Mitsubishi HS-U448 has its motor underneath the machine. You don't have to remove the top cover at all. Just remove the bottom plate and spin the motor (the correct direction) to completely eject the tape.
Dec 23, 2010 | Mitsubishi HS-U448 VCR
VHS Cassette stuck will not eject
take the cover off. try to locate the loading motor and turn the gear on it and the tape will slowly eject.
Jun 29, 2010 | Mitsubishi HS-U260 VHS VCR
Tape stuck will not eject
open vcr look for a belt on the right side of the vcr and begin manually turning it until the tape ejects
Jan 04, 2010 | Mitsubishi HS-U770 S-VHS VCR
Plays for 3 secs, stops, and then ejects
This unit needs to have the "idler" changed as well as the belts. Over time, the internal rubber parts get hard ans slippery. There are safety checks inside that will stop the unit when problems are detected. With a slipppery idler assembly, the tape does not get wound into the cassette after passing the heads. Rather than have the tape collect inside and be destroyed, the unit stops. This is a relatively simple repair that any shop should be able to perform. Expect a parts cost in the $35 range. In my opinion, this unit is worth the repair as it will continue to provide service to you for years to come. New replacement units tend to last only a year or two.
Dan
Dec 30, 2008 | Mitsubishi HS-U770 S-VHS VCR
Error message E4 and stuck tape
Yes with care. Simply remove the cover and with care unwrap the tape. If you must break the tape - but make sure all residual tape is cleanly removed. Re assemble and put a tape head cleaner through- following the instructions.
Jun 22, 2007 | Mitsubishi HS-U445 VHS VCR
Mitsubishi HS-U447 VCR in Lock or "Loc" mode
Hopefully you still the VCR. Your's is stuck in "CHILDLOCK" mode. To release the lock you have to have the remote and press the DISPLAY for 8 to 10 seconds.
The purpose of the CHILDLOCK is to prevent others from using your VCR. If you want to set the VCR back on Lock you again press the DISPLAY for 8 to 10 seconds.
This solution is from the owner manual for HS-U448, so I figure your model is the same.
Mar 06, 2007 | Mitsubishi HS-U447 VHS VCR
Cassette stuck in video
I am a sanyo VCR technician and i will share to you what i had encountered. the problem of your VCR is in the mechanism "slide front" unable to push out the ejector portion of the tape. If you can locate this part just push it so that the tape will eject.
Aug 28, 2006 | Philips VR630 VHS VCR
Televison & Video Logo
116 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
