I have a Pioneer PD-M501 6 disc player and when i load a disc into one of the trays in the magizine it doesnt read it and it keeps changing disc trays, it skips it and said no disc, whats up?
  • fsttlk Oct 17, 2008
    My problem is identical to yours. Did you find a solution? I'm at my wit's end & need help ASAP! Thx, Gini
  • noelpetechrs Dec 27, 2008
    I have had the same problem twice. The first time I replaced the ribbon cable PNP1343. It fixed the problem but not for long.I am relucant to replace it again since I have checked it with an ohm meter and it seems ok. Because it is connected to the laser head that moves, it is claimed that it wear out quickly. Not good engineering! Replacement cost is only $10.
    Problem Solver:
  • 7 Answers
Make sure you place the disk correctly in the caddy, (Upside down in the caddy). It seems backwards, but I had it do that, and I flipped the cd over, and it worked.
Posted on Sep 27, 2010
  • dps86 Oct 16, 2010
    Remove the four screws on the side of the case and two in the back, to open it up. Remove the four screws holding the CD/laser component, which has the thin ribbon attached to it, and clean the lens of the laser with rubbing alcohol and a Q-Tip. Put all the screws back in place and you are all set to enjoy your CD player once again.
Sony dav-dz555k home theatre system-dvd tray keeps opening and closing, wont read disc at all. have to manually push tray closed and change setting from dvd to something else to stop it.
You seem to be having a door sensor problem. When the CD tray closes a small switch under the loading tray shorts telling the microprocessor the door is closed and to stop the motor (either way when it opens or when it closes). A malfunction in this switch causes this symptom.
Mar 14, 2011 | Sony Audio Players & Recorders
Pioneer DV535 Player
That sounds like a problem that needs professional service. The door may have jumped a gear, or there could be a circuit malfunction. At any rate, it's probably cheaper to buy a new DVD player. CD and DVD technology are quite precarious still, and I wouldn't expect more than a couple years service from most DVD players.
Jan 02, 2009 | Pioneer Audio Players & Recorders
CD Payer PD-M426. When cartridge is inserted, Player starts at disc 1 then immediately to disc 2 right to disc 6, then zero, without playing any of them. All the other functions seem OK so it seems the...
Hi Peter,
First thing to ask you to check is that the discs have been inserted into the cartridge the correct way... that is writing facing down. Check that first and let me know how you get on. Happy to work through it with you.
regards
robotek
Dec 10, 2008 | Pioneer Audio Players & Recorders
SX-1600 + KD-491F
Appreciate the additional information.
To recap what you need is a receiver that can accommodate:
4 - Pioneer S-DF1-K (15-100W, 8 ohms)
1 - Pioneer PD-F407 25 Disc CD Player
1 - Pioneer CT-300 dual tape deck
1 - Kenwood KD-491F turntable
Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
i. Onkyo TX-8522 Stereo Receiver;
ii. Yamaha RX-397 100 Watt Natural Sound AM/FM Stereo Receiver;
iii. Sony STR DE695 AV receiver;
iv. Teac AG-790 200 Watt Stereo Receiver;
v. Denon AVR 888 - AV receiver - 7.1 channel.
Some of the above also includes feature(s) to hook up to your video system. Some may even require a fifth speaker (subwoofer).
Incidentally, you can also choose another brand/model even without a turntable/phono input. As initially posted, a turntable/phone to line level pre-amplifier is only required. Here are some examples:
a. XP200 Turntable Preamp - Nano Series;
b. Pyle® Pro PP999 Phono Preamplifier;
c. Pro-Ject Phono Box Turntable Preamplifier;
d. Radial J33 RIAA Turntable Preamp Direct Box
Good luck with your project.
Apr 29, 2008 | Audio Players & Recorders
Pioneer PD F506 changer jammed
It is quite possible that one of the drive belts has come off its pulley.
Mar 16, 2008 | Audio Players & Recorders
Pioneer 6 disc PD-M455
Hello...if you can try to clean the laser lens whit a smooth cotton pin it may be dusty,,i have had the same problem...don't use any solvent just the pin very carefully,,,maybe you can use a mild solution made of hand dish solvent... and dry clean after...alternative use a cd.cleaning disc...Good luck Ron
Mar 10, 2008 | Audio Players & Recorders
Pioneer PD-206 wont power up
Hi tfulton
Try disconnecting from the power and powering it up again to reset the unit.
If it still wont cooperate, the unit will have popped a IC protector in the power supply. Not an uncommon fault. The burnt disc you used may have pushed the tracking servos a little hard and a circuit protector has kicked it. Pop the lid off and look for a black 2 wire device about 4mm across that viewed from above has a D shape. Measure it with an ohm meter....It should read low ohms, if it does not... it has failed. It may be marked as ICPxx(from memory)
A fast fix we used for this is to grab the device and give it a 200 deg twist to short the legs together. Soemtimes(often) the body of the device will break off, just solder the legs left behind.
They have a habit of failingl with no reason, and shorting across them will not affect the operation of the unit, nor put it anything in jeopardy.
OR pull the board out... and replace the device, although I can tell you through experience, they may fail again.
Good luck, if you have any questions, just get back to
me here. :)
regards
Graeme
Mar 08, 2008 | Audio Players & Recorders
979 people viewed this question
 Grubhead
Grubhead
