Question about Sport & Outdoor - Others
How do you change the blades on a Woods Brush Bull 600 rotary cutter? I followed the operators manual and have removed the bolt & flat retention clip, but nothing will dislodge the pin from it's seat. Penetrating oil, hammer blows & (modest) heat w/ oxy-acetelyne torch has be all been ineffective. No damage to pin or equipment, yet - don't want to be too agressive (I'm a competent mechanic). I've thought of pulling the "stump jumper" from the gearbox shaft & using a press on teh pins, but this is a lot of extra work for a set of "easy change" blades. Thanks for any help.
  • 11 Answers
SOURCE: How do I remove the pin on my Rainbow Vacuum Model SE clips?
When I used to repair Rainbow SE vacuums for a living, I had a long nail of small diameter that I had filed the end off of just for this purpose. The pin you need to remove is grooved on each end to "catch" in the plastic housing, but a slight tap with a hammer, using this "nail" will do the trick. When you're ready to re-attach it, just tap it again to put it back in place.
Posted on Mar 06, 2009
  • 57 Answers
SOURCE: can't get pin off to replace wiper blades
It's not the pin. The wiper has a small tab to press on the bottom. Press the tab and pull down on the wiper blade at the same time.
Posted on May 22, 2009
  • 13 Answers
SOURCE: 2004 jeep overland rear axle seals are leaking.
Yes. The c lock needs to come off.
Posted on Dec 30, 2009
brector3
  • 1624 Answers
SOURCE: cutter plastic drive block doesnt hold cutter pin
It sounds like the drive unit is the problem. This part can be purchased from shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
Posted on Jun 04, 2010
aquaman987
  • 927 Answers
SOURCE: Where are the pins on
The "pins" are the 48 little tabs that are around the clock dial. That would be 2 in every hour of the 24 hour day.
Push down a pin to start the device that you want to control and pull up the pin at the time you want the device to stop.
Posted on Dec 21, 2010
Need to sharpen the rotary blade
Top 5 Ways to Sharpen a Rotary Cutter Blade ' eBay
www.ebay.com > ... > Quilting > Quilting Tools & Equipment
Since the 1970s, rotary cutters have provided a reliable and efficient method for quilters, garment-makers, and other workers of fabric to create symmetrical and ...
Sharpening and Maintaining Your Rotary Blade from Scrap ...
? 5:54
https://www.youtube.com/watch?v=Kdd3JiWnmtE
Mar 13, 2012 - Uploaded by Craftsy
Sharpening and Maintaining Your Rotary Blade from Scrap Quilting with ... My online Craftsy class, Scrap Quilting: Waste Not, Want Not, will ...
Penny's Hands: How to Sharpen Your Rotary Cutter Blade
pennyshands.blogspot.com/.../how-to-sharpen-your-rotary-cutter-blade....
Mar 5, 2011 - And what has the aluminium foil to do with sharpening rotary cutter ...Thanks for that tip Penny, I have lots of blunt blades I can sharpen now.
Jan 27, 2016 | Food Processors
Removing cutter
Is this a guillotine style cutter or a rotary style cutter? What brand/model? Some rotary cutters are self sharpening and some cannot be sharpened.
Jul 12, 2014 | Tools & Hardware - Others
How change blades in a makita 1912B
Power OFF. Unplug from the wall! If you screw up, it'll eat the fingers right off your hand!
Each cutter should have two bolts. Rotate the cutterhead with your fingertips until you can see them. Loosen and remove them. Remove the cutter. Replace, replace the bolts, and torque them tight. Never EVER leave the tool lying with a bolt loose! If someone mistakenly plugs it in and turns it on the cutter will fly across the room like wartime shrapnel.
Mar 09, 2014 | Makita 1912B 4 - 3/8'' Planer
Is the gear box on an old Woods Bush Hog packed in grease or a heavy weight gear oil and what type is best. How do you prevent leaking
90 weight only. Fill through top until level with side opening. If it is leaking, it has likely blown it's seals. If leak is slow, just keep checking and filling it. If it's just flowing out, it's best to replace the box. No too fun. I've had to do it twice in about 15 years. Hope this helps a little:)
Aug 19, 2010 | RTO 1:1.2 Mower Gearbox Brush Hog Rotary...
My 2012NB has served me well for about 10 years, but lately lumber does not feed through smoothly and the result is a "ribbed cut" - there are gouges running across the board at about 2 inch intervals. My...
I just read the owners manual online at Makitausa.com and I don't see the reference to the feed rollers and pressure.. I would look at the condition of the planer blades to ensure they are sharp and not pitted. Then I would look at the feed rollers for being out of round. Let me know, it has been a couple years since I worked on one of them.
Jun 30, 2010 | Makita 2012NB Electric Planers
Instructions for how to replace the rotary cutter blade in fiskars rotary cutter, searched online but, not getting what I'm looking for... where does the washer go in placement...
I am trying to get something from Fiskarcrafts.com on the rotary cutter that you have. I will let you know when and if I get something. Also you might check out their website, sometimes they have online help.
Sep 21, 2009 | Fiskars Brands Donna Dewberry Rotary...
Cutters on Elna 744 serger won't cut
is there lint or thread caught between blades preventing them from meeting?
scott
Jul 26, 2009 | Brother 929D Mechanical Sewing Machine
Rotary cutter shakes
If a roc bent the pan - I dont see how that would make it shake..
I suspect the shaft..
Hoe this helps !!
Jul 14, 2009 | RTO 1:1.2 Mower Gearbox Brush Hog Rotary...
Thihl HL75 hedge trimmer engine will not run at full speed
Remove the cutting attachment, insert a screwdriver in to the shaft receptor and it should operate smooth with a slight bit of friction. if not then check the blade bolts and make sure the blades move freely. Lubricate the blades and the gearbox regularly. If the attachment end is good then turn the driveshaft by hand (with attachment still off shaft). If this too moves freely then go to the clutch.
Apr 04, 2009 | Oregon Scientific Complete Carburetor for...
Sport & Outdoor - Others Logo
113 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
