Question about As Seen On TV Sewing Machines
The knitking needles are different, they are round with no flat end and smaller regular needles do not fit its called a knitking trimlock serger model 523
4 Suggested Answers
JeremySew
  • 65 Answers
SOURCE: I just bought a used White superlock serger model
We have that instruction manual available here:
White Sewing Machine & Serger Instruction Manuals
Posted on May 22, 2009
SOURCE: have singer 2 needle serger diagram to small to read it
problem solved inlaged diagram,thks ****
Posted on Jan 14, 2010
SOURCE: I have a baby lock
check with these sites, you may have to email or call them about the part
sewingpartsonline.com
sewvacdoctor.com
premiersewing.com
sewingpartsdirect.com
Posted on Sep 07, 2011
Needle broken taken old one cannot fit new one
Consult your owner's manual.
Make sure you are using the correct needle for your machine. Some machines use different kinds/sizes of needles.
Be sure the needle holder (the screw) is loosened enough to allow the new needle to be inserted and push the needle as far as it will go before tightening. BE CAREFUL not to lose that screw!!!
Verify that the flat side of the needle is facing the correct direction when installing. (Usually the flat side faces the back of the machine, but some machines differ.)
https://www.youtube.com/watch?v=bnDB2kldaKA
http://www.ehow.com/how_4597754_replace-needle-serger.html
Apr 15, 2017 | Sewing Machines
Can I use sewing needles to replace the one in the serger or does it use a round one
Depends on your particular machine. I use the same needles in my overlocker as I use in my sewing machine BUT that varies with makes/models. My coverstitch serger uses different needles.
Best bet would be to consult the owner's manual. If you don't have one, search the internet for:
Make + Model + the word "Manual"
Jan 21, 2016 | Sewing Machines
Does the Singer Serger Ultralock 14u52a use standard needles or do I have to get special ones?
Serger needles are different from regular sewing machine needles, but like sewing machine needles, they are generic. That means that if you buy a serger needle, it should fit most sergers from any manufacturer.
My favorite manufacturer is Organ; they've been in business for a long time and manufacture for commercial and home machines and sergers and they're quite inexpensive.
Jun 23, 2014 | Singer Sewing Machines
Serger Needles
Janome Overlockers (sergers) are set at the factory with #14 Red Tip needles
For finer fabrics, the #11 Blue Tip is good
If the #11 breaks, then try a #14 as they are a little heavier duty
You can always:
Contact Us at Bargain Box
Have a look at the detailed descriptions on these links
Accessories Parts
Apr 20, 2014 | Sewing Machines
When we thread the serger . the thread is still skipping
Are you using the corfect serger system needles in it? Most domestic sergers will take the regular domestic needle 130/705X but work best with a serger needle with has a groove down the front as well as the regular back scarf. This helps with the thread pickup from the looper by the needles. Sergers also run much faster than domestic sewing machines so the tolerances are very fine.
My Bernina came with ELX705 needles and it does run better with these in it. Also you need to use mid size needles, don't go too small, probably a size 80 or 90 is best.
Check out this page for some good info as the different serger manufacturers do have their own recommended needle sometimes. http://sewingmachine221sale.bizland.com/store/page78.html
Always refer to your manual (or ring the manufacturer if lost) to double check what needle they recommend be used in your serger, it does make a difference.
May 19, 2011 | Sewing Machines
What is the needle system for Simplicity 804D serger?
For the both you listed (brother 925d and simplicity 804d) it is a "15x1" which is a standard home needle. Same size the fits almost all home sewing machines. Make sure to put the flat side of the needle to the back.
Let me know if you have any more questions,
Chris
Jun 09, 2010 | Brother 925D Serger
What needles are used by my Janome Model 134D serger?
my overlocker is a janome and i use generic overlocker needles; these are all rounded, not flat on one side. i hope this helps
Jan 29, 2010 | Janome MyLock 634D Mechanical Sewing...
What is the size of the needle used in the white superlock 1934D
This is a very highly regarded serger. Check out the reviews on http://sewing.patternreview.com if you're interested--but they are all extremely positive.
I also checked out the White Sewing Machine site--the three sergers they currently sell all use regular sewing machine needles.
Based on what I read on both sites, I believe your machine also uses regular sewing machine needles (not all sergers do, BTW). To be absolutely certain, you can call the White Help Line (l 800-331-3164, Monday through Friday 8AM to 5PM, EST).
If your serger uses regular sewing machine needles, then the size of the needle depends on the type of fabric you're sewing. Sizes 8 to 10 for lightweight fabrics, 12 to 14 for medium weight fabrics, and 16 to 18 for heavy weight. Use ballpoint needles for knits, jeans needles for denim, and universal needles or sharps for woven fabrics.
Jan 26, 2010 | White Sewing Superlock 1934D Mechanical...
Needle for a singer tiny serger
Hi, ALthough it is called a "Tiny Serger", it will still take regular singer serger needles.
Apr 23, 2009 | Singer Tiny Serger TS380
Sewing Machines Logo
63 people viewed this question
Top As Seen On TV Sewing Machines Experts
Harjeet Singh
R.A. Ellis
R.A. Ellis
CrisO
Are you an As Seen On TV Sewing Machine Expert? Answer questions, earn points and help others
