Question about NComputing L230 Network Terminal
Usb port changes when a L230 got reset. the printer attached to the unit no longer printing.
3 Suggested Answers
pandeyram1
  • 192 Answers
SOURCE: why do connect usb key board on usb port of l230
in usb ports we will use only usb cable, but there are no need to use a particular cable to a particular port we can change the ports.
Posted on Apr 02, 2010
  • 86 Answers
SOURCE: I have ncomputing L300 thin
Since you posted this four months ago, there has been some major updates from NComputing to improve the USB architecture. This should improve support for peripherals such as your printer. Download the latest software for either W2K3 (v4.9.5) or W2K8r2 (v6.1.3) and update your system. Lastly, it is critical, and I mean absolutely critical, that you update the firmware on the L300 as well. The firmware is included with the vSpace update so once the host is updated, go to the L300 and tell it to update the firmware. The current firmware version that works with v6.1.3 or v4.9.5 is v1.4.1. As of this writing, 8/16/11, those are the current versions.
Posted on Aug 17, 2011
My print server cannot be reset to the factory default for some reason. I have tried holding the reset button for 10 secs, but without luck.
I have some devices where I have to hold the reset for 20 seconds. So try holding it longer. And make sure the print server is powered up when you do it.
Feb 17, 2016 | Belkin (F1UP0001) Print Server
WHAT CAN I DO TO MY PRINTER TO MAKE IT PRINT FASTER?
Depends on what part of printing that's slow. Parallel port may be slower than a USB or network connection. If your printer doesn't include a USB port, one may be available to add to it. Same for a network connection.
Other things that make laser printers slow is what you are printing. Text typically prints quickly, but images take longer, and large images take even more time.
Some software waits to send the first page until the last page is done "processing" before sending anything to the printer. You may be able to change that.
Nov 09, 2015 | HP LaserJet 2300 Printer
I have ncomputing L300 thin client with usb port. I attached Cannon Laserjet LBP2900 to thin client usb. also installed drivers on host. printer is detected & shows printer ready. but when i give...
Apr 21, 2011 | NComputing L230 Network Terminal
Why do connect usb key board on usb port of l230
Apr 02, 2010 | NComputing L230 Network Terminal
Printing off
Do you have any error messages? Try a new USB cable and attaching to a different port on the computer. If using a hub, try directly connecting to the computer. Do you see files stacked up in the printer queue? (These may need to be removed.) To reset the printer, unplug the USB and power cables for a minute. then reconnect them. (The USB cable should be unplugged from both the printer and the computer). Make sure your USB ports are not disabled for power-savings or security (in the Device Manager and Power Savings Control panels for Windows).
I hope this helps.
CiIndy Wells
Mar 20, 2010 | HP DeskJet F4280 All In One Printer InkJet
Can i used printer to ncomputing L230 in a
yaes use this printer only usb not lpt port
Feb 01, 2010 | NComputing L230 Network Terminal
Printer is connected but does not print
Hi
Thanks for using FixYa. Please check the following things first---
· The printer cover is closed and the rear access door or optional duplexer is attached.
· The printer is connected to the power source and turned on.
· The cable connections are secure and the cartridges are correctly installed.
· The paper or other media is correctly loaded in the in tray.
Now check the printer cable connection: If the printer cable is attached to a USB hub, a printing conflict might exist. Use one of the following methods to resolve the conflict:
· Attach the printer USB cable directly to your computer.
· When printing, do not use other USB devices that are attached to the hub.
Now verify if the printer is connected to the correct USB port: If the computer is configured to use both the back and front USB ports on the printer, then you might be printing to the wrong port. The computer has two versions of the printer driver: one for the front USB port and one for the back USB port. If you are connected to the back USB port, but select the printer driver that is associated with the front USB port, the printer will not print. In the application that you are printing from, click File and then click Print. The Print dialog box opens. The Print dialog box displays two versions of the printer driver. Select the version that is associated with the port to which you are printing. The issue will be resolved.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 12, 2009 | HP DeskJet 6540 InkJet Printer
Using D-link dp-300 Printer Canon ImargeClass MF4350d (Multifunction printer) Problem. I can not use scanner fanction. (no problem for printer) Without printer server, I able to use the scanner.
The problem you are having is pretty standard, the IP based printing works for most printers but the scanner require direct(or well faked, direct) connectivity with a USB port which most routers do not provide.
Several companies including Startech and Io Gear make Virtual USB devices which would resolve the issue.
How they work differs as instead of creating an IP printer, the usb device installs on an ip and then a driver you install on your PC(s) connect to the unit over the router and sets up a virtual USB port on your machine so you can re-install the printer as a local printer attached to what it thinks is a local USB port.
Doing this will allow you all functionality the printer offers but will slow down printing and scanning a bit
Hope this Helps,
Chris
Armor-IT
Apr 24, 2009 | D-Link DP 300U (DP-300U) Print Server
HP Laserjet 2300 printing 5 copies
Friend,
There shouldn't be any need for a parallel-to-USB device, since your printer has both ports - and you could use ONE of the ports for printing. One, since two ports does NOT mean that the printer can serve two PCs simultaneously. On startup, it determines which port is active and "forgets" the other.
So I would have gone for either a parallel cable (IEEE 1284 standard, no longer than 10 feet) or a USB cable, running the cable directly from PC to printer.
If there's a need for several users to access this printer, I would either have shared it from my computer (where it's physically attached) to the other users in the network - or, purchased a jetDirect network card for the printer. With a JetDirect card the printer is accessible for all users over the network regardless of which computer is switched on.
Hope this clarifies and gives an answer to your question.
//Al
Mar 10, 2009 | HP LaserJet 2300d Printer
Printing problem with Lj1020
I would suggest logging onto the companys web site and downloading the newest driver.
And see if there are any update locations for your printers software.
Sounds like a bad driver or printer software corruption.
Also check on your menus to see if there is a way to clear or reset the printer memory.
You most likely have some file corruption.
Dec 07, 2007 | HP LaserJet 1020 Printer
NComputing L230 Network Terminal Logo
Top NComputing Computers & Internet Experts
Tom Chichester
Alun Cox
Are you a NComputing Computer and Internet Expert? Answer questions, earn points and help others
