Question about ASUS P5L-MX Motherboard
Shut off at start up - ASUS P5L-MX Motherboard
    Genius:
  • 1,400 Answers
Hello
Possible memory sticks are either installed wrong or not seated properly.
Or you have them in the wrong slots,most slots are color coded.As seen in the picture.orange yellow orange yellow,shown lower right hand side.
http://www.diycustomcomputers.com/images/MotherboardB.jpg
If you using two sticks each needs to be in either yellow or orange.
Posted on Mar 31, 2011
My tool improper shut down detected checking file system please help me
that message appears if the shut down process is not followed.
power failure , emergency shut down or other problems that just shut the pc down will result in files and folders becoming corrupted and not saved
when booting up if the message appears that states start in safe mode , start normally etc , click on start normally
Oct 25, 2016 | Computers & Internet
Just replaced the circuit board after a technician told me that was the problem. White Rodgers 50A56-956. Getting the same result as the old board: clicks on, shuts off
White Rodgers relay clicks shuts off Surveillance Cameras ...
www.fixya.com > ... > Tags > relay clicks shuts off > Surveillance Cameras
White Rodgers surveillance cameras relay clicks shuts off related questions and answers. Ask your White Rodgers questions. Get free help from surveillance ...
White Rodgers car will start up but shuts off Surveillance ...
www.fixya.com > ... > car will start up but shuts off > Surveillance Cameras
White Rodgers surveillance cameras car will start up but shuts off related ...Thermostat works, clicks when turn on heat, shows Stage 1 on display (hooked up .
relay clicks shuts off Surveillance Cameras Questions ...
www.fixya.com > Forum > Tags > relay clicks shuts off
Surveillance Cameras relay clicks shuts off questions and answers. Ask your relayclicks shuts ... I have a white-Rodgers 1F86-244 thermostat. When I ... a new ...
Jan 16, 2016 | White Rodgers Home Security
At night its shuts down when the therm is satisfied,but trys to restart right away and when it does start it shuts down right away and just keeps doing this
The thermostat has a differential built into the temperature sensing operation. The differential is normally a degree or more. If the stat shuts down at 72 degrees it should not start the unit again until the temperature in the room reaches 73. If the AC runs and cools properly until it shuts down, I would check the thermostat. The AC can not restart immediately after it shuts off because the pressures in the system are too high at the compressor. It takes a few minutes for the pressures equalize allowing the compressor to start. If the stat tells the unit to start under high pressure, the compressor will shut down on overload. It will start and run after the pressure falls enough for the compressor motor to run.
Jun 04, 2015 | Dometic Rooftop RV Air Conditioner
How do i turn off windows 8
1. In Windows 8.1, from the Start screen, click the Power button and select Shut down.
If you can't see Start screen, point the mouse to the bottom-right corner of the screen, click Settings, then click Power, then click Shut down.
2. From the Start button, select Shut down or sign out and then Shut down.
Jul 08, 2014 | Computers & Internet
Turn off windows 8
Starts then it wont start back up
if it starts and warms up does it shut it self off or do you shut it off an then won't restartif it shuts self off may be runnining it self out of gas wwhen it shuts off try spraying a little starting fluid in breather and see if it will recrank if it does you have a fuel problem if it does not start you have an electicly problem such as a bad coil poss
Jul 29, 2010 | 2005 Yamaha YZF-R1
Pc not always booting,
blow out dirts on bord, then you pack the board to avoid any bridging with the cassing
Jul 20, 2009 | Computers & Internet
Engine Starts, then immediatly shuts down
mass air flow sensor, or idle control valve.
Apr 28, 2009 | 1989 Dodge Raider
ASUS P5L-MX Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
