Question about Scotsman CSW45 15" Ice Maker with 26 lb. Ice Storage Capacity, 44 lb Ice Production per Day, Drain R...
Scotsman ice machine problems.
I have a Scotsman CSW45A1A1 model ice machine. The ice will get thicker each time it dumps. After about five or six cycles the machine will not dump at all and has to be cut off.
  • Anonymous Mar 15, 2014
    scotsman ice maker
  • Anonymous Mar 25, 2014
    trouble code 8 short freeze cycle
  • Scotsman Master
  • 8,220 Answers
Well it is making ice cubes alright just too thick right? I would give it a good cleaning with nickleguard and retry. If it is still doing the same thing I would replace the ice thickness switch.
Posted on Mar 01, 2009
Check the dump valve if water is seeping through the dump valve then the water inlet valve will be adding water to sump all the time to replace water lost. Now if water is running over sump into ice bin then look at water inlet valve.
Jul 17, 2014 | Scotsman Ice Maker 600LB CM3 30inW...
Scotsman ice machine water runs continually never shuts off. It will make ice but really racks up water bill. It is as if the float never senses the reservoir is full. What is my problem?
OK is the bin full of ice to where the ice stops making ? and is the water running over into the ice bin. If this is whats happening then cut the machine off, If water is still coming into sump tray then pull the water inlet valve and replace it. If the water stops when you shut the machine off then check the water float or sensor since i don't know what model you have, If float then replace it , if probe sensor then replace it. Now if there is no water running over into ice bin during freeze cycle then nothing is wrong ice machines use a lot of water every time it go's into a harvest it dumps the water in the sump tray.
Jan 12, 2014 | Scotsman Ice Machine, Cuber, 1930 lb....
MY SCOTSMAN ICE MACHINE IS MAKING ICE, BUT ITS TOO HARD AND CHUNKY HOW CAN I FIX THE PROBLEM
First is the ice to thick coming off of the evaporator plate? If so then you need to adjust the ice thickness probe located at the top of the evaporator plate it is white with a 1/4" screw going through it, turn if left an 1/8" at a time let it make ice and check each batch. Now for chunky ice is it melted together? If so then make sure the machine is not dumping water into the bin during harvest if it is then check the dump valve to make sure it is opening during harvest cycle.
Oct 31, 2013 | Scotsman Cooled Modular Contour Cuber Air...
Scotsman drain water don't stop
check dump valve stuck open change dump valve. Ice production should have slowed down due to this.
Sep 17, 2013 | Scotsman Ice Machine, Cuber, 1930 lb....
Black flakes
Dose the whole cube have a black tint to it? or dose it have black flakes in it? If all the ice has a solid black tent to it then check your water filter most all filters has charcoal in them when you change one out and apply water to them you need to dump the ice until you get clear ice. Now if it is just black flakes in ice than you need to clean the ice machine with scotsman cleaner nickle safe and scotsman sanitizer follow manufacturers instructions.
Aug 30, 2013 | Scotsman Kitchen Appliances - Others
Scotsman sce275 making ice too thick
carefully adjust the ice bridge thickness screw at the top no more than 1/8 of a turn counterclockwise in between freeze cycle until desired thickness is obtained. clockwise gets thicker and counterclockwise thinner.
Apr 12, 2013 | Scotsman Ice Machine - 290lb...
My scotsman ice machine makes thin ice cubes
rotated the ice bridge adjustment screw clockwise about a 1/8 turn in between freeze cycles. thich direction makes the ice thicker.
Mar 27, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman CSW45 15" Ice Maker with 26 lb. Ice Storage Capacity, 44 lb Ice Production per Day, Drain R... Logo
1,038 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
