Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What is the gap setting for the 42cc poulan pro
  • Poulan Master
  • 2,239 Answers
0.3mm is fine for this machine.
Posted on Mar 31, 2011
Gap coil on ppb 330 poulan pro
First and foremost ppb330 is a model number for a grass line trimmer, gas model.
Second, I am unsure what you are asking. Gap coil?? Do you need the spark plug gap for your chainsaw? That gap is .025.
I hope this helps. If not, please re-post with the correct model number for you chainsaw.
Jul 08, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What is the spark gap for 221 pro 40cc
The gap for all Poulan chainsaws, regardless of the spark plug used, is .025.
Jun 12, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What is the proper gap for the mag to flywheel?
0.3mm for the air gap, 0.5mm fot the spark plug gap.
Apr 30, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan pro 42 cc, no spark
Try diss connecting the earth cut out wire from the ignition unit and try for a spark again, this will rule out the switch and any trapped wires, re set the air gap between the unit and the flywheel to 0.3mm, if there is still no spark the unit is bad and will require replacment, they are normally only held on with a couple of allen screws, and either bolted to the cylinder or the crankcase.
Apr 12, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How to set magneto gap in poulan 42cc. also how to test the coil if it is working well. there doesn´t seem to be enough spark
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction abates and remove the card. Ensure nothing contacts when the flywheel is rotated.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 03, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan will not fire off, no report when primed manualy.
Yes. I would start with the plug wire. If your gap is correct and you know that the coil is good. Then it should be the wire.
Jun 18, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
135 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
