Question about Memorex MVDT2002 20" TV
Our Memorex model #MVDT2002B, SH 067460905582A, was working fine. There was a short power outage in town during the work day. When we came home, the TV wouldn't power up. The cable box had reset just fine. We upluged and plugged back in, but nothing happened. We plugged a different, older TV into the same power source and that worked fine. Is there a reset button? We can't seem to find one. Also, we can't find our manual. Thank you, Janet and Brian
  • 1 more comment
  • bmgband Apr 07, 2011
    Hi, we got the back off the TV and the fuse looks ok. Brian took it out and put it back in and tried to turn the power on. It buzzed like bzzzzzt, then made a ticking sound like tick, tick, tick, tick. Do we need to replace the fuse? Can we get this fuse at a Radio Shack? Please advise. Thank you for your assistance.
    I think we'd better take the TV to a repair shop. Thank you for your assistance.
    The solution warned us that it could be dangerous to continue. We appreciate the warning and will take the tv to a repair shop.
    Top Expert:
  • Memorex Master
  • 75,404 Answers
Hello
There is a protection fuse inside your tV, which can be located at the power regulator section, to which the main power cable enters to the board. It is a class cartridge type, and can be replaced. Check it first. If found blown off, replace it with an other with same rating; which will be marked on its end metal caps. Never use an other rated one in place. Switch on your TV, while its back cover opened, and watch if the newely inserted fuse also blo up. if blow up, certainly there will be some short circuit inside the circuit board, which occured during power surge. Check these and inform me if the fuse blows again. I'll assist you further. Let me know the result by Fixya. OK.
Posted on Apr 06, 2011
  • The Knight
    The Knight Apr 07, 2011
    Hello
    The power supply section of your TV is faulty. It has an STR reguated power regulation section. The STR has damaged. You must have some knoledge in electronics to repair this section. Almost 90% of components in that section are "LIVE" parts, and touching the accidently will be fatal. Whout its schematic diagram, and measuring instruments, a concept about soldering and desoldering; you cant set it right.
    If you have these and wants to repair it by yourself, send your Email address to me, by Fixya. I'll send the schematic diagram of your tV;s internal circuit, so that you can see what exactly the components and about its connections. OK.
  • The Knight
    Good determination . It is dangerous to handle a device like TV without any experience. It may lead to more and more problems to occur if we try to repair it, if we are not aware of its working principles, and knoledge to readout its schmatic diagram. Wish you Good Luck.
Ovens work fine . .ONCE ! Then buttons do nothing until you turn off the wall breaker for an hour. Then the oven works ONE time again.
Tom Sh, you own every kind of appliance, or you are attempting to be a repairman with free advice from Fixya?
Replace the touchpad. Help Me Find My Model Number RepairClinic com
Aug 30, 2016 | Ovens Ovens
Frigidaire model number FRS6R5EMB8 Not cooling
Feel the top of the compressor and tell me what you feel
Oct 09, 2015 | Frigidaire Refrigerators
Westinghouse ice maker quit working
Is it your ice maker, or possible the blades that crush the ice or dispense the cubes? What can happen in the latter case is that during the storm the ice melted and pooled in the cutter mechanism. Then, when power was restored, the blades were frozen solid. To fix, investigate taking out the cutter mechanism and letting it thaw and drain. Then reinstall and use frequently for the first few days to prevent refereezimg.
Feb 26, 2014 | White-Westinghouse White Westinghouse...
Kenmore model #596-79872990. After a power outage, even a short one, the motor does not restart. If the unit is unplugged for several days and then restarted it works fine until the next outage. I...
Make sure the mains voltage is correct . if its too low the compressor will overload when trying to restart causing the overloader to kick out, but should only take a few mins to try and restart.
Sep 05, 2013 | Kenmore Refrigerators
I have an eMachines ET1810-01 PC Desktop. After a power outage, the computer won't turn on. When I press the power button to turn on, I see it supplied for about 5-6 seconds and off it goes. During this...
same thing happened to me with this machine -- actually, two power outages. I thought I was protected, as I run UPS and the machine should have hibernated (I know it did the first time). At any rate, after the first failure, the clock wouldn't run right, and after the second, the exact thing you describe happened.
I was within days of losing the warranty, and sent the box back. Cost $27 to ship, insured. They replaced motherboard and reformatted hard drive. It works fine now. 90-day warranty on the repair.
In short, your motherboard is toast.
Oct 29, 2010 | eMachines ET1810-01 PC Desktop
Had a short power outage. Freezer stopped working; light and panel would come on but compressor would not work. Still under mfg warranty but Sears will not schedule a repair for 14 days. Unloaded the...
find another service agent that is authorized to carry out warranty repairs on your make of freezer and have it fixed
Sears is not the only authorized service agent in town
Jan 04, 2018 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Cl flashing on display
You need to reset the time after a power outage.  Press the Day/Check, Hour, and Minute buttons until the correct time is heard-- Press Day/Check until you hear the correct day announced. Then do the same with Hour, and then Minute.
Jun 01, 2008 | Motorola Mobility MD761 Cordless Phone
Digital broadcast compatible
I have a 1999 RCA TV model # F27645. I wanted to know if I am going to need to get a digital converter box?
Feb 13, 2008 | Televison & Video
Memorex MVDT2002 20" TV Logo
220 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
