Question about Casio Watches
I have two Casio watches requiring new straps = Model PRG--50 Model DW5600E Where can I obtain replacements ? Thanks Ray.
  • 73 Answers
SOURCE: casio wrist watch, model # wv58a unit # 3064
Try this link to download your particular instructions.
http://world.casio.com/wat/download/en/manual/
Posted on Dec 31, 2007
  • 73 Answers
SOURCE: How to adjust the straps and time on a Casio AQ230A-7B
For an instruction manual go to the following link.
VOTIT
  • 2071 Answers
SOURCE: I have a casio triple
Casio solar watch has no battery it is powered by solar,but there is a storage capacitor like a battery.It will last for 5years that capacitor.Try to hold all the buttons and press hold simultaneuosly for 7 seconds this for reset the watch..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE.
Posted on Jul 29, 2008
indays
  • 111 Answers
SOURCE: hi, where can i get a
good eafter noon ! you can buy a bracelet of your watch on casio center near you,thanks!
Posted on Aug 29, 2008
SOURCE: WV-57H Watch - how do
If you look at the watch from the side, you'll see that there's a two-part metal piece on the underside of the watch on each side.  The metal piece is a spring-loaded pin going through the strap which is holding on a larger metal piece.  You need to get another small pin (or an eyeglass screwdriver might work) so you can poke in the end of that spring loaded metal piece, which will allow you to slip off the larger metal bracer.  Then you can poke the spring-loaded pin entirely out of the strap and it will be freed entirely.
To help you visualize what you are doing, the spring-loaded pin operates similarly to a toilet-paper roll - you need to compress the pin so you can slip off the larger metal bit, then take out the pin, which will free the strap.
Posted on Dec 05, 2008
I need to buy strap only for model prg-110b
Go to your local Jewelry (watch) H samuels , HINDS bout expect to pay a lot .
Dec 24, 2015 | Casio Protrek Triple Sensor Prg 110T 7VDR...
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I reset my Casio PRG-40 following battery replacement?
    Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please .
    Apr 08, 2010 | Casio Protrek Triple Sensor Tough Solar...
    The strap is broken on casio watch
    I had exactly the same problem with exactly the same model watch, and it happened to me twice. The AQ-160 is the important part of the model number as far as replacement parts are concerned. The first time, I took it to the shop where I bought the watch, and they replaced the band, but it cost me $50. The second time, I looked up the Web for the master agent for Casio in Australia, and they said I could buy the end piece, not the whole band, for $6. I found I could replace it quite easily myself by using a drawing pin to remove the spring pin that holds it together. A bit fiddly to reassemble but not too bad. In fact, I didn't wait for the new part to arrive, just used the unbroken end of the old band. So now I have a repaired band plus the old band and a new end piece, in case it ever happens again.
    I really like this watch, but it is a pity the bands are so weak.
    Aug 14, 2009 | Casio Watches
    How to change battery in Casio wave ceptor4305
    If there is no any screws holding that 'metal strap' then carefully check both ends of it. You will notice that the ends (or one end) are snaped over the little plastic hooks. Take pointed tweezers and push that end outwards (away from battery) and the contact (metal strap) will pop out.
    After battery replacement, just push the contact back into place till it fixes.
    If there are screws holding the contact, just undo them.
    Be quick when replacing battery- you have 2 or 3 minutes to do that, otherwise all data will be lost and you will need to reset watch completely.
    Dec 19, 2008 | Casio PRG-40T-7 Pathfinder
    Watches Logo
    Top Casio Watches Experts
    Jimmy Accardi
    k24674
    Are you a Casio Watch Expert? Answer questions, earn points and help others
