Question about Microwave Ovens
I GET THIS MESSAGE huile a vi danger IN MY Hummer H3
Are microwave ovens dangerous to our health
It depends on microwave, and condition, as some can leak so never stand directly in front while on is best safety advice. After all these years I have yet to see conclusive evidence of being dangerous to our health, but remember, only use microwave safe glass containers, not plastic in any microwave to avoid what is known to be a dangerous BPA vapor some plastics emit which penetrate foods, www.FREE-PPV.com
Mar 15, 2015 | Microwave Ovens
Display screen says H98.how do I fix it or what does this mean?
DO NOT try to REPAIR this Inverter Power Supply (U) and also DO NOT RE-ADJUST PRESET VOLUME on the board. It is very dangerous to repair or adjust without sufficient test equipment because this circuit handles very high voltage and very large current. Off alignment or inverter board operation is dangerous. Operating a misaligned inverter circuit is dangerous due to the very high voltage and current that is produced by this board. Defective boards must be replaced with a new one.
Jan 22, 2015 | Panasonic Inverter Countertop Microwave
I have erosion holes in my oven, is this dangerous?
The inner cabinet is deteriorating. Dangerous? well in some ways yes. You are leaking heat from the cooking chamber and if you have any spills of grease that could land on the bottom element it could start a fire. So yes it is dangerous, from a fire safety point of view.
Aug 13, 2012 | Microwave Ovens
Is the running open door dangerous
Yes! it is dangerous, microwave leakage is the biggest concern, you need a professional to assess safety and repair viability.
Mar 24, 2012 | Panasonic NN-T793SF Microwave Oven
My NN-J993, microwave function starts and turn off immediately
If the magnetron is OK,
Jan 20, 2011 | Panasonic Microwave Ovens
Microwave Model 40180089700 shows "5E"
You have an error code and probably for good reason. maybe a switch is bad to keep out radiation for closing the door or what ever . If you don't know about these things don't mess with them! They are very dangerous and it can radiate you with out you knowing in some instances. Not worth messing with ,too dangerous for the unknown guy!!!!!
Jan 12, 2011 | Kenmore Microwave Ovens
What does the F9 display mean for a Kenmore Elite Microwave Model 72163769300?
The F9 error code indicates a failed inverter. If resetting the unit does not help you will need to have the inverter & harness checked.
http://media.fotki.com/1_p,wbgdfgsrsttwqwbxgtqsskgwtqkq,vi/kgdfkfrkkxkfdtftrfb/1/1303472/5961857/image45625img-or.jpg
This can sometimes by caused by a power surge or glitch through the electrical lines.
You can sometimes clear this fault by completely unplugging the microwave for 1 minute.
Plug it back in and see if the fault code returns.
If it does, then you have an internal component failure that will need to be serviced by a technician.
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances.
Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged.
A microwave radiation leakage test must be performed on the unit following any internal component repair.
It does not ALWAYS indicate a inverter control board problem however in other brands/models.
LG's service manual (for an example) suggests the f-9 code could be due to line voltage, magnetron, inverter module, "Relay2", or a loose connection between door/magnetron/control pcb.
Other indications might help narrow down these choices before having to pull out your multimeter and crack open the microwave case.
For example, if the microwave works, but heats slowly, then the troubleshooting manual narrows your choices down to magnetron or line voltage problems, and pretty much rules out the other possibilities.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 15, 2010 | Kenmore 63792 Microwave Oven
What does an error code of F-9 mean on a Kenmore ultra wave microwave model 721?
Mar 22, 2010 | Kenmore 63792 Microwave Oven
I have a kenmore elite microwave and after about 8 seconds and f9 error apprears...please help
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^%$
Mar 06, 2010 | Kenmore 63792 Microwave Oven
Have a 4 1/2 year old Kenmore Elite Untra Wave Microwave Hood Combination. Recently got an F-9 error code after about 10 seconds. Tried unplugging for over an hour and then plugging back in, but got the...
Mar 16, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Microwave Ovens Logo
51 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
