Question about RCA TH1101 MP3 Player
MP3 Player keeps shutting off
I use my player when I work at the factory, so it gets dusty. I've also dropped it a couple of times. I took it apart looking for a broken battery wire, but that's not it. At least I haven't made the problem worse by poking around inside. The problem is it has started shutting down on me, which is really annoying when I'm in the middle of an hour long podcast or audio book. Strange side effects: often the shutdown occurs when I twist the plug to the earbuds. My favorite pair has a dead bud, which could, I suppose, cause a mini arc (before this problem began, the player would occasionally shut off if I shocked myself on a door knob). But I've tested the player on several headsets and it still wants to wink out. When it does, the display goes blank and the sound stops, but there is a faint background noise that persists until I pop the battery. Often when I try to restart, the "PEARL" icon appears, but it never goes to the "Please wait..." window. It just sits there. I usually have to pop the battery twice before it comes back, and then later on, it cuts out all over again. The problem doesn't seem to affect the player's function as a jumpdrive. Only once has it failed to interface with a computer. That one time, the screen came on (I had plugged it in cold, as usual), and instead of getting the "USB connected" window, the display simply said "PEARL" until I removed the battery, and then I could sync files just fine. Sorry for the essay, but since you can't tinker with my device yourself, I thought I should be as thorough as possible. Any suggestions?
  • 8,596 Answers
Try upgrading the firmware - otherwise, see if it's still under warranty by calling RCA - those conditions that you describe are more than sufficient to damage the player. Unlike TVs, mp3 players do not generally have saleable internal parts. If in warranty, just replace- don't tell RCA that you dropped it, or the warranty is voided
perform a firmware upgrade to
restore it.
– Please go to http://www.rcaaudiovideo.com/faq
for more details.
-Tha Mp3 Doctor
Posted on Sep 04, 2008
Why won't my Sansa 250R won't recognize an sd card?
Your 4GB card is actually a microSDHC card. The e250 works with microSD cards, 2GB and smaller.
Mar 10, 2013 | SanDisk Sansa e250 MP3 Player
Mp3 player full and can,t reset it.
ohh..i had a friend too who bought a chinese brand touch screen cellphone. .something about he just accidentally dropped it and the thing didint work back again..ever..like **** ..what the ****..just sayin that chinese brands are like not that gOod
May 18, 2009 | Jwin MP3 Player
Won't Work suddenly.
What is happening when you turn the device on? Does it go on and then shut off? If so you will have to reformat the drive for the mp3 player. Simply plug the mp3 player in and click the drive that appears for the player. It should say this device needs to be formatted. Then just follow the steps. Keep in mind you will lost your songs. If the device stays on, do you see your first song on the list. If you do, try pushing the play button, (very last one on bottom) hard.
Dec 08, 2008 | TruTech SMP-1 GBL MP3 Player
My MP3 keeps shutting off
restore it.
for more details.
-Tha Mp3 Doctor
Aug 05, 2008 | RCA TH1101 MP3 Player
Sansa e250 mp3 player
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jul 19, 2008 | SanDisk Sansa e250 MP3 Player
Freezing
let the mp3 sit my mp3 did the same thing to me in schoo so i let it sit for some time
Jul 08, 2008 | SanDisk Sansa E280 MP3 Player
Did my BATTERY short, or my whole PLAYER?
I have yet to see an Mp3 player that can survive a water drop. You can "dry out" the player, and it may work sometimes. Replacing the battery most likely will not fix.
Apr 15, 2008 | SanDisk Sansa e260 MP3 Player
MP3 player not working even though its powered up keeps shutting off
hi,
it seems to be a problem with the battery.,,,i m sure replacing it with a standard one will solve it,,,,
Oct 14, 2007 | SanDisk Sansa e270 MP3 Player
SOUND
Get a new one I am afraid or spend the money to get it repaired. The mp3 needs to be repaired or replaced as dropping it breaks certain parts on the inside of the player. Hope This Helps MichaelAHill
Aug 11, 2007 | Sony Network Walkman NW-E005 MP3 Player
Dropped MP3 player
It depends on wether the MP3 was dropped in water. If it was, it PROBABLY be dried out depending on the severity of the problem. If it wasn't, it's probably broken. If you plan on getting a new one, I suggest an RCA Lyra. They're very durable and tough. I've already dropped it 6 times at school and not one problem so far. Hope it works
Jan 01, 2007 | Creative Labs Zen Micro MP3 Player
RCA TH1101 MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
