Error code sc560 on a ricoh aficio 3228c - Office Equipment & Supplies
SOURCE: ricoh aficio 2022 error code sc542
I have a Aficio 551/700 and the display reads SC124 anyone have a suggestion on how to re-set this
Thanks
ES...ASD
Posted on Feb 08, 2008
munybuny
  • 14 Answers
SOURCE: Error code SC305 for copier ricoh aficio 1224c
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
Posted on Jun 22, 2008
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Posted on Feb 24, 2009
bosegautam11
SOURCE: Ricoh Aficio SP C411dn error SC542
Ricoh Aficio error SC542
Posted on Sep 26, 2011
Ricoh aficio 3228c error sc 873
Thats a hard drive error. Initialize SP5-832-008 or replace the HDD! Most machines use a simple IDE HDD. Just open the machine at the back, youll see the HDD
Jul 18, 2014 | Ricoh Aficio Office Equipment & Supplies
We connected 2 computers to our Ricoh 3228c nd now it prints everything in code, how do we fix this?
make sure you are using the right print driver and if using a mac need postscript to print
Jan 03, 2014 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
My ricoh aficio 3228c will not print in color
check your printer preference setting in computer driver you will see default set to black and white. select doc then select printer goto printer preference and select color
Feb 21, 2013 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
While trying to print, my Gestetner DSc435 is displaying a functional probelm sc560.
Some expert may give the exact answer but according to my knowledge SC 5XX error code series indicates a problem in fuser or paper feeding sections.
Aug 29, 2011 | Ricoh Aficio 450 Copier
Ricoh 1035. The moment you turn the photocopier on it reports error code SC560 suggesting i should call service agent or the supplier. what could that be please???
Enter in the service mode Yellow key-107-red key,enter in the SP mode open the front door,turn off the copier,unplugged,wait 10 sec.,pluged on close the front door and turn on the power switch.
Nov 08, 2009 | Ricoh Aficio 1035 Copier
Ricoh 3228c error code 375 but only when i try to print color
Your yellow is the culprit. try reseating the yellow developer unit and or drum unit. if still codes replace the yellow developer unit.
Oct 17, 2009 | Ricoh Aficio AP3800C Laser Printer
Cause for error code sc560 on ricoh ap3850c
H there below is what is stated in the service manual and I suggest to change the power cord before the main PSU (Power Supply Unit)
SC 560 Zero Cross Error
When the power switch is turned on. The machine checks how many Zero-cross signals are generated during 500 ms. If the number of Zero-cross signals is more than 66 or less than 45 and the condition is detected more than 10 times this code is shown.
Cause is electrical noise in the supply from the power cord.
Solution
  • Change to another power wall socket
  • Change power cord
  • Replace main PSU (Power Supply Unit)
I hope this help you
Thanks J
Jan 12, 2008 | Ricoh Aficio AP3800C Laser Printer
129 people viewed this question
k24674
jasbo
jasbo
