Question about Maytag Dishwashers
Soap dispenser door not always opening, rinse aid not being consumed
  • Maytag Master
  • 43,501 Answers
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Posted on Mar 31, 2011
Why does it keep dispensing soap?
What do you mean "keep dispensing soap"? Is this a GE dishwasher with an automatic soap dispenser? Or do you mean that the soap lid won't latch or stay closed? Or are you talking about the rinse-aid dispenser leaking rinse-aid (which is fairly common)?
May 11, 2015 | Dishwashers
Dishwasher suds up and leaks during wash
Suds in a dishwasher usually come from using too much soap or the wrong kind. Soap can build up over times causing problems. First start a cycle.Do not add detergent or any dishes.When it starts washing, pour a cup of vegetable oil directly into the tub. This will cut the existing soap suds. You may need to try this a couple time before the dishwasher will drain. After all suds have been removed, load you dishwasher and start a cycle filling the detergent cup up half way. If it goes through the cycle with no problems, you should be all set. Still have the problem? A rinse aid dispenser that dispenses too much rinse aid will also cause the dishwasher to suds up. You can remove the dispenser from the door, flush it out and reinstall. Make sure you turn the circuit breaker off before taking the door apart. After rinsing it out, do not add rinse aid. Try the dishwasher and see if the problem goes away. I've seen people accidentally put liquid dish detergent in dispensers too. A dishwasher that has suds is apt to leak. Fix your suds issue and you most likely will fix you leak
Dec 27, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Dispenser door not opening, therefor tablet not being dispensed nor is rinse aid
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
heatman101
Sep 04, 2011 | Indesit 23 in. DV62 IX Built-in Dishwasher
Ecomax 400 400-17 Glasswasher is not drying glasses completely. Streaks left on glasses
It sounds like the rinse aid has run out or is not dispensing. streaks on glassware is the usual symptom of this. Check and refil the dispenser. On the final rinse, open the door and you should see soap foam , which will let you know the rinse aid has ejected, or alternatively, if you havent had to fill the dispenser in a long time, I would say its not ejecting. these are not usually repairable and you will have to purchase a new rinse aid dispenser from the manufacturer. I always suggest usung " finish" rinse aid, its the best.
Jul 31, 2011 | Hobart Dishwashers
Greetings from Downunder, i have a HDWSE12 dishwasher Rinse aid light flashes all the time and it won t go. I put dish liquid in rinse aid container - still flashes. Don't normally have to use rinse...
the rinse aid compartment has to be one of the biggest things in your unit. it helps with drying process or you will have wet dishes, helps with spots, and also with the cleaning process, this is what you can do . add jet dry or rinse aid not soap .fill compartment then close door ,then raise and lower door 3times then open the compartment door and add more repeat this process until you cant add anymore. this will pull all of the air out of the dispenser and allow you to fully fill compartment . the light should go off .
Mar 04, 2010 | Dishwashers
The some dispenser and the rinse aid dispenser seem to be "stuck", soap door doesnt open and dishes appear streaky from no rinse aid. this happened after I cleaned the deposits from under the screen in the...
There is a solenoid which pops open the soap lid after the initial rinse.
If the solenoid or soap lid latch is faulty, you will need to replace it. In the interim just poar your soap in the bottom of the dishwasher tray before cycle starts.
Only use a little amount as per normal. Dishwashing tablets are best as it is a measured amount and has the rinse aid built in.
Good luck.
Ash
Oct 21, 2009 | Bosch Dishwashers
My Miele dishwasher does not get the plastic refridgerator items dry
Hello Zipmap0202,
I have never found that plastic dries very well in my Miele dishwasher as well.
Check your rinse aid indicator to see if it is on. Next to the soap door there is a door you can add rinse aid to. There is also a dispensing control knob that allows you to turn the amount of rinse aid dispensed up or down. Try changing the setting and see how that works. I have done this and it has not worked well for me. I find opening the door after the cycle is done (Just cracking) it will dry plastic alot better
Sep 16, 2009 | Miele Optima G2430SCi Stainless Steel...
Soap dispenser will not open in dishwasher
depending on the model and make of the dishwasher you're going to have to determine if it the control which actiavtes the soleinod of the wax motor that springs the dispenser door open and later in the cycle it also dipenseces the rinse aid
Dec 19, 2008 | Dishwashers
Bosch dishwasher SHU66C02UC - Rinse Agent issue
Does soap draw open at right time?
Same solenoid opens soap draw as injects rinse aid.
Turn up hardness counter ?
Any blockages in dispenser unit its-self?
OTHERWISE CALL IN THE PROFFESIONALS !
Apr 09, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher sending out bubbles
There is a plastic strip that runs between the lower panel and the upper panel you can pull the strip off then take the outer panel and cardboard out you will see the rinse dispenser there. open the door and take the rinse cap off the dispenser and push all of the plastic tabs in at once and pop the dispenser out. now you can clean out the dispenser and put things back together.
Dec 18, 2007 | Kenmore 17252 Free-standing Dishwasher
Dishwashers Logo
137 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
