Question about Gateway FPD1530 15" Flat Panel LCD Monitor
Gateway monitor fpd1530
My screen goes off randomly and comes back on by itself opr i have to turn it back on
  • 105 Answers
There are multiple curcuits for this model.
Quick turn off of the backlight can be caused by deteriorated solder connectiond on Q6 & Q10 on the power supply/inverter board. Resolder and reassemble. (board mfgr: BI Electronics)
Monitor Mike
Posted on Oct 02, 2008
My gateway fpd1530 comes on then goes right back off any sugjestions on repair or is it worth it?
15? not likely.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
May 15, 2010 | Gateway FPD1530 15" Flat Panel LCD Monitor
Monitor comes on for a second then goes off. Power light stays on
You say you can still see the screen if you look close enough. The only thing that gives it more light is the backlight. It is either shorting itself out right after it comes on or the device that powers it (usually the inverter) is the culprit.
Jul 23, 2009 | Gateway FPD1530 15" Flat Panel LCD Monitor
Installing monitor problem
The Gateway FPD1530 is plug and play and should be automatically detected by the Operating System. In your display properties it will say plug and play monitor as Monitor type.
Jan 08, 2009 | Gateway FPD1530 15" Flat Panel LCD Monitor
Gateway fpd1530 15in flat
There are more than one inverter circuit for this model. One is prone to have poor solder connections in the transistors Q8 & Q10.
Another can be repaired by replacing 2 1uF electrolytic capacitors near the center edge of the board between the lamp sockets.
Monitor Mike
Nov 15, 2008 | Gateway FPD1530 15" Flat Panel LCD Monitor
My Gateway FPD1530 will not turn on
replace c106 and c107. fixed 3 monitors back to back, all worked like new!
Aug 27, 2008 | Gateway FPD1530 15" Flat Panel LCD Monitor
Gateway fpd1530
Not sure about these screens but they should be button on the front that says auto. Press this and the screen should set itself up optimally. Usually does but I have not seen one of these before
Mar 07, 2008 | Gateway FPD1530 15" Flat Panel LCD Monitor
Gateway FPD1530 15" Flat Panel LCD Monitor Logo
131 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
