Question about Whirlpool Dishwashers
Water will not dain after washing - Whirlpool Dishwashers
    Genius:
  • 3,422 Answers
f the water doesn't drain from your dishwasher, check these:
Drain line/air gap
Pump
Drain valve and/or solenoid
Belt
Motor
Timer
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Posted on Aug 05, 2008
Samsung washer ND code and not drain and spin
Sounds like control Board isn't sending voltage to pump. Most likely a control issue.
Nov 03, 2017 | Samsung Washing Machines
Washer works but will not drain
Get a wet/dry vacuum and suck the hose clean form the waste end.
Nov 30, 2012 | LG WM-2277HW Front Load Washer
Not yet finish washing the waters go to dain
Choose another program and watch if the same issues come up . If so there is fault in the program controller unit , Make sure to check motor and all connections to the connectors to be tight.
Jan 21, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer not draining
check that the water pump is working / running if it is check for blockage you will need to get to the pump identfied by the swan neck dain pipe that is attached to it
NEVER ATTEMPT O OPEN MACHINE CASE WITHOUT REMOVING POWER PLUG FROM MAINS SUPPLY
Jan 16, 2010 | GE WSXH208A Front Load Washer
Will not drain and spin....just stops after wash
Take bottom panel off and there is a twist off cap to clean out the dain/pump.
Nov 25, 2009 | LG WM1814CW Front Load Washer
Doesn't seem to fill with water. Maytag MDB6000AWW
if the washer is not flooding the floor or room turn it off the pull you dain hose up from the drain tube you should here water coming out.once the water stop keep the hose up but do not pull it out of the wall and restart the washer it should then fill up to the proper level and then start washing. i hope this helps please let me know
Sep 27, 2009 | Maytag Dishwashers
Leaks out bottom somewhere
Hi, Check the pump. Sometimes they under the base. Your belts will be wet if the pump is leaking. Also check the dain hose outside the machine. Put water in ans then put it in the spin cyclw. You should be able to see where the water is coming from.
I hope this helps you. If I can assist you further, please let me know
Vic
May 23, 2009 | Washing Machines
Wont fill up with water it drains out before its full
If you hear the motor running when it is draining then you have a bad timer. If it just drains out and the motor is not running then you have a siphon problem which is caused if the drain hose is too low. Let me know what you find.
Dec 03, 2008 | Roper RAS8445KQ Top Load Washer
Dishwashers Logo
214 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
