Question about Haier HDP18PA Stainless Steel Free-Standing Dishwasher
Middle spray arm
Can't find collar number for this specific item
  • Anonymous Sep 10, 2008
    Trying to find part number so I can order a new (white) spray arm that is located under the top shelf of this protable dishwasher?
  • fredprincen Nov 02, 2008
    Do you known the number???
    Thanks
    New Friend:
Not fixed yet.. I dont have the part or know what to order yet!!!
Posted on Oct 10, 2008
  • 3 Answers
Yes, we got the correct number and ordered the part... thanks
Posted on Aug 06, 2008
SOURCE:
What is turning
Could be a couple of things.
If you are sewing a new collar, turning is done after you've sewn three edges together and then you turn the item so the right sides are out and the raw seams are enclosed inside the collar. Then the collar is attached to the garment using the fourth (unsewn) edge.
https://www.craftsy.com/blog/2013/12/sewing-perfect-collar-points
How to Sew Collar Points Melly Sews
Or turning on an old, worn garment is when the collar or cuff is unstitched from the shirt and then flipping it over so the worn part is on the underside and the fresh, clean part is facing up (as against the neck edge or, in the case of a cuff, against the arm). This is an idea from the depression era when people wanted to get more use out of an item that was showing wear.
Turn shirt collar
Oct 02, 2016 | Sewing Machines
I removed the lower spray arm and cleaned out a lot of stuff. I noticed when I screwed the sprayer arm back on medium tightness, then the arm does not move freely. Any ideas? thanks
I just looked up your kenmore dishwasher on repairclinic.com. They give free repair help that is model number specific. You may have bent the arm assembly or the retainer is still too tight. Could be it's simply worn. The replacement is about $32. Check out the self help on this site and enter your model number. Good luck.
Jun 16, 2015 | Kenmore Dishwashers
Show me proper spacer placement on rear axle of 2002 hd duece
The axle enters from the disc brake side through a collar (washer with a cut out on it, axle adjuster bolts sits in cut out), through the swing arm, through the plain spacer, then through the wheel, then through the spacer that has a type of grouve in the middle of it, through the swing arm and finally through another collar, then a washer and finally the axle nut. Nut torque is 60 - 65 ft/lbs. Do not exceed 65 ft/lbs or wheel bearing damage will occur.
Oct 04, 2014 | Harley Davidson Motorcycles
The middle spray arm isn't rotating
There is a pipe/tube that runs up the back of the inside of your dishwasher. This provides water for the top spray arm. The spray arm has a feeder tube that covers the pipe in the back. If for some reason the feeder tube has come dislodged, the water just drips back down into the dishwasher, never touching your upper shelf. My kids used to jam cutting boards and other large items into the lower shelf and in so doing, would dislodge the upper spray arm feeder tube. Just pull out the upper shelf and check to see that the tube is in the correct position. This should solve the problem.
If not, then the spray arm may have debris in it that keeps the water from being forced through the jets. You'll need to flush the arm with the spray attachment on your kitchen sink. I sometimes use tweezers or a toothpick to dislodge bits of peelings, paper, or bone that manage to get into the sprayer arm.
I hope one of these tips helps. If it does,please come back to fixya and rate my answer.
Jul 04, 2011 | Frigidaire Dishwashers
Middle spray arm clogged
no it cant to clean a dishwasher good the best thing you can do is run lemeshine often found at a publix or wallmart in the dishwasher detergant isles . if you try to sepperate the arms ther is a very good chance you will break the water tight seal and it cannot be fixed without replacement.
Jun 02, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwasher-bottom arm not spraying
The spray arms can usually be removed by unscrewing (clockwise or counter clockwise depending on brand and model), or squeezing a retainer to release the arm. Before removing the spray arm, place the spray arms (all) in a specific position and activate the dishwasher for a few seconds with wash action. Then examine the position of the spray arms to determine if there was movement from the spray arms. If not, then the spray arm(s) are probably clogged and restricting water flow (which makes them turn). Make certain that you are positioning the plates, glasses, etc. in the dishwasher so that they have access to the water. If still no luck, contact an appliance service company.
Feb 20, 2010 | Jade RJDW2470A Free-standing Dishwasher
The diswasher arm does not rotate or spray water
Check the small holes on the spray arm. They are most likely plugged. (candy wrappers, tooth picks, popcorn or watermelon seeds, you name it.) Sometimes you can clear the holes out, other times it is just as easy (and not very expensive) to replace the spray arm(s). List your model number if you need part numbers or instructions on removing spray arm.
May 14, 2009 | GE 24 in. GSD2000Z Built-in Dishwasher
Kenmore DW model 15999 Lower Spray Tower Came off
Yes, I was able to get it fixed.
The spray tower actually fits in the rack (I had thought it fit in the top of the lower spray arm - wrong!)
If you were to look at the spray tower itself, it has 2 little clip like plastic protrusions that with a little twist will clip onto the lower rack!
Push the lower rack in and you can see where the center would be, (right over the middle of the lower spray arm ).
Now pull out the rack and take the spray tower and slip it under the rack up thru the bottom in the position you noted was the center (from above).
Now with the spray tower in place, slide the rack back inside the dishwsher and you will see that the tower will be sitting directly over the top of the exact middle of the lower spray arm.
Voila!
Nov 22, 2008 | Kenmore 24 in. 15999 Built-in Dishwasher
Fisher turntable M-720 need to set weight and return levels
Hi mariahom
Setting the tracking force is an easy task. Try this method.
  1. first thing to do with the tone arm sitting above its rest, rotate the weight on the end of the tone arm until the tone arm is balanced in the middle. neither up nor down, just right in the middle.
  2. calibrate the numbered rotating collar on the weight so that 0 is exactly on the reference line on the tone arm.
  3. then turn the weight and numbered collar together to the tracking force that you are seeking. Most moving magnet cartridges need at least 1.5grams of weight. Set it for 2 grams if you are unsure of what your is or needs.
  4. adjust the anti skate dial(if you have one) to the same number as the tracking force you are using.
At this point you should be able to gently bounce the tone arm on your index finger(not above the record of course). This is about all there is to it.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jul 13, 2008 | Fisher Audio Players & Recorders
Spray arm not attached
You may have stripped the threads on the spray arm or spray arm support. I believe the threads are reverse-threaded and since they are plastic, can easily be stripped if turned in the wrong direction. This has happened to me before. The solution is to replace the lower wash arm and spray arm support. You can find the parts at repairclinic.com. Just type in you model number and look for item numbers 830883 (spray arm support) and 9040141 (lower wash arm). You may also want to check out searspartsdirect.com as well. The parts will be located under the "Lower Washarm and Strainer Parts" section. The two sites do offer comparable pricing. Post back if you need further assistance. I hope this helps you.
May 04, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
Haier HDP18PA Stainless Steel Free-Standing Dishwasher Logo
99 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
 Doug
Doug
Your Consultant
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
