Can't get into windows xp after startup - Computers & Internet
  • 942 Answers
Try to turn off the pc. Then remove the cables and battery on the laptop and then press and hold the power button of your laptop can't get into windows xp - ryanpajaro20_12.jpg for 8 secs. Then , reinsert the cables and battery of your laptop. Turn it on, and if there is power on the laptop and still you cannot boot to windows xp, consult your laptop provider to perform file back-up for you. The file back-up is dependent on its PC brand (DELL, HP).. they have different procedures on how to back up the files for it..
Posted on Mar 31, 2011
After I power on HP Hewlett packard laptop what keys can I use to access startup menu
If you mean BIOS startup menu, DEL or F1
if it's windows startup menu
for XP your computer restarts but before Windows launches, press F8
For Windows 7, follow this tutorial
Need to Start Windows 7 in Safe Mode Here How
For window 8 follow this tutorrial
5 Ways to Boot into Safe Mode in Windows 8 Windows 8 1
If you means something else by startup menu, please be more specific
May 12, 2015 | HP Computers & Internet
NTLDR is missing is displayed when i turn on the computer
The "NTLDR is missing", error displays very shortly after the computer is first started; after the Power On Self Test (POST) is complete. Windows XP might only initially load when the NTLDR error message appears. Causes of this error message include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Get more help and information for Windows XP hope this helps you.
Mar 01, 2011 | Microsoft Windows XP Professional
I have a hp pavilion 2120tx with windows 7 and i want to dual boot windows 7 and windows xp [windows 7 first]
You can create a Dual Boot in ur machine....
C: XP
D: or E: or F: as Win7
You need to re-format your disk, back up all critical data in your disk....
once done...boot with XP disk in CD drive....
after format, create multiple partitions....C: , D: , E: etc as per your preference
install XP in C:
once done...start PC and let the machine boot from C: XP...once you get Desktop in XP
install Win7 in D: or E: as prefered....once done..
in the startup screen you will get these 2 options
1 load earlier version of Windows
2 Windows 7
to make Win7 as default, right click on My computer (Win7), Properties / Advancd System Settings / Advanced Tab / Startup and Recovery / Under System Startup - Chose the Default OS by the down arrow and the time to it must be displayed in the startup to chose the OS....by this method you can chose Win7 or Xp to load...make your choice as prefered...
reg
for more info on formating and loading OS visit my site
www.sureshayyar.110mb.com
May 08, 2010 | Computers & Internet
Im using windows xp sp2 and my startup is incredibly slow. im using alienware themes and alienware dock starts on startup.other than that ive changed the startup tune to something i converted on my own....
Sounds like you are running out of ram for the program. Try upgrading to some more ram in your system. Windows xp recommends minimum 512k of memory to run.
Dec 29, 2009 | Microsoft Windows XP Professional SP2
My daughter (aged 12) has loaded a copy of Vista (which were discs from a computer her grandmother no longer owns and has been scrapped) onto her laptop which had Windows XP installed. She does not have a...
Hi.
If she did not format the hard disk, then the Windows XP startup option will be present in boot option. When computer startup you will get a choice like this:
1 Microsoft Windows Vista Home Edition.
2 Microsoft Windows XP Professional SP2
In that case you can restore XP, starting on XP and editing the file winboot.ini, that is an hidden system file located on C:/ drive.
See:How to edit the Boot.ini file in Windows XP.
If instead Windows XP does not start, or if you do not get the boot option, that means that Windows XP system file had been deleted.
In that case the only way to get back Windows XP is reinstalling the system from scrap, using a Windows XP install disk, and the number listed on the licence sticker.
Regards.
Oct 23, 2009 | Microsoft Windows XP Home Edition
MS WIndows Startup Clean Up
Click Start > Run > msconfig > click Startup Tab and then go through the list. Items that are checked will startup.
Jun 30, 2008 | Microsoft Windows XP Home Edition
Startup problems
this is telling you that a Scan/checkdisk program is running.
to get rid of this, run scandisk within windows, also go to Start/all programs/startup and remove from the startup if applicable.
to bypass on boot-up, simply press enter beefore the program Starts to run.
Mike @ compurepair.
Mar 08, 2008 | Computers & Internet
WINDOWS XP STARTUP
remove it from start up
start > programs > startup right click and delete the program
if the program is not in the startup the you have to go into the registry with regedit
Jan 04, 2008 | Microsoft Windows XP Professional With...
Installing widows XP
first, have a WIN XP startup disk...created by (in windows)  inserting floppy and right clicking choosing format and select option "create MSDOS startup disk"
first backup all personal files...then restart and bypass to DOS screen at startup...try using F8 key just after BIOS screen...then select startup to DOS prompt only...then run (from the floppy disc) format c:
now you should have a nearly bare hard drive. repeat above steps and this time choose "startup using CDROM drivers"...then insert CDROM and redirect to that drive letter (d drive?) and run setup.exe.
Oct 30, 2007 | Compaq Presario C552US Notebook PC
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
