Question about HP LaserJet P2055d Printer
Paper jam in cartridge area - HP LaserJet P2055d Printer
This is not much information. Have you tried just opening the cartridge cover to check under the cartridge? What is the error code showing on the display?
Posted on Mar 31, 2011
Hp LaserJet Pro 400 paper jam in cartridge area
Clean all of the rubber feeders with alcohol/rubber restorer in the paper path of printer.
Sep 14, 2016 | HP Laserjet Pro 400 Mfp M425dn...
Piece of garbage jammed again, removed the jammed paper and am still getting error that it has a jam in cartridge area. I have taken out the cart. and blown it out with air and also took the back off and...
Hello denelson994,
Welcome, and thank you for using FixYa!
Your issue has to do with the paper sensor flags just under where the cartridge is inserted.
If there is paper or dust in that sensor(s), the printer will interpret that as a paper jam. Grab some canned air, blow everything out, and then physically examine those sensors under the cartridge area.
If the sensors were dirty, they should work now. If the "Flag" (plastic lever) that is pushed down as paper passes over it, is broken off; the sensor(s) will have to be replaced.
Make sure you flip up or back, any metal plates you can, to look for paper shreds or dust under them as well.
Have a great day!
Sep 12, 2011 | Dell 1815dn All-In-One Laser Printer
I've got a 4 by 6 photo paper jam in my Lexmark S405 all-in-one printer.
Please follow the steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Try to reach for the paper jam.
3. If paper jam can't be reached, open the printer cover to access the cartridge area. You may be able to get a better hold of the paper jam in the cartridge area.
4. Remove the paper jam and make sure not to tear or leave any torn piece of paper in the printer.
When paper jam is clear, try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 01, 2011 | Lexmark All-in-One Printer with PictBridge
LEXMARK IMPACT S 305 A 5 PAPER JAMMING, HOW DO I REMOVE IT, THEIR IS NO WAY IN VIA THE BACK.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path. Open the scanner unit or the printer cover.
  4. If you can see the paper jam, the cartridge area should give you enough space for your hand to reach on the jammed paper in the printer.
  5. Carefully remove the paper jam and make sure not to tear or leave torn pieces of paper in the printer. It can cause future paper jams.
  6. When the jam is cleared, close the printer cover.
  7. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
  8. When the printer turns on, try to print again.
Aug 19, 2011 | Lexmark C533DN InkJet Printer
I have a problem. When I turn on my printer, the first symbol from top constantly blinks and it doesn't print anything. How can I solve this issue?
Welcome to FixYa!
If the first symbol on the top is constantly blinking as shown in the picture below, It means that a paper or a foreign object has jammed your printer.
Jam can occur in 3 areas. Please refer to the image below.
1. Internal Areas
2. Input Trays
3. The Output Bins
To clear the jam, turn the printer off and disconnect the power cord. Be careful not to tear the paper in case of a paper jam. If a small piece of paper remains in the printer, it could cause additional paper jam.
Let's clear out the Internal Areas first. Push the button to open the print-cartridge door, and then remove the print cartridge. To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper. Please refer to the image below.
If jammed paper is visible, grasp it with both hands and slowly pull it out of the printer. Please refer to the image below.
If no paper was jammed inside the print-cartridge door, open the Output Bin or the back door
of the printer. To avoid damaging the printer, do not attempt to clear a jam in the top output bin by pulling the paper straight out.
Again, if jammed paper is visible, grasp it with both hands and slowly pull it out of the printer.
If no paper or foreign object is visible, close the back door of the printer.
Next, let's take a look at the Input Tray. (We have already taken out the print cartridge.)
Lift the Tray 1 roller cover, grasp the jammed paper or foreign object, and slowly pull it out of the printer. Please refer to the image below.
If no jammed paper is or foreign object is visible, open Tray 2 and see if a paper is visible. Again remove it slowly with both hands. Please refer to the image below.
Close Tray 2.
If no jammed paper is visible in the second tray area, pull down the upper media guide (we have already taken out the print cartridge). With both hands, grasp the jammed paper and slowly pull it out of the printer. Please refer to the image below.
Close the upper media guide and return back the print cartridge. Please refer to the image below.
These steps should clear out any jams that you are experiencing.
Connect back the power cord again and turn on your printer. You should be able to print now.
Thanks for using FixYa. Keep me posted.
Jas247
Mar 03, 2011 | HP LaserJet Black-and-White Laser Printer
What does the "heart beat" symbol/light mean?
I assume you mean the symbol that has a pair blackened circles and then a pulse up and then down below the starting line before returning to the starting line.
That is the paper jam symbol. If the continue light is on (steady) and the paper jam light is on, then you have a paper jam. Press Continue twice to see any secondary error message (this will show where the problem is).
See the manual for the list of the lights that show where the jam is occurring. Different groups of lights will be lit. The manual is available as a PDF at the bottom of this page: http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN . An example: if the Continue, Toner Low and Paper Jam are all on, then the jam is in the fuser area under the print cartridge assembly. For a paper jam, even a small corner of torn paper could be in the mechanism.
In all cases, you should check the entire paper path. When you pull out any paper, grip it so that you can gently pull the sheet straight out. Remove all paper from the output tray. Then remove the paper tray if you are using it. Pull any paper from this area. Press down on the green duplex flap and remove any paper from there Reinsert the paper tray. Open the front door of the printer and remove the print cartridge assembly. Lift the green flap and remove any paper from the area. NOTE: the fuser and the fuser area may be hot. Open the rear exit door and remove any paper from that area. Use a flashlight to check for small pieces of paper that may be stuck. Once all the paper is removed, reinstall the print cartridge assembly and close all the doors. Press Continue to reset the printer.
The page that jammed may be reprinted.
I hope this helps.
(please note that frequent paper jams may be a sign of excess humidity in the paper. Put less paper in the tray at each refill and keep the remaining paper in a dry location. If the paper jam light is coming on when no paper jam is present, one or more of the paper jam sensors may be bad. Contact Lexmark for more information.)
Nov 30, 2010 | Lexmark E250dn Laser Printer
I have a samsung scx 4200 am getting the papaer jam error even when theres no paper jamed up there
Good Day Sir,
when paper jam occurs, Paper jam appears on the display.
Message Location of Jam
[Paper Jam 0] - In the paper input tray
[Paper Jam 1] - In the fuser area or around the toner cartridge
In the manual feeder
[Paper Jam 2] - In the paper exit area
hope this will help you. god bless
Nov 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Jam in top cover area
Replace your paper pickups and set your paper tray setting correct, both in the tray and the settings menu. That should help you out. The part# for paper-pickups is RF5-3739.
Mar 17, 2009 | HP LaserJet 4600dn Color Printer
I have PIXMA MP 600 PRINTER that has a paper jam as I fed used paper back into it /ink was still wet and apparently paper has stuck together and jammed. How do I clear
clear the jam paper
1) pull slowlly the jam paper back as possible as you can, usually the jam paper could be broken as pulling
2) open the cartridge area find the paper pull slowlly forword paper direction as possible as you can and try to take out any pieces paper behide the cartridge (between paper input roller and ink cartridge
Jan 24, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Paper jam
Hi usually paper jam at paper input area a or transfor section(photo drum area or fuser unit area, so you may try:
1) take out paper tray and open the cover that you can change toner cartridge there (see manual) looking for any paper inside paper input area or around the cartridge, then take out jam paper.
2) open fuser unit at paper output area ckick a locker at somewhere (see maanual) looking for any paper jam
Dec 22, 2008 | Canon imageRUNNER 1310 Printer
HP LaserJet P2055d Printer Logo
491 people viewed this question
Seeker5211
Seeker5211
