To fill tub with hot it makes humming noise only, turn to cold to fill tub cold water only
  • Washing Mach... Master
  • 43,501 Answers
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Mar 31, 2011
Kenmore series 80 newer won't fill spin or agitate just hums on cycles and makes no noise on spin cycle
Are you sure the water is on and water is getting to the machine.
If there is no water the water valve will open & hum & nothing else will work till the tub is full.Check the little screens on the water valve behind the hot & cold hoses where they hook up the the machine they get clogged
up sometimes just pull them out and clean them. Hope this helps you
Jan 05, 2018 | Kenmore Washing Machines
My shower won't switch on at all and the flow dial makes a humming sound when turned . any advice please .
check your tub diverter (spout that fills tje tub). then check the cartridge in the water (hot n cold) faucet.
Jun 03, 2016 | Home
Washer hums but will not fill or start/ spin has water pressure and tub seems to move freely the model #on tag LTF2140ES0
If it doesn't fill it won't start any other cycle unless you move it ahead yourself. If it hums I am thinking it is trying to fill. Sounds like the valve is turning on to let water in but it is not getting through. My washer has a screen where the hoses go on and sometimes the screen becomes plugging with scale. If that is ok then the solenoid must be coming on but the valve is stuck. Does neither hot or cold settings work? Please rate my answer so I am rewarded points for it.
Jan 27, 2012 | Frigidaire Washing Machines
Water comes up to tub but doesn't fill the tub. Help and when I pull the knob I hear a humming noise
Hi and welcome to FixYa, I am Kelly.
The humming noise your hearing is the inlet water valve solenoid. Before proceeding try switching between warm cold and hot to see if any of those selections give you water. If you get water on either hot or cold then you probably have debris in the inlet screens of the water valve where the hoses connect. Turn off the water. remove BOTH hoses noting hot and cold installed positions and the use a thin knife blade on the outer edge of the screens to lift the inlet screens out of the water valve body. Wash then under slowly running water rubbing them between your fingers. Reinstall the screens. Connect the hoses in their original positions, turn on the water and test your water fill again switching between warm, hot and cold. This should get you going. If your still having problems after doing the above; please respond with MODEL: number and I will help you.
Thanks for choosing FixYa,
Kelly
Feb 17, 2011 | Maytag Washing Machines
Will fill with cold water but not hot
the hot water inlet valve is shot replace it
Apr 27, 2010 | Maytag Atlantis MAV7551 Top Load Washer
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Machine stops at rinse cycle and hums
check the setting of the water temp for the rinse cycle. If one of your water supply valves is closed (HOT/COLD) the tub cannot fill with the proper water temp selected. The hum noise you are reporting is associated with the fill solenoid valve located in back of the machine.
Also, I have found the problem to be the screen located in the fill valve clogged with rust and water deposites. Disconnect both water lines and verify the water supply is not restricted.
Hope this helps..
If not, a more thural description of the problem may reveal more clues to assist in troubleshooting.
Thanks and good luck...
Apr 26, 2009 | General Electric Clothes Washer Timer -...
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Washer tub will only fill on the hot setting
Is the tap to te cold water turned on
I would check that
Jan 13, 2007 | Maytag MAV3905EWW 13 Cycle Washer
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
