Question about Sony Ericsson Cell Phones
W550i lost ribbons cable connection - Sony Ericsson Cell Phones
Replace it
Posted on Sep 05, 2008
Replace it
How did you know u'd lost ribbon connection?
Posted on Dec 27, 2010
Where can i get ribbon connectors for sony stero system part#26AWG THE END OF THE CONNECTED IS BROKEN OFF
I doubt at this point you will ever find a new one but hope is not lost entirely. Since these are not high current cables the possibility exists to solder the one end of a ribbon cable to the board and then attach a dB connector to the cable for interconnection and taking the system apart. This would solve this problem. In fact ribbon cable of different types can be obtained new and this might be a good upgrade to do as most dB connectors are made with Gold flashed pins. The trouble is not many technicians will want to do this for cheap.
Oct 24, 2012 | Audio Players & Recorders
How to flash my sony ericsson w550i
to update your phone follow these steps 1)--CONNECT PHONE(K750I CABLE)
2--SELECT MODEL
3) SELECT MCU and CUST/fs
4)TEST POINT BYPASS&TP2
5)SELECT FLASHING MODE------MCU+CUST/fs
6)PRESS GO BUTTON
FLASH MODE STARTED SOFTWARE SHOW CONNECT TEST POINT
(TEST POINT HERE)
FLASHING STARTED SOFTWARE SHOW DISCONNECT TEST POINT
FLASHING COMPLETED PHONE 100%OK thanks
Jun 30, 2011 | Sony Ericsson W550i Cellular Phone
My w550i shows a white screen as soon as i on it... what should i do to fix it?????
Hi this is a very common problem with all flip and slide phones and even laptops and notebooks, the problem is to do with the data ribbon that connects the screen to the circuit board in the bottom of the phone.
now inside this ribbon are several single strand copper wires and over time open and closing the phone causes these to break and you then lose the connection with the screen.
as this is such a common fault it makes the part itself cheap to buy and cheap to get fitted. it isnt something you can do your self as you need specialist tools to take the phone apart and to fit the data ribbon.
if you want it repaired the cheapest place would be one of those small independent phone shops as the bigger one will have to send it off and you will be charged extra for this, the smaller phone shop should be able to fix it whilst you wait or the next day at the latest.
its up to you if you think the phone is worth getting fixed then it wont cost much to get done.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
`15
Oct 05, 2010 | Sony Ericsson W550i Cellular Phone
How to flash sony ericsson w550i
first attach your data cable to your phone
then connect to the sony erricson site
go to firmware upgrade option
then press ok
Sep 28, 2009 | Sony Ericsson W550i Cellular Phone
My sony ericsson w550i isn't getting connected to my pc
When you insert your usb cable to your phone, is it give you phone and file transfer mode. If yes then reinstall pc suite. If no then your usb cable is defective or usb port to computer is properly connected.
Please if you have more any question then reply to this solution if your problem is solved then mark as answer.
Thanks
Nov 28, 2008 | Sony Ericsson W550i Cellular Phone
Softwere instllatin in sony ercsson w550i
Installation instructions
  • Download the file to a temporary folder on your PC.
  • It is recommended to uninstall any previously installed version of Sony Ericsson PC Suite
  • Execute the downloaded file.
  • If updating to a newer version of the Sony Ericsson PC Suite, a restart of the PC may be required after the new installation is completed.
How to use
  • Connect the mobile phone to your PC using an applicable connection: Cable, Infrared or Bluetooth connection.
  • Start the included programs from the Start/Programs/Sony Ericsson folder or the Application Launcher application
try it
Sep 07, 2008 | Sony Ericsson W550i Cellular Phone
Sony ericsson
Try updating the phone trough Sony Ericsson's website. Using your data cable. You have to hold in the c button when you connect your phone to the cable. ( When the update service asks you to connect your phone.) Wait for the update to finish and check to see if it worked. ( Worked for me )
Mar 06, 2008 | Sony Ericsson W550i Cellular Phone
I want to release memory
ur memory is selected to phone memory , kindly change it to memory card , it will solve ur problem else try using via data cable instead of blue tooth
Oct 10, 2007 | Sony Ericsson W550i Cellular Phone
Cell Phones Logo
35 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
