Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
HOW CAN I REMOVE WRITE PROTECTION ON MY USB DRIVE
  • Kingston Master
  • 27,725 Answers
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Posted on Mar 31, 2011
Cannot format usb says write protected but there is no write protection for the usb
Reinhard, Check the attached links,instruction and guides on removing USB write protection, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
2 ways to fix write protected USB drive or SD card
How To Fix Write Protection Errors On USB Stick
How To Disable Write Protection from USB Key
How to remove write protection on generic usb disk drive
Jun 16, 2016 | Electronics - Others
How to remove the write protection in a usb
1.Turn on your computer and plug in the drive after your operating system has loaded.
2.Open "My Computer" and search the list of drives until you find your USB drive letter.
3.Right-click on the name and click "Properties." Once the options have loaded, go through the tabs until you see the option to remove write protection. If this does not work, go to the next step.
4.Visit the company website for your USB drive. Go to the help or support section and search for "write protection."
5.Click on the download section and search for "write protection software remover." Download the program and install it on your computer.
6.Open the software program. Go to "Option" and click "Remove Write Protection" to unlock your USB drive.
>>>>"M.J Trusedell"
Aug 16, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to remove usb write protection
  • 2 Open "My Computer" and search the list of drives until you find your USB drive letter.
  • 3 Right-click on the name and click "Properties." Once the options have loaded, go through the tabs until you see the option to remove write protection. If this does not work, go to the next step.
  • 4 Visit the company website for your USB drive. Go to the help or support section and search for "write protection."
  • 5 Click on the download section and search for "write protection software remover." Download the program and install it on your computer.
  • 6 Open the software program. Go to "Option" and click "Remove Write Protection" to unlock your USB drive.
  • Jan 20, 2011 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
  • 2
  • 3
  • 4
  • 5
  • 6
  • Read more: How to Remove Write Protection From a USB Drive ' eHow.com http://www.ehow.com/how_4924168_remove-write-protection-usb-drive.html#ixzz1BY4ve3fh
    Jan 20, 2011 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
    My 8gb verbatim is write protected. don't know how to remove it
    It has password protection. Open My Computer on your PC, insert the USB drive, open the password file, enter your password, then select the option to remove password protection from the USB drive.
    Jan 10, 2011 | Verbatim CORPORATION 94933 USB 2.1GB...
    My verbatim USB 2 GB is write protected. I am not able to remove write protection. Please suggest to solve the problem.
    It has password protection. Open My Computer on your PC, insert the USB drive, open the password file, enter your password, then select the option to remove password protection from the USB drive. If this does not work, contact Verbatim for a solution, these USB flash drives have lifetime warranties.
    Nov 12, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
    I cannot remove write protection of my transcend 4GB pen drive
    1. Download this tool:
    http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
    2. Format
    (Before removing USB flash drive click on the Safely Remove
    Hardware icon and then click on USB flash drive you want to remove)
    Jan 05, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
    Remove the write protection on 2GB USB Kingston Data Traveler 100
    Found this on Kingston site, doesn't help much but may point you in the right direction.
    Unfortunately this unit does not have any security or write protection feature. If you receive a write protection message with this drive, check for the following:
    1. Verify that you are allowed to write to removable storage devices. There may be a security setting in the OS that disables write access to removable storage devices.
    2. Make sure you have not enabled write protection on the drive by using a third party software.
    3. If none of the above apply, the drive may be defective.
    Jun 02, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
    Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
    136 people viewed this question
    Top Kingston Computers & Internet Experts
    Cleverer2
    Mike
    Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
