Question about Zebra GX430t Thermal Printer
Zebra gx430t printer blinking lights - Zebra GX430t Thermal Printer
4 Suggested Answers
  • 38 Answers
SOURCE: zebra 105se printhead issue
The controller thinks the printhead is still open. If it is open, close it.
If it's closed, it's likely that the sensor flag on the rear of the shaft has come loose and is no longer interrupting the photosensor. Remove the rear panel and inspect the flag while you move the printhead handle. The flag is supposed to be in the opening of the sensor when the printhead is closed and latched.
Steve Weinrich
LazerTek, LLC
Posted on Mar 30, 2008
bartech9
  • 155 Answers
SOURCE: Zebra Z4m+ won't print from Bartender 9.01
BarTender uses its own drivers for each model of printer you must install the correct driver, because there are differences in some commands a printer to another.
Posted on Mar 10, 2009
  • 32 Answers
SOURCE: zebra green light blinks continuously
It will blink when there is power. It will go solid once there is a network connection made.
Posted on Oct 27, 2009
Zebra gx 430t printer when I turn it on the light is blinking green/red
Do a factory reset on the printer.
Check you printer driver settings if you are printing using it.
Jan 14, 2016 | Zebra GX430t Thermal Printer
Zebra GX430t, print two blank label when switch on
this is because printer calibrates every time u power on, this is a default setting, and its good if u using diferent labels all the time. you can change the settings thought driver,and change (when power on - "doing nothing" dont forguet to reboot Thanks Paulo.
Apr 08, 2014 | Zebra GX430t Thermal Printer
How to reset IP address on GX430T label printer
http://www.scanonline.com/pdf/PrintersZebra4/GX420t/ProductDocumentation/980612-001A_GX420tUGen.pdf Here is the manual it will tel you how to go about resetting the Ip address on this printer, If its connect to your RJ45 cable or you have a print server you will need to reset it using other means but this should set you on the path to help here, thanks please do not forget to leave a rating.
Aug 03, 2010 | Zebra GX430t Thermal Printer
Losing half of top line when printing
Label definition in printer driver may need adjustment. Try calibrating printer, printer on solid green light, hold down feed key & release after light blinks 4 times, (blinks once, twice, three times then 4 times) Download the Zebra setup utility and use it to configure printer.
Sep 29, 2009 | Zebra TLP 2844-Z Thermal Label Printer
ZEBRA P310 LIGHTS BLINKING
Seems like you just need to run a cleaning cycle on the printer. Both lights flashing means you have printed a high volume of cards without cleaning the printer. Please purchase cleaning kit 105909-169 to clean your printer.
-- The Pros at www.DiscountIDStore.com
Sep 14, 2009 | Zebracard P420I Thermal Card Printer
Zebra TLP 2844-z green/red light flashing
Check their website. It should let you download the user's manual after you've logged in.
http://www.zebra.com/id/zebra/na/en/index/products/printers/desktop/tlp2844z.4.tabs.html
I work with these at my work-work, and the manuals are pretty handy to have!
Jun 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra green light blinks continuously
Jun 05, 2009 | Zebra S4M Thermal Label Printer
Zebra Z4M only feeds a small portion of the label.
You should try a factory reset. Power off the printer. Hold the "pause" and "feed" buttons down while powering up. Allthe lights will blink and when they stop blinking, release the "pause" and "feed" buttons. This will factory reset the printer.
Apr 24, 2009 | Zebra Z4M Printer
Zebra S500 no print
You can find the manual in www.zebra.com, and try reset, pressing FEED and PAUSE keys and turn on printer, release keys until move labels.
Mar 12, 2009 | Zebra Stripe S600 Thermal Label Printer
Zebra GX430t Thermal Printer Logo
1,078 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
