Question about Pro Line TFP120A (4.2 cu. ft.)
Awful smell coming from back of unit. Discovered drain tray was rancid and overflowing. How do I clean the drain pipe effectively and ensure this never happens again?
  • 126 Answers
Go to a craft store and buy some large pipe cleaners use a ammonia water solution soak the end of the pipe cleaner in this solution then put it in drain pipe work back and forth this will clean and kill any germs/ bacteria in that pipe be sure to wear rubber gloves
Posted on Mar 31, 2011
Testimonial: "many thanks - very helpful"
How do I get rid of awful odor coming from bottom of fridge when compressor running
the coils on the bottom are dirty blow out with air and vacuum. you will have to pull out Ice box and clean from back.
Aug 18, 2014 | Frigidaire : FFHT1715LW Top Freezer 16.5...
Washing machine sewer odor
The drain pipe that your drain hose goes into is more than likely the problem. The drain pipes should have a p trap which looks kind of like an S- shape the water stays in the trap preventing the smell from backing into your home . If there is none, install one.
Jun 09, 2013 | Washing Machines
Cause for burning smell from lower back of upright freezer
your freezer might be having blockage on the drain pipe thus not allowing water to flow on the drain tray if the drain tray is mounted on the compressor and its dry then the compressor or the condensor pipes are burning the drain tray. the solution to this problem is to service your freezer
Jan 23, 2013 | GE Freezers
Evaporation tray at back of stand alone refridgerator is full of .....? and smells. How do I clean it as it is fixed to the back of the fridge?
syringe out drain hole/pipe with clorine bleach(clorine will gas off and leave no smell after an hour or so)clean out tray with bleach,as it will kill the bacteria that causes the smell,the higher the himidity the more often you will need to clean drain/tray.(any clean water in tray ,use to feed your house plants,
Aug 04, 2010 | Zanussi Refrigerators
Fridge smell
It sounds as if you may have had a spillage at some stage in the fridge unit and this has gone onto the tray at the rear of the unit at the bottom on top of the motor.There may be some other explanation when you do pull out the fridge to access this tray.It may be easier to clean the tray in position as they can gat damaged if you try to remove them.If so get some soapy water and a sponge then clean out and dry,also some spray dissinfectant in the tray after cleaning will help.
May 03, 2010 | Zanussi ZEBF277W Bottom Freezer...
Our lg washer model wm0642hw tub clean cycle stops
software problem. regarding smell, after wash keep the door opened for ventilation, use fabric conditioner etc. also check whether any rodent has gone inside and messed up the place
Mar 18, 2010 | LG WM0642H Front Load
There is a horrid smell coming from the back off my candy fridge freezer its a sicky cheesey smell what is it??
little green men from the planet DRAIN PIPE , awful smelly these people.. have lost the ability to flush out drainpipe with clorine beach (only drainpipe NOT INTERIOR OF UNIT)
Sometimes called streptococus..............
Feb 08, 2010 | Candy CPCA240FFK Bottom Freezer...
Central air unit/ Lux500 thermostat
There is usually an overflow tray which has a shutoff valve when the tray is about to overflow water into your house. It is not located outside on your unit but inside where ever the condenser unit is. IF that tray is full of water, your unit will not turn on until it is emptied. Then you need to find out why the tray isn't draining...do you have a blocked drain pipe?
Jun 21, 2009 | Jackson 25 in. TempStar HH70 Free-standing...
Inside rhe house unit is leaking water from around the pvc pipe.
cant understand what you are describing. is the drain pipe clear. water coming out end into french drain or pump. if not clear out by mechanical means or by blowing.
Jan 15, 2009 | Ruud Heating & Cooling
GE UNIT - AC/HEAT PUMP
Hello Cheryl, what they are talking about is a drain. As air conditioners run they collect moisture from the air on the evap(in cooling mode) or condenser ( in heat mode). This moisture will run off the part and flow into the tray. In the cooling mode, the moisture is slung onto the condenser to help cool it down, thus be more effective. I always recommend once a year remove the unit and clean all the coils and oil the fan motor. Household oil will work for this. During this cleaning find and clean out the drain. If it gets clogged that water can run back into the home. The PC pipe is sometimes attached to the unit to direct the water to a designated place. These units are common in hotels and they use the pipe to keep the water from dripping on the guest as they walk under the windows. Hope this helps.
Jul 26, 2008 | GE Heating & Cooling
Pro Line TFP120A (4.2 cu. ft.) Logo
94 people viewed this question
Top Pro Line Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Pro Line Refrigerator Expert? Answer questions, earn points and help others
