Question about Foxconn 45CMX socket LGA775 motherboard (16897)
Hi there, I've got a Foxconn 45cmx mb, A intel Pentium 3.0GHz cpu, 2g ram. I've search for two days now and although I found a lot of similar problems, none is the same. My pc is working fine, I can reset via start button, even a hard reset via the reset button on case, but as soon as I shutdown my pc it will not boot up again. Unless.... I reset my bios. Now I've tried all the other option, replacing the PSU, remove memory, etc.. I suspect that my bios needs to be updated as this was never done before, for the simple reason... I've never done this and done have the money to replace the motherboard if I mess it up. Is there a foolsafe way to do this, or do I have to be content to leave my pc on... or reset bios every time I shutdown? Please help!!!!
  • Foxconn Master
  • 3,606 Answers
Hi, try to replace the cmos battery:
So the bios can remember its settings.
The battery is a watch type 2032.
Once you have installed a new batttery
enter the bios and set the boot sequence
for the harddrive as first boot device
and the cd/dvd as second.
You can download a manual from here:
http://www.foxconnsupport.com/download.aspx?models=&category=C000000001&Series=&keywords=45CMX&sort=
Hope this will help you.
Posted on Mar 31, 2011
I have a motherboard foxconn 45cmx-45gmx-45cmx-k,Will this processor Intel Pentium D 945 3.4 GHz 4M 800 Dual Core LGA775 CPU work on it?
Yes ,this foxconn motherboard will support the above mentioned
processer. Please check the below link.
Foxconn
Thanks for using Fixya.
Oct 12, 2013 | Computers & Internet
45CMX/45GMX/45CMX-K I do not know what video cards and processors are compatible with this motherboard as I want to upgrade my pc
Hello download the manual here:
http://www.foxconnchannel.com/ProductDetail.aspx?T=motherboard&U=en-us0000341
Intel Core 2 Duo, Pentium Dual-Core, Pentium D, Pentium 4, Celeron D, Celeron processors, Socket T (LGA775)
- 1333(oc*)/1066/800/533 MHz (FSB)
- Dual Channel DDR2 667/533/400 x 2 DIMMs, Max. 4GB
- 1 x PCIe x16, 1 x PCIe x1, 2 x PCI
- ATA x 1, SATA II x 4
- 5.1 channel Audio
- 10/100M LAN
- 8 USB 2.0 ports
Good luck
Jun 17, 2012 | Foxconn 45CMX socket LGA775 motherboard...
Characteristics of n15235 manual motherboard
- Intel® Pentium D, Pentium® 4, Celeron D processors, Socket T (LGA775)
- 533/800MHz front side bus (FSB)
- Single channel DDRII 533 / 400 x2 DIMMs
- 1 x AGP 8x, 3 x PCI
- ATA x 2 + Serial ATA x 2 w/ RAID
- 5.1 channel Audio, AC'97 interface (Realtek)
- 10/100M LAN (Realtek)
- 8 USB 2.0 ports
Also, if you need drivers for all that components, use this tool: http://tinyurl.com/n8nrz6t.
regards
Sep 16, 2011 | Foxconn 6627MA-RS2H Motherboard
Foxconn 45gm new cpu monitor now wont work?
sounds like your new processor is faulty or dose not support your board if your old CPU works fine then take your new one back after checking its compatible also with some boards you need to update your bios to get full use of it i have had similar problems that an update solved first if not get your new CPU replaced hope this has been of help
May 21, 2010 | Foxconn 45CMX socket LGA775 motherboard...
No display after restart
bro I am having the same problem!! after searching I found that the pc gets display on my case if I remove power cord and press the power button (and holds on) of pc like 30 seconds and then reconnect the power cord and powers on!! this is how I get back display after restarting pc.
Feb 02, 2010 | Foxconn 45CMX socket LGA775 motherboard...
Is it compatible a intel dual core processor to a
Hi..
If you want to upgrade you unit be sure that the motherboard socket are totally fix with the processor. The compatibility is important because if it is not compatible the motherboard can not support the processor,
Good luck !!!
Regards
PCmania
Jul 15, 2009 | ASUS P5PE-VM Motherboard
UpGrade
you could only upgrade the processor and RAM in this condition i.e.
you can only change your an upgraded p-III processor like 1.0 GHz, 1.1 GHz or 1.3GHz and
upgrade the RAM by changing to 256 in each slot.
that is all what u can do with ur pc
Oct 18, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Troubleshoting on installation of mb foxconn 45cmx
have you placed the 4 pin block to the motherboad and also check the bois clr jumper to see if it's not being shorted this can also cause the board not to boot pluse check ram sticks making sure they are well seated and clean the cntacts from dirt on the ram sticke if al gose well and still no boot then get a converter and try this if all else fail try a ney cpu if same resaults then replace board.
Aug 26, 2008 | Foxconn 45CMX socket LGA775 motherboard...
Installation of foxconn 45cmx
Hi aligmatos, it is suggested that you use a 24-pin main power connector if you are going to fill up the motherboard & use a PCI-Express graphics card & Dual-Core Pentium CPU. The power supply should not be less than a 450W for this board, 550W would be better. You can use a 20-pin main connector but its not suggested. Make sure you connect the 4-pin 12V power connector. Your motherboard should still function with a 20-pin main power connector. Again I would not suggest it.
Main web site for Foxconn 45CM-S
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000328
Search preformed for Recommended power wattage for foxconn 45CM-S motherboard.
http://www.google.com/search?hl=en&q=Recommended+power+wattage+for+foxconn+45CM-S+motherboard&btnG=Search
Good luck aligmatos!
Mike
Foxconn 45CMX socket LGA775 motherboard (16897) Logo
208 people viewed this question
Top Foxconn Computers & Internet Experts
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
