Question about HP Computers & Internet
Hello, I have a 5 year old HP -for some months the fans inside (cooling) have been running louder and much more often than usual. I have done the obvious things ie cleared any dust from the vents etc. Also it has begun switching itself off occasionally with no warning at all, just an instant power cut, but it always starts up again just fine. Could the 2 be connected?
  • 3 Answers
You best bet is to change the fan.
Marvis
Posted on Mar 31, 2011
Why does my pc's power light indicator keeps blinking red (2 beeps) after it powers on and begins to boot, running for about a minute or two?
Hi
This means your PC is doing a Thermal Shut down, the CPU is getting to hot, this means the fan is not running at all or fast enough, or is dusty causing loss of cooling to the CPU.
To fix this open the case look at the fan if its running as it gets louder I would say in your case it is, you need to remove all the dust from the fan and the heatsink I use a small USB fan from poundland (UK) this should stop this error.
Cliff
Aug 22, 2014 | HP Compaq DC7900 PC Desktop
I have an HP G62. I get an error message saying a cooling fan is not working properly - data may be lost, damaged, etc - and then it turns off. The fan seems to be much louder than it did when I first got...
I really suggest that you replace the fan it is not that hard to do. Get a replacement and look for how to do the job online in Google Search engine. There are samples usually at YouTube.com for this type of thing. If you continue to run this computer you may be replacing a mother board shortly now is the time to fix this. If you do not want to attempt it take it into a professional it will cost you a lot less than a brand new computer. I hope this assisted you. Thanks for using FixYa! John
Feb 12, 2011 | HP (344872-001) Laptop Cooler, Cooling Fan
For some reason the fan noise is getting louder on my Panasonic -PT56LCZ7 Projection TV ...the TV is almost 3 years old, and we haven't really herard it until now or within the last 6 months or so. Is...
Hello; A buildup of dust can make the fan noisy. If you clean away the dust, and it is still noisy, the fan needs to be replaced. Hope this helps! John
Nov 22, 2010 | Televison & Video
I have a HP Pavilion dv7, and recently it has been running much louder than usual. I don't know if it is just the fan, or what the deal is. Any ideas?
Hello
OK, usually when there is a noticeable sound difference in the loudness of the fan, overheating is an imminent matter. The reason for the fan noise increasing is due to the dust particles in the fan housing which is preventing sufficient cooling. Hence, the fan needs to have to turn at higher revolutions just to suffice in the cooling.
Now, the solution is to open up the unit and use compressed air to blow out all of the dust particles. This will enable to fan to cool the CPU at a lower radial speed, hence less revolutions per minute.
Please do not hesitate to let me know if you need any further assistance, i will gladly help.
Kind regards
Andrea
Nov 09, 2010 | Computers & Internet
My cooloing fans are running full speed all the time which is very loud and annoying. how can i fix this?
Firs thing you need to do is to find our why they are running full speed. My guess is that your computer is dirty inside and it is overheating, thus causing the fans to run full speed trying to cool it off. Disconnect everything from the pc and take it somewhere to clean it out. Remove the side panel an use a can of compressed air or an air compressor to blow all dust out the interior of the pc. Pay close attention to the heat sink on the processor and the cooling fans. When blowing around the fans hold the fan in place with a pencil to prevent it from spinning as this might damage the fan. You need to clean out the inside of a pc sitting on the floor every 6 months. If you have cats or dogs that shed living inside then every 4 months. If it is sitting up high and you have no animals then every year may be good enough.
Oct 05, 2010 | HP Pavilion a1010n (PS563AA) PC Desktop
Our Amanda refrigerator/freezer has been making noises on and off (buzzing) over the past two months, in particular the bottom freezer. Today everything started to melt and the buzzing is frequent every...
It sounds like your evaporator fan motor, they last about 4-5 years. Try to see if the buzzing noise comes from the motor, usually in the freezer compartment behind a vented cover plate
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). It could be that your drain hose is clogged or frozen. Maybe the temperature adjuster go bumped.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Amana ABB1927DE Bottom Freezer...
Fan in our Sharp "Comfort Touch thru-wall a/c stopped
Unless the Unit can be cleaned ( you claim it cools?) but not enough. The age of the Unit is not in you Question, the amount of time you got for 100 bucks is pretty good being you purchased a USED UNIT. With the type of use you claim Running 24/7 and about 5 months of cooling - I'd say you never cleaned the Unit from day one - that might cost you about 100 bucks if the unit can be done in the yard by a serviceman. Chemicals can hurt the Unit if not done properly ( and yourself). It sounds to me like you use it for a Business - if so you can purchase one and write it off .
Jul 18, 2009 | Sharp AFR120NX Thru-Wall/Window Air...
My fan has stopped working the laptop is 1 year old. I was having a problem a few months ago and hp took over computer and fixed problem my warrenty has run out help?
hello, have you looked to see if dust or other objects clogged the the fan, could also be failed or getting no power, open the notebook if you are comfortable with that, and see if you can turn it with finger, you will also see the wire and if it is dirty. good luck,
Mar 15, 2009 | HP Computers & Internet
Freezer refreezing continuously
Yes the defrost system is not functioning properly. You will need  a Ohmmeter to properly diagnose it. If you are going to tackle it and need to know what to check, let me know. If so the defrost thermostat (clipped to a freon tube near the top of the coil in the freezer) Should be closed when its below 20deg and open when its 50+deg. Also the heater should have somewhere between 10-20ohms reistance.
Oct 21, 2007 | Frigidaire FRS6R4E Side by Side...
Computers & Internet Logo
27 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
