Question about Compaq Evo Notebook N400c
I had installed a bios password on my Compaq Evo N400c, which i have forgotten, i need to make my CD as 1st boot device so need to reset its Bios password.
    Problem Solver:
  • 6 Answers
I found this fix for your problem on http://forums11.itrc.hp.com
If you have lost your BIOS password(s), then you can clear them by removing all power from your laptop for a while.
I think you are familiar with how to enter the BIOS - but if not - look here:
http://tinyurl.com/hlusx
You may need to consult the Maintenance & Service Guide for your N400C to find and remove the RTC battery. You can access that and all the documentation for your notebook here: http://tinyurl.com/mda9a
This is the procedure to clear the Set-up (BIOS) passwords:
(1) turn off the computer.
(2) If it was in a docking bay, remove it.
(3) Disconnect A/C Adapter.
(4) Remove main battery pack (and the secondary battery if one is fitted.
(5) Disconnect the Real Time Clock (RTC) battery from the system board. (You'll need to remove the palm rest and keyboard to do this - there are clear instructions and pictures in the Mtce & Svce guide referenced above. You should see a tiny white plug on the end of the RTC coin cell leads. Disconnect it - you do not need to remove the RTC battery.)
(6) Now wait 30 minutes. (The 5 minutes quoted by HP in some of its manuals is not enough)
(7) Press and hold down the laptop power button for 1 minute. (This is intended to clear any stray voltages or static that's still around)
(8) Reconnect Real Time Clock battery and re-assemble laptop. (BUT DO NOT re-fit the main battery yet.)
(9) Hook up the A/C adapter and turn on the laptop. System should boot up OK - press F1 or F10 while on Compaq splash screen (ie before windows starts to load) to access BIOS.
(10) All passwords should now be cleared. Check you can enter BIOS OK. It should be restored to Compaq default settings with no power-on or admin passwords.
(11) Now you can re-insert the main battery (and secondary battery if you have one)
(12) Now reset date, time and other BIOS settings as you want them to be.
(13) If you set any passwords - make sure you keep a note of them somewhere safe but outside the laptop !!!!
Hope this helps
Posted on Mar 31, 2011
Evo N610c bios password
BIOS passwords can be reset in two ways,
1. using software 2. using hardware.
I would first try resetting using software, here are two software's to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
CmosPwd - Cmos password recovery tools
Please let us know if it works.
May 29, 2011 | Compaq Evo N610C Notebook
MY COMPAQ EVO N400c HAS A POWER ON PASSWORD THAT I HAVE FORGOTTEN I NEED TO PASS IT TO MY SON BUT HE CANT USE IT COS OF THAT I HAVE REMOVED THE RTC BATTERY AND THE MAIN POWER PACK FOR A LONG TIME AFTER I...
Many manufacturers leave a backdoor password built in, especially on older Laptops. Try entering 'Compaq' including the capitalisation. If this doesn't work then you could try using !BIOS.
!BIOS is a freeware utility which is designed to be a whole BIOS and security suite. It has the ability to decrypt the passwords used in some of the most common BIOS.
Note: Because of this applications password cracking abilities, some antivirus software may report it as a virus/trojan. This is a false positive.
To start using !BIOS, reboot your computer and take note of the BIOS type and version you are running. For example, If your motherboard uses Award BIOS you should look for the text "Award Medallion BIOS 6.0? or something similar.
Download !BIOS from here and save it to your desktop. Then, open a DOS command windows by going to Start > Run and type: cmd
Once you see a black screen in front of you, type: cd desktop
You should now see something like: C:\Documents and Settings\YourUserName\Desktop>
Now type the name of the file you just downloaded, if you haven't changed the name just type in: bios320.exe
Use the down arrow and choose "Crackers" and then press the right arrow. Using the up and down arrows, select the BIOS that the motherboard is using and press Enter.
You should now see a menu asking what you want to crack, in most cases its the Supervisor or System Passwords you want to crack, so press the 1 key on your keyboard. It will then show you another menu asking how you want it to be cracked. Option 1 is pretty good so try that first by pressing the 1 key on your keyboard. You should now have your BIOS password.
Reboot the computer, enter the BIOS and try it out.
May 04, 2011 | Compaq Evo Notebook N400c
Give me password for compaq evo n600c
You can remove your bios password by reseting your CMOS battery or jamper. You need to open your notebook remove first the battery and all screw at the back of your notebook. You can see there a CMOS battery together with the CMOS jamper. Just read it you can read CLRSCR which means clear cmos, just pull it with in 10 seconds and insert it back. Now you are done to reset bios.
Mar 03, 2010 | HP Compaq Evo Notebook N600c
I have a compaq evo n400c pc and when i switch it on it always asks for the power-on password which i do not have because i have forgotten it. how can i restart the pc and create a new password so i can...
Try booting up into safe mode and changing the account's password or deleting the account. If it is a BIOS password, then you will have to contact the manufacturer.
Dec 13, 2009 | HP Compaq Evo n400c Notebook
Compaq Evo D310 power on password reset
you can reset it easily by using the jumper near the bios battery (usually) on the motherboard then go into the bios settings at boot time. hope this helps
Aug 17, 2009 | Compaq Evo D310M 845G P4 Motherboard
I have a compaq evo n400c needs a power on password key
If you forgot your password then you have to take your laptop to hp service centre. Because the laptop need to be disassembled before one can reset the poweron password.
Nov 23, 2008 | Compaq Evo Notebook N400c
How to reset BIOS password for Compaq EVO N160 notebook
Do the following steps -
- Remove the laptop battery - Remove the CMOS battery - Leave it for idle for around 15 minutes - Put the CMOS battery in - Boot the laptop  with AC power - Then put the laptop battery in.
 - The BIOS pwd would have been reset now
- For troubleshotting the battery - Go into BIOS and run the Battery Caliberation tool
Hope this helps. Thanks, AK
Oct 27, 2008 | Compaq Evo N610C Notebook
Evo n400c
yes it is possible
if you have operating system of xp than it will install automatically if its not done
then first you should install the driver. then you can use it.
Jan 16, 2008 | Compaq Evo Notebook N400c
Compaq Evo Notebook N400c Logo
245 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
