Question about Health & Beauty
My TGA eclipse mobility scooter will not drive - diagnostic giving 5 flashes which is supposed to indicate brake problem - doesn't have a brake! All switches are where supposed to be and battery fully charged, new 4 weeks ago. Please help we are away on holiday and can't get to the dealer.
  • 5 more comments
  • patmayes Mar 31, 2011
    my TGA Eclipse mobility scooter will not start. It was working perfectly before I brought it on holiday, diagnostic light flashing 5 times. battery is fully charged and new 4 weeks ago. as on holiday cannot take it to dealer. we are in south of france. all previous reply seemed to refer to motor scooter and talked about break leaver which this does not have.
    new battery not new scooter
    scooter mobility will only deal with us if we bought from them. It seems that the brake is stuck on even though the lever is in the drive position. Scooter under 2 years, battery 4 weeks old.
  • patmayes Apr 01, 2011
    my TGA eclipse mobility scooter will not drive - diagnostic giving 5 flashes which is supposed to indicate brake problem. All switches are where supposed to be and battery fully charged, battery new 4 weeks ago. Leaver had been put into neutral position for loading then in drive position with brake engaged We are away on holiday, can't get to the dealer who is not answering the phone either. Please help someone as we a re a bit stuck in the south of France with the dealer in the north of England
  • patmayes Apr 02, 2011
    trying it now - had given up and gone to bed so just got your message now
    didn't work! Think we will just have to manage without it until we get back to England and see the dealer - thanks for trying.
  • Robin Hill
    Robin Hill Nov 06, 2013
    The TGA Eclipse does indeed have a brake, it located on the side of the motor, check the connections to this brake from the controller
    Brigadier General:
  • 4,736 Answers
Disconnect the battery cables and allow it to remain disconnect for at least 10 minutes. Doing this should allow the electronics to reset themselves and solve the problem. If that fails, in the UK call
0800-046-8136. They can help you over the phone.
Posted on Apr 01, 2011
  • Rich Landrum Apr 01, 2011
    Did disconnecting the battery for ten minutes allow the unit to reset itself, as I suggested?
  • Rich Landrum Apr 02, 2011
    patmayes, I'll be away this weekend, but would like to know how it worked out for you in the end. I'm sure this puts a damper on your holiday in southern France, but I hope you will make the best of it.
  • 17,970 Answers
Sound like a electrical problem
Keep in mind the new device and its possible that you have warranty for this, you can reach they using the contact details below:
Scooters Mobility Ltd
Suite 3
40 Melton Road
Oakham, Rutland
LE15 6AY
T: 0845 273 9717 (local rate)
F: 01572 801 075
E: info@scooters-mobility.co.uk
Try this before to do something, you could lost the warranty..
Keep us updated.
Posted on Mar 31, 2011
  • ZJ Limited
    ZJ Limited Mar 31, 2011
    According with Scooter fault codes...
    Flash Code: 5 X
    Fault: Brake Fault Scooter will not operate.
    Action: Check Brake Release lever position. Check Brake connector. Contact Factory Service.
  • ZJ Limited
    ZJ Limited Apr 01, 2011
    Flash Code: 5 X
    For you self security, contact Factory Service.
    Genius:
  • 1,622 Answers
Are you pulling in the left brake lever? All scooters require that you pull the rear brake lever as you push the start button. It's a safety to keep the scooter from rolling away if you have too much throttle and it's on the ground.
Starting Elements
To start a scooter, four things need to happen: the ignition has to be on, so make sure the ignition switch is in the "on" position. Make sure the kill switch near the right handle grip is in the "on" position. If this switch is not turned on the scooter will not start. Squeeze the left brake lever when starting the scooter---the safety interlocks will prevent the scooter from starting if the brake is not on. Last, be sure the starter button has been depressed. If the starter relay is not able to transfer power to the starter motor the scooter will not start, so be sure to check the relay first.
Use a Test Light
If your scooter is not starting, use a test light to make sure there is adequate power. Use that test light to check the post at the starter to make sure it is hot. If the post is hot, the next thing to check is the wire that runs from the starter switch to the starter relay. When the starter is depressed the test light should register 12 volts. If the test light does not read 12 volts the starter switch is probably bad. If the reading is 12 volts, the starter relay is good and you should check the wire running from the starter relay to the solenoid. If that wire is not hot, the starter relay will need to be replaced.
Check for Spark
If the scooter turns over, but does not start, check for spark before doing any other troubleshooting. To check for spark, remove the spark plug from the cylinder, hold the tip of the plug against the cylinder head and crank the engine. If the ignition system is working properly, you should see a spark jump across the gap. If there is no spark, the ignition coil or electronic ignition module will need to be replaced. If the spark is good use a test light to check the wire which runs from the starter relay to the starter solenoid. If the test light registers insufficient voltage the starter relay is probably defective and will need to be replaced.
A battery tender like the Battery Tender Jr. can make all the difference in whether your scooter will start right up each spring, after being stored for months.
Just about every scooter owner needs to have a battery tender, sometimes called a trickle charger. Unless you are lucky enough to live in a climate where you can ride all year long, chances are your scooter will be put on ice, figuratively-speaking, for at least a couple months every winter.
One of the key steps in winterizing a scooter is to protect your battery from draining during its "rest" period. This can - and will - happen if you leave your battery sitting untended in your cold scooter over the winter, even if it's in a garage or shed.
Use the link for parts purchasing and under knowledge about scooter repairs.
http://www.partsforscooters.com/
http://www.jacksscootershop.com/maintenance_tuneup_how_to.html
TGA Mystere mobility scooter. Scooter drives perfectly but drains batteries within 5 minutes of driving. Have tested with brand new batteries but still does the same. Help!
Hi again ring TGA PARTS FOR A PRICE ON CONTROL BOX 0117 329 1740 good luck i think u need to check THE BATTERIES condition buy a BATTERY LOAD TESTER .OF E/BAY COST APROX ,$35 ,.THIS WILL GIVE U A TRUE READING ON THERE CONDITION,,. Cheers
Dec 27, 2016 | Health & Beauty
The self-diagnostic light is flashing 5 times for a brake fault.
CTM info on flashing 5 times is CHECK FREEWHEEL LEVER IS IN DRIVE,,check wiring .connections good luck
Apr 21, 2016 | Ctm HS 125 3 Wheel Power Scooter
Tga vita4 red light flashes5times then comes up error 5
hi , that s related to a brake fault, check connections and the micro-switch that is closed when you operate the free-wheel lever...
Make sure it 's in drive mode, you can push the scooter when i nthis mode...
Regards
Rob...
Aug 02, 2015 | Health & Beauty
Our tga eclipse is constant beeping and flashing 5times.trouble shoot says free wheel mode...have checked this what can be wrong?
There is a micro switch on the brake unit, make sure the freewheel lever is hitting the switch.
Oct 17, 2014 | Health & Beauty
Aquasoothe travelite scooter, the batteries are fully charged, the battery gauge is showing full, but the battery light is flashing. It flashes 7 times then pauses, we can't get the machine to move or...
Response to similar query in 2011.
http://www.fixya.com/support/t5751777-aquasoothe_travel_lite_instruction
not my words. The link to the pdf for this is http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
you want page 22.
Problem Check Point
The driving of the wheelchair is too slow or insufficient, the status
indicator lamp flashes slowly Batteries are exhausted and need to be recharged
1 flash The battery needs charging or there is a bad connection to the battery. Check the connections to the battery or charge batteries.
2 flashes There is a bad connection to the motor.
Check all connections between the motor and the controller.
3 flashes The motor has a short circuit to a battery connection.
4 flashes Freewheel is engaged.
5 flashes Not used.
6 flashes The controller is being inhibited from driving; this may be because the battery charger is connected.
7 flashes A throttle fault is indicated. Make sure that the throttle is in the rest position before switching on the scooter
8 flashes A controller fault is indicated. Make sure the controller connections are secure.
9 flashes The parking brakes have a bad connection. Check the parking brake and motor connections. Make sure the controller connections are secure.
The-Active-Light
does not function,
the Battery/
Status indicator
flashes rapidly.
Count the number
of flashes:
10 flashes
An excessive voltage has been applied
to the controller. This is usually caused
by a poor battery connection. Check the
battery packs and controller
connections.
Sorry wasn't sure how much space they give you for answers. :)
Oct 11, 2013 | Health & Beauty
I turn key on celebrity scooter. everything looks normal. all lights on, but does not run.
Are the lights flashing or steady? If they are steady and indicate that the battery is charged, make sure that the freewheel/manual brake release lever is in the drive position. If the lights are blinking, then you can visit this site to locate the type of controller on your scooter to try and determine what the problem may be: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
If you continue to have problems, please contact Pride Mobility Technical Support for assistance.
Dec 22, 2010 | Pride Mobility Products Pride Mobility...
I have an electric mobility scooter 302Le that is fully charged but will not run. The lights and horn all work but the scooter will not move. The led light in the control box flashes five times. Can you...
Barb the flashes indicate a brake problem. Make sure that you aren't in freewheel. Move the freewheel lever located at the rear of your scooter up and down a few times then put it in drive mode and turn the scooter on and see if you still get 5 flashes If so you will have to replace the brake assembly Hope this helps
Oct 20, 2010 | Health & Beauty
Scooter does not respond to control. Diagnostic light flashes 5 times. Can you help?
Hi ,
5 flash - >> Brake feedback error
Drive inhibited Check that the Park Brake release
switch is off. Check the Park Brake
and wiring for open or short circuits.
Check the brake connections, the two wire leading to the brake, if the rear motor comes away fro mthe frame make sure there is a good connection between the rear part and the main frame.
Regards
GeWiz.
Jan 27, 2010 | Golden Technologies Companion II Travel...
Health & Beauty Logo
1,765 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
