My frigare portable air conditioner is working but it can't cool my room no more even the water doesn't come out the hose in the back of the unit no more can u help me
    Brigadier General:
  • 4,736 Answers
Sounds like the AC Compressor may need a recharge of refrigerant gas. Particularly, since there's no condensation dripping out of the drain tube. This is something that a qualified AC technician should do.
Posted on Mar 31, 2011
Remove exhaust hose
U need that hose to direct the warm air outside the area to be cooled. If you remove it, the hot exhaust will stay in the room being cooled and negate the cold air being directed into the room.
That is why regular room AC units are mounted on window sill. Cold air in, hot air out.
Oct 08, 2015 | Haier Commercial Cool 8,000 BTU Portable...
Excess water prodution in portable 14000 BTU unit. See below
all a/c units remove moisture from air with cooling coil being cold and room air blowing across coil - depends how humid it is - i have used several different portable units and this seems to be a common problem if it is humid
Jul 03, 2014 | Commercial-Cool 8,000 BTU Portable Air...
My LG LP1200DXR Portable Air Conditioner seems to be working properly, cooling the room as it should but no longer is draining any water. It does not shut off as it would when it is full although I have...
Actually, your unit was not designed for continuous draining. It needs water in the tank to help cool the coils. I'm sort of surprised that the unit hasn't stopped cooling or hasn't overheated. Since you haven't seen any water in the drain tank you have, it may have pasted the point of no return. Disconnect the hose, reinstall the drain plug and hope that you have to start emptying the tank again, soon.
Hope this helped you and thanks for choosing FixYa.
Aug 19, 2011 | LG LP1200DXR Portable Air Conditioner
My Haier 7000BTU portable AC unit is blowing hot air into the room from the back. We have the drain hose in and draining, so what might be the problem?
The drain hose is only to be used when the unit is in Dehumidifier Mode. In AC/Cooling Mode, there needs to be water in the tank to keep the coils cool. It is not recommended to use continuous drainage in AC Mode. My personal recommendation is do not operate Cooling Mode & Dehumidify Mode at the same time. As the dehumidify mode generates heat. Not something you need to be doing when you're trying to cool the room.
Jul 31, 2011 | Heating & Cooling
The unit is not cooling the room. Water is not draining out the water hose.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 17, 2010 | Alen C400H Portable Air Conditioner
AC was cooling fine. Now, won't cool room even though cool air comes out. Exhaust hose is extremely hot.
Check filter, if you have a 5000BTU unit (small) and it is extremely hot, then it wont work great for a big room. BTU is the rate of what the AC will put out. 5000 BTU is good for a small single room. 10,000 will cool a bigger room and 18,000 btu is meant to cool a home.
Jul 07, 2010 | Whirlpool ACP102PS Portable Air...
Fan blows room temp air, I can hear the AC kick in but it only runs for about 30sec to 1min before cutting out and making a sputtering sound that shakes the whole unit. Then it just goes back to blowing...
check you condenser fan motor make sure it turns on, if ok you must clean the fins on the outside unit,with a water hose , make sure you turn power off first before taking a water hose to unit
Aug 30, 2009 | EdgeStar AP420HS Portable Air Conditioner
Air exhaust hose gets extremely warm
The Pinguino's exhaust pipe has to be attached to the window bracket to direct the air hot air out of the room, otherwise the room can't cool properly.
The owner's manual has several troubleshooting remedies for you to try:
1)  If the window is open, close the window. 2)  If there is a heat source in the room (burner, lamp, etc.), eliminate the heat source. 3)  If the exhaust hose is detached, connect the exhaust hose.  (My recommendation is to connect the exhaust hose to the window bracket and direct the air outside.) 4)  If the air filters are clogged, clean or replace the filters.
Remedies that aren't mentioned in the manual, but you might find helpful:
1)  Make sure that there are no kinks in the hose, and that the hose either remains straight or has a gentle curve when directing it into the window bracket.
2)  A sunny window reduces the maximum power and efficiency of the unit.  Placing it in a sunny window reduces your BTUs by at least 600, which means the maximum square footage of cooled space is reduced.  Cooling a kitchen requires at least 4,000 BTUs alone, which is nearly half of the unit's BTUs.  Try to place the unit by a window that receives minimum to no direct sunlight.
Finally, stating the obvious, if the room isn't cooling, the room is too large for the unit.  The PACL90 cools up to 400sqft.  Bear in mind that the air from these portable air conditioners cannot move around corners very well, so try to set it by a window in the central part of the room.
Jun 13, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Portable Room Air conditioner will not cool
You need to call for for a qualified technician oil residue is a sign that your unit have leaking, your unit is out of refrigerant.
Nov 12, 2007 | GE APN10AA Portable Air Conditioner
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
