Question about InFocus LP70+ Multimedia Projector
In Focus projector LP 70 +
Just got sent a used projector from my company. When I tried to turn it off with the power button, it stayed on. Is that because it has to cool off first before it turns off? How long does that usually take?
  • Anonymous Mar 05, 2009
    I push the power button and hold down but lamp will not shut-off.
    Problem Solver:
  • 11 Answers
It should shut down in about 2 mins. if you need repair try avalontc.com they are reasonable.
Posted on Aug 06, 2008
6ya staff
SOURCE:
Infocus 250 will not turn on at all.
The power button is solid green? try to turn on whit the remote control. Try to clean the surface on the Main board, uder the contro panel.
May 31, 2010 | InFocus LP 240 Multimedia Projector
InFocus LP 250 Multimedia Projector was working fine until i unplugged it and when I went to plug it back in, I used my computers power cord instead of the projector but the plug is almost identical. I...
The plugs on this model projector is very delicate, over time the solder around the plug will begin to crack. Until eventually the connection is lost. Another possibility is that the power supply has gone bad. Using another cord would not cause this. I can fix the projector if you'd like. My ebay screenname is gtitubro.
May 11, 2010 | InFocus LP 250 Multimedia Projector
The device is an InFocus LP 290 with less than 100 hours on the bulb. I have used the projector several times over the course of two years without any problem, but never longer than 3 hours at a time. A...
there is an issue with the power supply edge connection with the main board. you'll need to have it sent to an infocus service center for repair. try av solutions in ny. they're pretty good. www.avsolutionsny.com
Nov 24, 2009 | InFocus LP290 1100 Lumen XGA LCD Projector...
Infocus LP 70 projects a blurred display
Go to control panel and reset hardware configs that way.
Jun 29, 2009 | InFocus LP 70 Multimedia Projector
InFocus LP240 Projector won't turn on.
there is a fuse on the power supply next to the plug (on the inside), but this model of projector has power supply issues. the biggest being that infocus no longer has parts, schematics, or component cross references for the lp240. the circuit boards were made by another company that made had their own components and now no longer makes circuit boards (they make fans and bearings), and they have no schematics either. so, i'm sorry to say that the machine is doa. there are no replacement parts available and almost no way to fix the old ones.
May 19, 2009 | InFocus LP 600 Multimedia Projector
Infocous LP 530 Light comes on then stops
this could be one of three issues. the power supply. the firmware or the lamp. thebulbman.com
Feb 03, 2009 | InFocus LP 530 Multimedia Projector
PAL support
Yes the LP70 and the LP70+ both operate perfectly with a PAL source. Also the will operate just fine using 220vac 50hz too.
Cheers
May 31, 2008 | InFocus LP 70 Multimedia Projector
LP 530 Lamp does not power on
Did you cancell the bulb fault status in the main menu ie bulb hours when you changed your bulbs if not try this turn unit on and see if it works it may do.
To reset the lamp hours counter press and hold down the Volume minus button - , then press the source button whilst still holding down the volume button for 5 seconds .
If this works you can then verify that the lamp counter was reset by viewing the counter in the status window in the OSM
hope this helps... Regards Vortash
Feb 27, 2008 | InFocus LP 530 Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
190 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
martin hogg
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
