Question about Sharp AR-275 Copier
Meaning of error E7-02 of sharp AR-275 - Sharp AR-275 Copier
  • Sharp Expert
  • 316 Answers
E7-02- LSU trouble
Posted on Apr 13, 2011
  • amir hamza
    amir hamza Apr 13, 2011
    E7-02 - LSU trouble
What does code u2-40 mean and how do i by pass it
Hello, You can download the manual here http://sharp.diplofix.com/forum-SHARP/AR-275
It looks like this error is a CRUM chip error, which could be caused by the type of toner cartridge you are using, and or the actual CRUM chip. The connector could be bad (check the connector for the toner cartridge) or when you replaced the toner cartridge; it may have bent the plate that it is mounted on and it needs to be straightened, realigned.
Oct 07, 2010 | Sharp AR-275 Copier
Error code L6-10 on sharp ar-275
try to reset or replace the polygon motor
Nov 17, 2009 | Sharp AR-275 Copier
SHARP AR 275 PROBLEM E1 15 ERROR AFTER SOLVING THE U2 40 PROMLEM
Porfavor ayudenme necesito su ayuda urgentemente. este problema ya lleva 2 semanas asi y no me permite ni scanear ni imprimir ni nada.
Aug 06, 2009 | Sharp AR-275 Copier
Getting a CE-02 error when trying to scan.
1) Check that the Network Cable is
inserted properly.
2) Check that the connected network
supports TCP/IP protocol.
3) Check from the Web Page that the
Primary/Secondary E-mail Server
Address or the Destination FTP server/
Desktop PC address are properly set.
4) If the above address is described with
Hostname, check that the DNS server
is properly set.
5) Check that the SMTP server/FTP
server/NST causes a trouble or not.
Jun 10, 2009 | Sharp AR-275 Copier
H2 00 problem
Try to reset the error code by pressing these buttons :
[#] [interupt] [c] [interupt] [1] [4] [start/copy]
If the error code still exist check the thermistor and it's connection and reset again.
May 21, 2009 | Sharp AR-275 Copier
Sharp AR-275 Copier
Hello sir; there have no reset key for maintenence, whenevere PM light on you need to do PM service (such as replace drum developer, drum blade etc.)
May 19, 2009 | Sharp AR-275 Copier
Call for service U2-40, on a sharp AR275 printer
In AR 275 Sharp copier U2 40 is very common problem, U have to only reset the above error code as fallows
press # then intrrupt then c them intrrupt then display will show simulation mode then enter 16 then press ok key
pl ask for any difficulty
May 17, 2009 | Sharp AR-275 Copier
Sharp AR-275 copier with fax module. Need to edit sender ID
push custom or system setting button, push key operator programs on lcd, type in 00000 from number pad, hit fax settings, fax default settings, own name/number set. hit ok button at top when done then CA button to return to main menu.
Mar 04, 2009 | Sharp AR-275 Copier
Sharp copier printer error: PostScrip printing not licensed for t
what is you OS? check you printer drivers. are they properly installed?, what is your connection between your PC to your printer?, AR 275 can be connected thru network, parallel port, and a USB... they have different printer drivers
Feb 01, 2009 | Sharp AR-275 Copier
Sharp AR-275 Copier Logo
174 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
