Question about Amana DLG330RAW Gas Dryer
Dryer gets to hot
My problem is that my fryer gets to hot.  To the point that it burns clothes.  I have removed all lint buid up in the dryer and the vent. I have replaced the flame sensor, thinking that was acting as thermcouple.  What else get it be?
  • MADDOGROB Nov 01, 2008
    I HAVE THE SAME PROBLEM IT GET TO TO HOT
  • David Ransom May 11, 2010
    did you clean the whole vent with a vent brush like the whole pipe
Yes, I removed the vent pipe and the front of the dryer, vaccumed both. Removed the blower cover and cleaned that out. Cleaned everywere that lint could get to.
Posted on Aug 05, 2008
SOURCE:
My electric dryer won't dry clothes. Doesn't get hot, what's wrong with it?
how is the lint filter maybe it is too full of lint and the dryer will not heat up to protect you from burning doen your house when the lint filter gets too hot and catches fire. Just a thought
Oct 28, 2014 | Dryers
Clothes get caught
Instructions
Remove the lint screen from the GE electric clothes dryer.
Roll the lint from the screen with your hand. If the lint screen is clogged with fabric softener, fill a sink with hot water and add 1 to 2 tsp. dish soap.
Scrub the lint screen with a soft-bristle brush and soapy water. Rinse the lint screen thoroughly and shake off any excess water. Set the lint screen aside to air dry while you clean the dryer exterior.
Dampen a cloth with warm water and wring it out. Wipe over the GE electric dryer exterior to remove any lint, dust or product residue. If the dryer is very dirty, dip the cloth in the soapy water and wipe away any spots.
5
Wipe the GE clothes dryer with a towel to dry. Replace the lint screen when it's completely dry.
Jan 09, 2013 | GE DCVH515EFWW Electric Dryer
Affinity dryer burning clothes
Probably a seal around the drum or blower needs to be replaced.
Affinity service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 24, 2012 | Frigidaire Affinity FAQG7011KW 7.0 Cu. Ft....
There is a burned odor when drying my clothes. How do I get lint from inside the dryer out if this is a problem
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 20, 2011 | Miele Novotronic T1515A Electric Dryer
Heating elements are lit up working normal, drum hot but not inside of drum. it takes forever to dry clothes. vent wide open no clogging inside. need help ?
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Jan 04, 2011 | Whirlpool LER5636P Electric Dryer
Problem for Frigidaire FSE748GF Dryer Brown marks on clothes - What could the problem be and how do you fix it.
If the clothes have a 'burned' smell, likely, the air flow through the machine is restricted and getting too hot. Vacuum out the exhaust hose and the outside vent of lint. Reach inside the machine's air outlet pipe and vacuum all that you can reach. Remove the lint filter and wash it in hot water and detergent to remove fabric softener deposits. Vacuum below the lint filter opening as far as you can reach and inside the door cavity (be careful of sharp edges!). Hope this helps!
May 16, 2010 | Frigidaire FSE748GF Dryer
Getting Hot, but not drying the clothes
there has got to be some restriction in the vent system. Take the vent pipe completely off and look in the tube coming directly out of the dryer. Also make sure the drum is turning good speed.
Jun 07, 2009 | Dryers
HI I HAVE DLG2524W. IT DRYES CLOTHS BUT THERE IS LITTLE BURNING SMELL GET INTO CLOTHS
Pull out the dryer and remove the vent pipe. Check it to remove any lint and also check inside of the machine to remove lint.
Apr 07, 2009 | LG DLG2524 Gas Dryer
LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Dec 01, 2008 | LG DLG5932W Gas Dryer
Burning smell coming from the dryer!
You have a serious clog somewhere in your dryer exhaust ventilation. I would recommend you STOP using the dryer immediately and clean both the interior and all the vent ducting from where it exits the dryer to where it exits the home. the burning is coming from lint build up in and around the heating element and its beginning to smolder. This is a potential fire hazard and may end up causing the heating circuits to fail. The condensation comes from the the inability of the hot air (which is mixed with humidity from your clothing) condensating inside the vent duct. The lint starts to collect and get wet to the point of saturation. Then it begins to cause water to form and leak out of the ducting and on to your floor. You do not want this condensation inside the dryer where the heating circuits are. The following link will provide with some guidance for future reference:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Pay particular attention the paragraph where it discusses proper dryer ventilation. I hope this helps you. Let me know if I can be of further assistance.
Sep 28, 2008 | GE DBSR453EBWW Electric Dryer
Amana DLG330RAW Gas Dryer Logo
188 people viewed this question
Top Amana Dryers Experts
Marvin
Marvin
jdthefixer
Android Man
Android Man
Are you an Amana Dryer Expert? Answer questions, earn points and help others
