Question about Technics SUV500 2-Channel Amplifier
How must I connect the amplifyer V500 with my computer for recording from a tape player?
  • 635 Answers
I assume you want to record from tape to computer and monitor the recordings later.
Simple three steps.
1) Connect the tape deck line out ( or labeled PLAY ) to any one of the inputs like Aux / Tuner using an 2RCA connector.
2) Connect Rec out from the SUV' to line input of your PC ( blue socket ) sound card.
3) To monitor your PC sound after recording on to Hard Disc , connect a cable between the PC sound out ( green socket ) and the the SUV Tape monitor IN ( sometimes labeled PLAY ) Now comes the tricky partHow must I connect the amplifyer V500 with my - bobhifi_30.jpg.When you want to record on to your PC put the source switch on the SUV to where you have connected the Tape deck ( Aux / Tuner ). On the SUV keep the Tape Monitor switch to source ( released position ). After having done the recording to monitor and hear the Hard Disk playback turn on the Tape Monitor switch ( dipress it ). The pressing of the Tape switch on the SUV lets you toggle between the source and recording - In your case Tape deck and PC
Posted on Apr 02, 2011
How to convert VCR to DVD
no easy way to do this unfortunately. You either need to connect your VCR to a DVD recorder and record it directly onto DVD or use a device such as this http://www.dx.com/p/easycap-usb-video-capture-adapter-5707 to connect your VCR to your computer and record it onto your computer that way.
Feb 23, 2015 | Zenith XBR616
Tip
Is there a program out there that will convert my old cassette tapes or vinyl...
The short answer is yes. There is a program out there that will record cassette tapes or vinyl records to CD. Today, I will show you how. If you have the right software and the right cords, getting your cassettes and Vinyl onto your computer, then onto CDs, is a pretty easy task. Just follow the steps below and you will be on your way to bringing your audio into the 21st century! What you need: To make the conversion, you will need a (free) audio recording program, a tape or record player and a cord to connect the device to your computer. Here's a breakdown:
1. Audacity. This is the program that will record your audio to your computer.
2. LAME-encoder. This is a file that will convert your audio to MP3.
3. A record player or cassette player. Hopefully you already have one of these.
4. A cord to connect the player to your computer.
The first step is to install Audacity and LAME,
Now that we have the software installed, we can look at connecting your tape player, or record player, to your computer.
Your player will have one of two types of outputs. You will either have a standard 3.5mm headphone jack, or RCA audio output jacks.
If your device has RCA outputs (left image)to connect to your computer.
If your device has a 3.5mm jack (right image) to connect to your computer.
The other end of the cable will connect to the line in jack on your computer
Now that we have the software installed and the cassette/record player connected to the computer, let's record something!
Put a cassette or LP into your player. Get the player to the place where you want to start recording and pause or stop the player.
Now, let's stop messing with all this hardware and get the computer set up. First, go to your control panel and open your audio settings.
In XP, go to the audio tab and click "volume" under sound recording. Place a check next to "line in". If you don't see a "line in" option go to options and click advanced. Place a check next to "line in" there.
In Vista/7 go to the recording tab. find your line in, select it then choose "set default". Click on "properties", go to the levels tab and turn up the level to 80 or 100. (This varies depending on what you are recording so you may need to adjust this to get it right).
As you can see, Audacity is pretty much a more advanced sound recorder. To begin recording, press the play button on your record/cassette player then click the red "record" circle on audacity. You are now recording to your computer! When you are done, click stop on audacity and press stop on your player.
After recording, you can now export your audio as an MP3. Go to the file menu and click "Export as MP3". You can now choose the name of the file and save to wherever you want. You are done recording!
on Dec 14, 2009 | Computers & Internet
How do you connect Sony rcd-w500c to Sony tape deck to record tapes to CDs?
Line Out from the CD player/recorder goes to REC IN on the tape deck
Sep 09, 2014 | Sony RCD-W500C 5-Disc CD Recorder
How do I attach and play a technics record deck to a technics DV250 amplifyer?
The problem you are facing is that the record player audio outputs has a left channel, a right channel and an earth or grounding cable. If this grounding cable isn't attached, you are likely to get a hum sound. I would suggest buying a record player RCA (Ground simulating) cable or you will have to buy an inexpensive mixer that supports record players through which you can channel this record player. Once you have all these, just follow the white and red color coding to attache the right channel to the right socket.
May 10, 2014 | Technics SC-DV290 System
How do I record my cassettes into my PC
find a tape player/recorder than has the capability to connect to a computer connect your tape player/recorder to your computer open windows explorer navigate to the tape player open it then select the files you want to copy to your computer right click select copy then navigate to the place where you want them saved or you can select the files hold the muse cursor on them drag them to the place you want to save them and drop them into it
hope this helps
Nov 28, 2010 | Behringer (UCA202) Sound Card
How can I connect my CD-RW880 recorder to the
Make sure the phonograph is connected to the Phono Connectors. Hook up your CD recorder to the tape. The play connectors on the CD recorders can connect to the tape play connectors on your stereo. The record connectors on your CD recorder connect to the record outputs on the tape connectors on your stereo. You can also connect you CD recorder to the VCR connectors if you are using an audio tape as your source. All of the outputs and inputs are the same level except the phono.
Jun 12, 2009 | Teac CD-RW880 CD Player / Recorder
Connections for a Grundig reel to reel tape recorder
Grundig TK23
Inputs at rear of machine. From Left to right.
Circle with line underneath. (Micro socket) - microphone, mixer (Grundig 607), telephone adapter.
Square with line on top - Radio input/Output. Record/playback radio. Record records if player is connected to radio for playback via a 3-pole amplifier unit. Re-recording to a second tape recorder. Connection to a Grundig Stereo-Mixer 608.
Reversed Q - Phono Input. Connection to a record player or a second tape recorder. (for re-recording records or tapes)
Squiggly lines - Outputs. - Connection to external speakers. Grundig Stereo Box. Connection to an additional amplifier (Grundig 229) for synchronous recording.
Square with line at right. - Earphones.
Loudspeaker switch - (At bottom) - In the "0" position, the internal speakers are shut off.
Dec 30, 2008 | Audio Players & Recorders
No sound coming through when recording from hi fi tape to computer
This is actually simple to do. Connect the line out on your tape player to the line in on your computer. Then download a free program, from the net called Audacity at http://audacity.sourceforge.net/. The program is totally free and works great. Some recording studios use this program. In the middle of the main Window on Audacity set it to record from Line in. This is from the small drop down menu next to the little microphone icon. Then hit the record button on Audacity and play your tape. You can record each song individually or you can record the whole side of the tape at once and separate the tracks when you save them. You can even use this program to clean up the sound on your recordings. I have transferred many of my tapes and records to CD using this process. I hope I have been helpful and good luck
Jul 01, 2008 | Genius Soundmaker Value 5.1
Dubbing from vcr to vcr
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder]
OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
May 24, 2008 | Zenith VCS442 VHS VCR
How to Record From a TV Using PV-GS13?
connect a lead via your tv video out audio out jacks. Select tha appropriate channel (You may have to go through the av channel on you tv and tune in the channel you want to record) or, video or dvd player audio out video out jacks. connect other end to your camcorder. Select on the camcorder menu video in audio in. Turn on tv. If connected to video or dvd player, press play. Press record on your camera. When finished recording press stop. Presuming the camcorder is tape, you can buy a tape adaptor to play or record your mini tapes in a standard video recorder, then take them out of the adaptor and play them back on your camcorder. You can also do all this via a computer. Also if the camcorder is disk or hard drive it can be used the same way as a regular dvd recorder to record tv programmes once connected to you t.v. Let me know how you go 26 red
May 08, 2007 | Panasonic PV-GS31 Mini DV Digital...
Technics SUV500 2-Channel Amplifier Logo
174 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
