Question about Rockford Fosgate Car Audio & Video
I have a Rockford Fosgate punch 50.2 idk the year or anything and i dont know where to put the power wire from battery to?
OuttaControl
  • 4 Answers
SOURCE: Wiring 2 subwoofers to a mono amp?
The subs can be wired "parralel" or in a "series". it depends on the ohm rating of the speakers and the amp. Most amps can only go down to 2ohms (mono) so it depending on the ohm ratings of the speakers when wired in a series vs parralel that will decide how to wire them. you can always take the safe route and just wire the positives of each to positive on the amp and the negatives to the negatives on the speaker terminals. Do you have the speakers model numbers?
Posted on Dec 22, 2007
hogan doan
  • 227 Answers
SOURCE: I need a wiring connector
Look on installerz.com. Goodluck.
Posted on Apr 24, 2008
duby1990
  • 370 Answers
SOURCE: Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
Posted on Feb 06, 2009
jpenn1192
  • 58 Answers
SOURCE: Rockford Fosgate P2 12" cone
TRY GOING TO, SONICELECTRONIX.COM, OR WOOFERSETC.COM
Posted on Jun 18, 2009
  • 1114 Answers
SOURCE: when my bass hits, my car lights flicker.
Is the problem much more noticeable when the car is at idle? Double check that Alternator output. 70 amps is not high output, and if the problem is especially noticeable at idle, it's probably due to the alternator putting out lower voltage( a common thing with alternators). Also, with that much draw from your sub amp, the wire from battery to alternator should be beefed up, as well as the ground wire from battery. You can make up your own cables by purchasing the wire to length and wire lugs at a local Welding shop, 4 gauge from alternator to battery is good. High output aftermarket Alternators shoot into the 200 amp range.
Posted on Aug 20, 2009
What is the watts on my rockford punch 360
Hello
Punch 360 can be wired as Mono and Stereo. Actually it it a 2 channes stereo amp, wirable to Mono too. When wired as Mono, the output power will be 450Watts. When wired as stereo, the outputs will be 210Watts/Channel. OK.
Dec 18, 2011 | Rockford Fosgate Car Audio & Video
I have a rockford fosgate punch P325.1 subwoofer mono amp that blows a fuse every time i start the car. I have a second pioneer amp but that works with no problems. How can i fix this?
Is it the correct size fuse ? Is it the power fuse or remote ? Either way check your connections going into the amp . Try this hook your other amp to the set of wires for the rockford if that amp has a problem its a wireing problem if not chances are its an interal problem on the rockford . Hope this helps !
Aug 19, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
Rockford Fosgate Punch 500a amp wont turn on
check the internal fuses inside the amp its self these burn up real easy plus if it is them it will save you some money
Mar 31, 2010 | Rockford Fosgate Punch 500a2 Car Audio...
I'm looking for a wiring manual for a punch 150 amp
Follow this link to the downloads page for Rockford Fosgate, you can choose the correct manual there.
LINK
Sep 25, 2009 | Rockford Fosgate Punch 150a2 Car Audio...
Rockford Fosgate punch protection light
power it off, then on...check you're fuses. unplug the car battery and try again. good luck.
Sep 05, 2009 | Rockford Fosgate Punch 800a2 Car Audio...
Feb 05, 2009 | Rockford Fosgate HE2 RFP4212 Car Subwoofer
Ohms load
u should be able to just dont wire the subs sown to 1/2 or 1 ohm I believe these amps can handle 2 ohms and above
Nov 23, 2008 | Rockford Fosgate Punch 700S Car Audio...
Rockford fosgate punch 700s gets very hot
Disconnect the speaker wires from speaker terminals on the amp and turn the amp on (turn the head unit on). Set the volume to zero on the head unit.
Does the amp get hot?
If it does, either the bias is set to high or the amp has other problems. If it does not, you may have the speakers wired to the wrong ohm load.
Nov 03, 2008 | Rockford Fosgate Punch 700S Car Audio...
Car Audio & Video Logo
51 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
